Old 11-05-2016, 04:17 PM   #1
Norinradd
Drives: 2013 frs
Rear camber crazy from .75" drop
Installed trd lowering springs and dropped car off to be aligned. Got call back saying rear camber is at -2.5 and -.9. Tech saying he cant adjust rear in the green. Saying something about "slotting" something as an adjustable arm isnt possible. I apologize. I know solid axles in 4x4s. Not to familiar with these independent setups. I have no idea what to do. Whats my cheapest option?
2013 silver frs, injen intake, agency power header, hks exhaust, no kitties, ecutek tune
Norinradd is offline   Reply With Quote
Old 11-05-2016, 04:27 PM   #2
Norinradd
Drives: 2013 frs
I read over and over that the 1" drop coils. Trd eibach or any others you dont need to buy anything to adjust camber as its not big enough of a change in height to warrant extra parts. I soecifically bought these coils so i wouldnt have to mess with adjustable alignment stuff. Uhg
Old 11-05-2016, 04:55 PM   #3
churchx
churchx's Avatar
Drives: 2014 GT86
<1" "not warrant extra parts", as in miscellaneous roll center adjustment kits, diff riser, expensive coilovers and so on. But as car naturally gains negative camber, when lowered, basic camberbolts for front/rear LCA won't hurt to get right & better camber. I don't get though why difference is THAT big left to right in rear. Maybe some installation error, when installing those lowering spings? Car hasn't been in crash?
Bolts/LCA usually are still within reasonable budget (cheapest probably ~$250-300 new with spc bolts front, reusing oem crash bolts & SPC LCA), unlike what's needed if going for unreasonable drop, where spendings will be more then tenfold of that, at lest if you want for car to still handle well and be comfortable enough.
Old 11-05-2016, 04:58 PM   #4
Norinradd
Drives: 2013 frs
Old 11-05-2016, 05:04 PM   #5
Norinradd
Drives: 2013 frs
No installtion error. Everything fit back smooth and simply.
No accident.
Just recently did new wheels and tires and installed lowering spring.
Old 11-05-2016, 05:40 PM   #6
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Are you the original owner?
Just because there isn't a recorded accident doesn't mean it was never slid into a curb or something.
Old 11-05-2016, 05:50 PM   #7
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
1) are you 100% sure your springs properly installed?
2) are you 100% sure there's no accidents or bent suspension components on the car?
3) cheapest option is to slot rear lower control arm. next cheapest is SPC rear lower control arm.
-alex
The Following 2 Users Say Thank You to mav1178 For This Useful Post:
Norinradd (11-05-2016), TruRace (11-06-2016)
Old 11-05-2016, 05:56 PM   #8
Norinradd
Drives: 2013 frs
I am 100$ sure the springs were properly installed. I went step by step and everything installed easily. Springs are seated properly tophats as snug as can be. Bottom bolts are tight.
Theres no recorded accidents but a good ding on running board from previous. Possibly could have hit curb and bent strut
Old 11-05-2016, 05:58 PM   #9
Norinradd
Drives: 2013 frs
I hit about 5 million speed bumps driving into my complex and it doesnt make any clunks. But i do hear an odd clunk driving in random situations. Think im just hearing things. I dunno. Next time im leaving it stock. Lol
Old 11-05-2016, 06:23 PM   #10
Norinradd
Drives: 2013 frs
-alex
One thing that did sorta get me was when i removed two rear struts. I had to put then inside and walk to the store to buy some go through wrenches. I mixed up left and right side struts. I searched online for an hour and looked hard at both. I saw no Left or right markings. Visually they looked the same. So i assumed they were the same for left or right. As top hat can be placed at whatever angle.
Old 11-05-2016, 06:36 PM   #11
Norinradd
Drives: 2013 frs
Never mind. Phoned toyota. Asked them to search rear shock absorber. Theyre both the same for either side. No difference in part number
Old 11-05-2016, 07:17 PM   #12
churchx
churchx's Avatar
Drives: 2014 GT86
Same part number != correct, without any possible mistakes, installment. difference of almost two deg of camber per side .. my only versions are some error installing (springs on shocks, or whole shock assembly), or that such difference was already there (from some crash in past? But then again shouldn't such difference in alignment per side be detectable by "butt dyno" by abnormalities in car handling/stability? I somewhat doubt that servicemen that did installing & alignment took for test ride or dropped car from lift and bent during time car was left at shop) as lowering springs should affect toe/camber at similar pace on both sides.
Old 11-05-2016, 07:57 PM   #13
Norinradd
Drives: 2013 frs
Yah i dont know. Im confused. Car drives great. Always has. Still does.
Old 11-05-2016, 08:07 PM   #14
Norinradd
Drives: 2013 frs
But the shock assembly is simple. Open end of coil on bottom of shock. In its proper seat within 10mm. Closed end on top. Bolted up and done. Its as simple as rotating tires. So i take it as an insult questioning if the install was done correctly.
FS: New H&R TC112 Rear Camber Bolts, PAC 2.5" Helper Springs customfab87 Brakes, Suspension, Chassis 0 02-08-2016 11:41 PM
Fitment with -2 Camber and 1" Drop 18x9.5? ajcarson11 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 10-26-2015 02:29 PM
*FREE alignment* with Purchase and install of Front Camber / SPL Rear Camber Arms! Corner3garage Southern California 188 04-24-2015 02:10 PM
*FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! Corner3garage Mechanical Maintenance and Tools 6 10-31-2013 04:40 PM
