Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > Marketplace > Members Classifieds > Audio/Visual, Electronics, Infotainment, NAV
Old 10-28-2016, 01:43 AM   #1
customfab87
customfab87's Avatar
Drives: 2014 FR-S 6MT
Shorai Lithium Iron Battery w/ Terminal 21AH 3lbs LFX21L6-BS12 - $100
Super light weight (3lbs) Shorai lithium battery. Gently used in a daily driver in Southern California. Has 315CCA, so about 400 at room temperature. 21AH capacity is plenty to listen to the radio while working on the car. Behaves just like a normal lead-acid battery, but is 28lbs lighter!
Posts are already set up for a FR-S/BRZ. Added a battery post to the negative terminal, which cost another $10. I found that the positive terminal post doesn't fit as well. Instead just unbolt the cables from the terminal post clamp and bolt them directly to the battery. Red positive terminal cover fits on just fine. Battery tie-down works perfectly flipped upside down.
$100 + Shipping
customfab87 is offline   Reply With Quote
Old 10-29-2016, 12:01 PM   #2
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Please follow the Member Classified Rules (#2) or I'll delete the thread.
2. You must post AT LEAST ONE picture of the item(s) for sale with a sign included in the photo. On the sign, should be your username, date and the words FT86Club.com on it. It can be handwritten or printed on a piece of paper. No photoshopped signs will be accepted.
Thanks,
ichi
Old 11-02-2016, 02:41 AM   #3
customfab87
Sorry about that. Fixed. Price drop to $100.
Old 11-02-2016, 09:57 PM   #4
DCdesign2000
DCdesign2000's Avatar
Drives: Civic Hyb, RS6, BRZ SeriesBlue
Does the car need any modification or additional accessory to use this battery?
This is the quote from Shorai's website, " SHORAI LFX Lithium-Iron Powersports battery, 21Ah PbEq 12V eq, "L" polarity, Case Type 6 Length 5.83" Width 3.23" Height 5.51" Shorai Batteries require a charging system output of 13.1 Volts or higher at idle, and must not exceed 15.2 volts at maximum output."
DCdesign2000 is offline   Reply With Quote
3.6oz Carbon Fiber Battery Bracket for Shorai LFX21L6-BS12 Anthony Tracking / Autocross / HPDE / Drifting 5 04-02-2020 03:48 PM
KC Machine Tray and Shorai battery + Shorai Charger toeout Engine, Exhaust, Bolt-Ons 0 02-15-2015 06:34 PM
Shorai Lightweight Battery and KCMachine CNC Machined Battery Tray Package KCMachine Brakes, Suspension, Chassis 111 10-08-2014 09:26 AM
FS: New Shorai Lithium-Iron Lightweight Battery (LFX36L3-BS12) ft86Fan Interior Parts (Incl. Lighting) 0 06-11-2013 02:54 PM
Lithium Ion Battery Flat Black VW Scion FR-S / Toyota 86 GT86 General Forum 1 11-09-2012 03:23 PM
