Old 11-09-2016, 07:51 PM   #57
BS in Mechanical Engineering from a public university that ranks well and typically gets called a 'Public Ivy'.
Somebody shortchanged you on your education.
I finished a semester of grade 11 and agree with your evaluation.
gramicci101 (11-09-2016), strat61caster (11-09-2016)
Old 11-09-2016, 08:06 PM   #58
justatroll
justatroll's Avatar
Drives: Full race 4cyl boxer
Originally Posted by DSLeach View Post
I'm not going to continue this discussion because you clearly don't have the necessary education to understand the physics of this subject.
I'll just leave this here:
"SURFACE VEHICLE STANDARD
SAE J1349
7.5 Power and Torque Determination
7.5.1 TEST PROCEDURE
This section defines the actual dynamometer test procedure used in obtaining Rated Net Power and Torque. The test shall consist of a run at full throttle for spark-ignited engines and at a fixed full-load fuel injection pump setting for CI engines. The following test controls and operating conditions must be adhered to meet the requirements of this standard:
7.5.2 TEST POINTS
Measurements shall be taken at increments of no more than 500 RPM in sequence from the lowest to the highest engine speeds recommended by the manufacturer. The operating speeds shall include those for peak power and peak torque. Data at 100 RPM increments around peak torque and peak power are recommended to accurately distinguish their respective rated speeds. Engine speed shall not deviate from the nominal set speed by more than ±1% or 5 RPM, whichever is greater.
7.5.3 LOGGING OF MEASUREMENTS
No data shall be taken until torque and speed measurements have remained stable within 1% and controlled temperatures have remained stable within ± 2 C for at least 1 minute. The recorded measurements shall be the average of readings over a span of 1 minute. Alternatively, data can be taken by stabilizing the torque and speed for 5 seconds and then acquiring data at a minimum 10 Hz rate for at least ten seconds. If this alternative procedure is used, the entire speed sweep shall be repeated at least three times. The results are considered valid if the repeatability of at least three measurements is within 1% of the mean."
That says that (according to the definitive authority on automotive testing) that torque measurements are to be done at constant RPM.
So someone please tell me how rotational inertia can affect to torque produced at constant RPM?
(hint I already told you above)
If it is such simple physics, it should be a simple answer right?
Arguing with an engineer is like wrestling with a Pig in the mud. You are never going to win and after a couple of hours you realize that he likes it.
justatroll is offline   Reply With Quote
The Following User Says Thank You to justatroll For This Useful Post:
Cole (11-09-2016)
Old 11-09-2016, 08:08 PM   #59
Lantana frs
Drives: 13 frs red
I had perrin pulley in 2013. Made the car feel livelier in lower gears. Coupled with a raised rev limit ate a crank bearing. For me, a good header and tune makes the car everything I could hope for.
Lantana frs is offline   Reply With Quote
Old 11-09-2016, 08:13 PM   #60
justatroll
justatroll's Avatar
Actually, I found a couple of good references for why rotating mass will affect your acceleration. The first a Tire Rack article on the benefits of lighter wheels and tires.
I never questioned that reducing mass and/or rotational inertia will give you faster acceleration.
I said it cannot make more hp
Or do you believe HP and acceleration are the same thing?
Tcoat (11-09-2016)
Old 11-09-2016, 08:25 PM   #61
........and THEN you got kicked off he short bus ...... ??
Cole (11-09-2016), Tcoat (11-09-2016)
Old 11-09-2016, 08:27 PM   #62
gramicci101
Off Topic
Back then it was a short carriage.
The Following User Says Thank You to gramicci101 For This Useful Post:
Tcoat (11-09-2016)
Old 11-09-2016, 08:36 PM   #63
No then I climbed on the short bus and joined the Army!
Cole (11-09-2016), gramicci101 (11-09-2016)
Old 11-09-2016, 08:41 PM   #64
........ so, then they took away your padded helmet and issued you a steel pot .... ??
Tcoat (11-09-2016), Ultramaroon (11-09-2016)
Old 11-09-2016, 08:45 PM   #65
With a fiberglass liner yes!
Old 11-09-2016, 08:58 PM   #66
It must have been difficult to lick the windows on the bus with that on your head .........
Old 11-09-2016, 09:00 PM   #67
No it was OK the officers showed us how. They had years of experience at it. The Captains seemed to be very proficient.
Cole (11-09-2016)
Old 11-09-2016, 09:29 PM   #68
Just how do you think they made captain ....... ??
Tcoat (11-09-2016)
Old 11-09-2016, 09:56 PM   #69
Show us your work so we can discuss. Show us how much of a difference your lightweight pulley will make given a simple mass model of the vehicle.
I'll even do you a solid. You may neglect internal frictional losses, rolling resistance and drag.
Cole (11-09-2016), soulreapersteve (11-10-2016), Tcoat (11-09-2016)
Old 11-09-2016, 10:05 PM   #70
Cole
Not a troll
Cole's Avatar
All these pulley debates remind me of the great physics question:
If you put an airplane on a treadmill that matches the wheel speed of the airplane perfectly so that no forward motion of the plane is achieved, will it take off?
Cole is offline   Reply With Quote
The Following 3 Users Say Thank You to Cole For This Useful Post:
soulreapersteve (11-10-2016), Tcoat (11-09-2016), Ultramaroon (11-09-2016)
Recommended cheaper power gains mods emishor86 Scion FR-S / Toyota 86 GT86 General Forum 38 03-27-2016 09:49 PM
POWER Mods for NA setup NYCsubaruBRZ Engine, Exhaust, Transmission 61 02-17-2016 10:19 AM
Mods to reduce drivetrain power loss? FRSW12 Engine, Exhaust, Transmission 31 12-28-2015 06:10 PM
Easy mods for power and sound. LWAA BRZ First-Gen (2012+) — General Topics 40 09-13-2015 10:20 PM
More Power VS. other Performance Mods Darryljr11 Mid-Atlantic 38 08-11-2013 09:53 PM
