Old 06-26-2012, 10:58 AM   #337
Stu L Tissimus
Stu L Tissimus's Avatar
Drives: MT GB BRZ Limited
Just checking in again - I've been driving mine a lot since the camshaft sensor/oil valve were swapped out and I've had absolutely zero shuddering or dropping below 600 at idle. I really think they've found the problem.
I notice this the most when coming up to a stop light fast, and when i'm stopped, clutch-in, the rpm drops and comes back a moment later.
This is the exact situation it was most reproducible in for me as well.
Stu L Tissimus is offline   Reply With Quote
Old 06-26-2012, 11:11 AM   #338
Marrk
Drives: Honda Fit
Excellent, Stu. Thanks for the update.
Marrk is offline   Reply With Quote
Old 06-26-2012, 11:35 AM   #339
blackfireball5
blackfireball5's Avatar
Drives: Scion FRS Firestorm
Oddly enough, i think I've actually noticed this on my dads 2009 Lancer Ralliart with less than 9000 miles on it.
blackfireball5 is offline   Reply With Quote
Old 06-26-2012, 12:05 PM   #340
Hanzo
Hanzo's Avatar
Drives: Waiting for the ND Miata
How many miles do you have on it?
Hanzo is offline   Reply With Quote
Old 06-26-2012, 12:15 PM   #341
Marrk
Drives: Honda Fit
Hanzo, I've been following your posts and I think I know where you're head is at. If I'm wrong, forgive me.
This thing is playing out as a recall. If you are thinking that maybe you dodged a bullet and will not be affected, it may be time to slowly adjust to the idea that your car will have to go in for the repair. It won't be so bad, if what Stu's good result turns out to be the same for everybody.
First model year cars always have bugs. Everyone here who thought otherwise — and I remember all those statements about how Toy.-Sub. "really tested this one thoroughly," etc. — is nothing more than magical thinking and naivete.
Old 06-26-2012, 12:23 PM   #342
Hanzo
Hanzo's Avatar
Actually I am hoping for a recall because the noise is really bothering me and I did have the RPM drop a couple of times. I've had 1st model year cars since my 2002 WRX I was expecting recalls on new cars just want to make sure Subaru actually do a recall and not just leave us hanging.
Old 06-26-2012, 12:27 PM   #343
Marrk
Drives: Honda Fit
Me, too.
Old 06-26-2012, 12:32 PM   #344
Julio86
Julio86's Avatar
Drives: 2013 Scion FR-S 6MT
And you just took it in to the dealer or how'd you go about getting a fix or get it looked at. Did u call HQ of scion n let them know? Thnx
I don't always drift every corner, but when I do, I drift FRS . Stay drifty my friends
2013 Scion FRS Whiteout 6MT
Julio86 is offline   Reply With Quote
Old 06-26-2012, 03:27 PM   #345
FR-YES
Drives: FR-S, Firestorm, AT
Is this happening to both manuals and automatics? I have an automatic and have noticed that when I come in fast to a stop sign or red light the car will shake a bit almost like it wants to stall. I thought it was just me but after reading all this I think there's a problem. The weird thing is it doesn't happen all the time and doesn't really matter if AC is on or not. This sucks. I'm at 288 miles and thought it was just breaking in.
What is the hypothesized fix? I hope it becomes fact soon. I hate coming up to stop signs now and wondering if it is gonna do it or not.
FR-YES is offline   Reply With Quote
Old 06-26-2012, 04:22 PM   #346
Boosted2.0
Boosted2.0's Avatar
Drives: 13 FR-S, 00 Spyder&Celica, 08 Tundr
If you want to help get this fixed, there is actually something you can do to help. Monitor the condition - note EXACTLY when (time of day, temp / humidity / ambient conditions) and how it happens (ie: coming to a stop, foot on clutch, in neutral as idle comes down etc.) and what your drive pattern was before that point. (how long and how many miles had you been driving, how fast were you going, did you just get gas, etc). Then write all this down and bring it to the dealer and give them the all the info.
My shop diagnoses hard problems all the time, and the first step is always to duplicate the condition. If you can't get a car to do what the customer says is happening, there is often no way to diagnose it. This is true of almost any situation. And knowing when it acts up makes it infinitely more likely that they will be able to reproduce it and eventually diagnose the condition.
Also remember that numerous things can cause a similar condition. Too rich, too lean, too much cam advance, you didn't quite depress the clutch pedal fully, etc. This is why the exact conditions for duplication are so important.
Boosted2.0 is offline   Reply With Quote
Old 06-26-2012, 04:56 PM   #347
EsoBOFH
Senior Hoonigan
EsoBOFH's Avatar
Drives: 2016 Hot Lava 6MT FR-S
Recall might be jumping the gun here people, it seems a lot of us complaining of the issue are very low mileage...
I'm at 1600 km now, and had a good lengthy drive around town last night - I didn't experience the issue a single time (even when trying to reproduce it). It may be the ECU just learning (and me learning).. and the engine breaking in.
Naturally, I'm going to continue monitoring the issue... but I think it really just might be new-baby panic.
EsoBOFH is offline   Reply With Quote
Old 06-26-2012, 05:48 PM   #348
Boosted2.0
Boosted2.0's Avatar
Recall is def. jumping the gun. My car only did it one time fairly early on and I have almost 2800 miles on it already with no further problems.
Old 06-26-2012, 06:11 PM   #349
TuxedoCartman
Drives: '13 86
Actually, mine started having the problem after I got over 1000 miles on the odometer.
TuxedoCartman is offline   Reply With Quote
Old 06-26-2012, 06:41 PM   #350
Stu L Tissimus
When I brought it in, maybe 100. Yeah. I wasn't happy about that. I was scared to drive the thing because I didn't want to cause engine damage or something. Now it's at... I dunno, 350, 400?
1) It's a BRZ, not an FR-S
2) I brought it in to the dealer because the check engine light was unpredictable. It would turn on one day and off on others. Nonetheless I brought it in. New cars shouldn't be throwing off check engine lights.
3) The shuddering happened every once in a while. I informed the service guys of this (WITHOUT mentioning this thread at all - I just said that the RPM will go down all the way to 400 or so and then shoot up. Also mentioned that it happened most often after highway driving followed by a stop sign.)
4) I brought it in to the Subaru dealer. Sure enough the engine tech said said, yep, there's a problem and you're the second guy in north america with it, we're calling subaru HQ and getting it fixed for you
5) A couple days later it was fixed.
6)
A Small Easter Egg avusblue Scion FR-S / Toyota 86 GT86 General Forum 28 06-28-2012 11:38 PM
Subaru BRZ - The biggest small car ever Laika BRZ Photos, Videos, Wallpapers, Gallery Forum 7 06-09-2012 01:21 AM
Received my FR-S with a small ding Neurytic Scion FR-S / Toyota 86 GT86 General Forum 10 06-03-2012 12:53 PM
Isn't 6-10 miles on a new car kinda high? houseofsuffering BRZ First-Gen (2012+) — General Topics 45 05-15-2012 12:32 PM
Kinda make me worry! (Radiation related thing) EJ20 Off-Topic Lounge [WARNING: NO POLITICS] 32 05-09-2011 12:58 AM
