#15 | |
Drives: Satin White BRZ Limited
Thanks for the suggestion, but I already installed energy poly bushings for front LCA. I probably should have gotten the whiteline bushings in the first place lol.
After your post, I went ahead and ordered a set of the STI bolts. I currently have energy poly steering rack bushings,but with the stock bolt. |
| The Following User Says Thank You to shattered_memory For This Useful Post: | nikitopo (10-25-2016) |
#16 |
Drives: 2013 SWP BRZ
I'm glad I ran into this thread. Last year I got RCE Yellows installed and noticed a huge difference in handling but that was to be expected. I think i noticed the lighter steering the most and i wasn't a huge fan of that. I went back and checked the alignment report and saw that the car had negative toe up front and I had asked to be dialed back to 0 degrees thinking any amount of toe wasn't good. This thread helped answer the question as to why the steering feels so light...not a bad thing but I also prefer just a tad more heavy-ness.
"Don't be a don'ter, do be a doer" - Johnny Wu
#17 |
Drives: frs
[QUOTE=shattered_memory;2783015]Thanks for the suggestion, but I already installed energy poly bushings for front LCA. I probably should have gotten the whiteline bushings in the first place lol
Easy to change, and not too expensive. You will get the results you're after.
| Subaru 216A confirmed with 2.0L turbo, AWD, bigger and heavier than FT-86 | Hachiroku | BRZ First-Gen (2012+) — General Topics | 118 | 11-16-2017 03:19 PM |
| [Power Steering/Electrical/Warranty] Problems, could use some advice. | Ajax969 | Issues | Warranty | Recalls / TSB | 7 | 07-26-2015 08:01 PM |
| How different is handling with heavier/rep wheels? | HachiRo | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 11 | 02-28-2015 11:19 AM |
| Swapping steering wheels with a new tC steering wheel. | jonathan9573 | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 12-21-2013 12:45 AM |
| Steering Feel Question Concerning Tic Solid Steering Bushings | brillo | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 15 | 10-31-2013 05:52 PM |
