Old 11-07-2016, 12:30 PM   #71
wbradley
Sarcastic SOB
wbradley's Avatar
Originally Posted by Norinradd View Post
I dont want to or plan to go any lower. I love my car how it sits now. Aside from neg rear cAmber.
Just so youre informed i wasnt eyeballing camber. It came back from alignment at -2.6 pass side and -.9 driver.
I thought id be ok with the trd coils aswell but i guess ordering some rear lcas are what i should do. I cant handle looking at one tire tucked under fender and one tire sticking out of fender. Looks so bad. Im sure it will effect performance too
I wont be running plates. And THANK YOU for understanding the word excentuate haha.
Youre saying i shouldnt buy new lcas?
If the two sides are way off as is, there is something that is bent that needs to be replaced. Rear LCA's are only a solution if the stock LCA is bent as you might as well go aftermarket then. Otherwise the damaged part needs to be addressed or the discrepancy otherwise explained.
Old 11-07-2016, 12:53 PM   #72
wparsons
wparsons's Avatar
First off. I dont get why were talking about the front struts. And youre not reading what i said!!! I said i CAN (not cant) see how bend in front strut would directly effect camber?!
It was brought up to explain the difference between the front and rear suspension, and why a bent shock won't cause what you're experiencing in the rear.
Im not saying the springs CAUSED it. Immsaying they EXCENTUATED it. As in with the car having LESS wheel gap. Its EASIER. To see camber variance.
Ding is on side with more negative camber.
I noticed before alignment
The word you're looking for is accentuated.
I'm a little surprised you can visibly see the difference in camber with your wheel specs, it's about a 1/4" difference side to side at the top of the tire.
Yes i tried the push and pull texhnique when i re did the rears yesterday seems maybe a bit better. Hard to say
Next time use a level app on your phone and measure before/after. Don't trust them as anything beyond relative measurements, but they'll be good at telling you if you got any benefit from the attempt.
I am ordering spc lcas and will be installin before i get another alignment. Also some whiteline bolts.
I searced on google for ft86 speed factory vendor as the search function in this forum is terrible.
The search function isn't terrible, you just have to know what to search for. There's also this very useful site called google that will find WAY more information for you.
I found ft86motorsports? Thats the candian vendor? 286$ shipped for lcas is really good!
That's the one.
Ill measure ride height after work
Make sure the car is on a really flat surface, both left to right and front to back.
Were you sitting in the car while it was being aligned? If not, it's not an accurate measurement for how the car is normally driven. Depending on your weight it could be off a few tenths of a degree.
There's no way the difference is that extreme from 1.5* unless there's another issue at play as well. Like I've said a few times, the difference at the top of the tire should be in the 1/4" range.
How much do you know about the previous history of the car? Any accident repairs at all?
If the subframe is shifted, it could cause more poke on one side even without the camber difference.
He's saying that the camber on a typical car from a ~1" drop doesn't really require any correction. If you want to keep the balance closer to stock, or want closer cross camber, then you'll need LCA's to correct it.
flickr
Norinradd (11-07-2016)
Old 11-07-2016, 05:20 PM   #73
Man i said i had a dent in running board on side with more camber and you acted like i was an idiot for not assuming that impact could have changed camber.
Then i agree with you and you act like im an idiot for agreeing with you.
What
The
Fuck. I swear ur juat trolling and enjoy getting ppl fired up like tcoat
Absolutely zero trolling nor fuckery from me. I am being as direct as I can.
I am reasonably certain that something on your suspension or your subframe is bent. Not shifted, bent.
A shift in the subframe would show up in both wheels. If we were to spend some quality time discussing the topic in general, you would benefit greatly from understanding the whole thing.
Your improved understanding and correct use of terminology would then enable you to figure out with reasonable certainty if, and how the suspension was damaged.
wparsons (11-07-2016)
Old 11-07-2016, 06:09 PM   #74
wparsons
wparsons's Avatar
I'd be willing to bet that the problem side is actually the side with -0.9*, not the side with -2.5. With a 1" drop I'm at -2.5*R and -2.6*L (with me in the driver's seat). Even with 1/4" less drop, it should be closer to -2.5* than 0.9*.
flickr
The Following 2 Users Say Thank You to wparsons For This Useful Post:
strat61caster (11-07-2016), Ultramaroon (11-07-2016)
Old 11-07-2016, 07:14 PM   #75
Norinradd
Drives: 2013 frs
Took the car to the only good alignment man i know in lowermainland here. Dialed in the rear to -1.7 and -2.0. Guys a wizard. Found some wiggle room within the bolts.
2013 silver frs, injen intake, agency power header, hks exhaust, no kitties, ecutek tune
Norinradd is offline   Reply With Quote
Old 11-07-2016, 07:24 PM   #76
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
That's an understatement, if he can consistently find 0.8/0.5 degrees of camber adjustment off of 'wiggle room' on an 86 he'd be a rich man.
People would legit fly him out across the continent to have him align the car if that's the case.
Glad to hear your car is all sorted now, wish we could know how it was off so badly but some mysteries remain unsolved.
ineedyourdiddly
The Following 3 Users Say Thank You to strat61caster For This Useful Post:
cjd (11-07-2016), Summerwolf (11-07-2016), Ultramaroon (11-07-2016)
Old 11-07-2016, 07:46 PM   #77
Yup. We haven't confirmed that the -0.9 side corresponds to the body damage. I had that on deck for OP but wasn't going to make any assumptions for fear of jumping to conclusions and taking shortcuts.
Anyhow, glad it's worked out.
Old 11-07-2016, 08:30 PM   #78
Norinradd
Drives: 2013 frs
I think the fountain tire that first did it must have made some mistakes.
The guy today who i wanted to bring it to saturday. His initial reading i think was 2.2 and 1.4. Somewhere round there. Not as off as the fountain tire job at 2.6 and .9.
So no lcas. Yay. And he says i have more than enough room for degree or two in the fromt.
Anyone familiar with grinding the front spring perches down? as i noticed they are the closest thing to the tire, not the spring itself. Have people done that? Any feedback?
Old 11-07-2016, 08:32 PM   #79
Norinradd
Drives: 2013 frs
Anybody know a good video or article explaining these macpherson struts and double wishbones
Old 11-07-2016, 09:02 PM   #80
wparsons
wparsons's Avatar
Don't, there's a lip on the edge to keep the spring seated properly. If you want more clearance there buy coilovers.
flickr
Old 11-07-2016, 09:06 PM   #81
Norinradd
Drives: 2013 frs
Nah inwas just wondering. I understand a spring seat. Haha. Just theres room there to be grinded out.
Btw what is the whole 16mm vs 14mm thing.
16mm whitelines allow for 1.5 degree like they advertise. Or do you need 14mm to get that much?!
14mm bolt in a 16mm hole sounds retarded to me. Just a show car with ridiculous camber
This is how camber affects toe in front. Also RCE camber plate info. Pat Suspension | Chassis | Brakes -- Sponsored by 949 Racing 17 05-04-2016 11:08 PM
Basic Noob Questions - Camber bolts/alignment/etc Rifle Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 10-28-2015 02:59 PM
*FREE alignment* with Purchase and install of Front Camber / SPL Rear Camber Arms! Corner3garage Southern California 188 04-24-2015 02:10 PM
*FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! Corner3garage Mechanical Maintenance and Tools 6 10-31-2013 04:40 PM
