Drives: 2016 Subaru BRZ
Took my car in for rough idle...
And the dealership said it was either bad gas or the car trying to save gas.
*eye roll* He said he didn't think there were any TSBs out for my car and to not worry about it. Jalopnik and three prior year TSBs disagree with him. |
#2 |
this is where you need to print out the TSB and shove in their asses..i mean faces so they can't say otherwise
| The Following User Says Thank You to FX86 For This Useful Post: | funwheeldrive (10-24-2016) |
#3 |
Drives: car
check the TSB / Recall thread: http://www.ft86club.com/forums/showt...=21868&page=22
#4 | |
Thanks, but I've already looked here a few times. Nothing for 16s yet. There's one for autos hard shifting, but not manuals. |
#5 |
Drives: 16 BRZ Limited CWP 82 Alfa Romeo
My 2016 runs rough every once in a while...maybe 1-2 a month...will be addressing it on the next oil change.
#6 |
Lowly Cartuber
Drives: 2016 BRZ, 2005 Honda S2000
Gah yeah i had this too last month. Ever since i went stage 2 though i havnt noticed it. I was freaking out becacuse the car was only 3 months old that point.
#7 | |
Have you changed sources of gas lately .. ?? humfrz |
#8 | |
Drives: '13 FRS - STX
Have you had any 'bad gas' in the last decade or two? |
| The Following User Says Thank You to strat61caster For This Useful Post: | Icecreamtruk (10-28-2016) |
#9 | |
![]() Back in my Miata (required premium) driving days (all over the MW and West), I've run across stations, out in the bush, that claimed to have hi-test gas. However, after seeing the spider webs and dust on the hi-test pump, I would pass and get just enough regular to get me back to civilization. Now, I'm not sayen that Bubba was pumping the hi-test out of a 55 gal barrel, 1/3 full of water, ....... I wasn't about to chance it. But, generally, these days, I would blame rough idle on an electrical (including ECU) problem rather than "bad gas". humfrz |
| The Following 2 Users Say Thank You to humfrz For This Useful Post: | radroach (10-27-2016), strat61caster (10-28-2016) |
#10 |
Drives: car
Yeah I agree it could have been bad gas. You don't know what you're getting when you're in Nowhere-Ville, how long their premium gas stock has been sitting. I'm not an expert on gas, but I generally avoid gas stations that wouldn't have a lot of customers buying premium.
But who knows what the newer ECU programming is. If it persists, I'd consider getting the car tuned and start monitoring stuff. To add, are you guys sure that it's not normal operation? Do you get a stumble or is it truly rough all the time? The stumbling idle is pretty much normal if you operate window switches and other electrics at idle. |
#11 | |
#12 | |
But what I'm seeing sometimes is a drop below 500rpms. About 3-4 times now, it's dropped low enough to make the engine miss a beat and come back. The rest of the time, it's still bad enough that you can feel the engine shaking through the car. I've had my car in twice now to tell my dealer about it. The first time, they said the car was just trying to save gas and run lean. The second time they hooked it to their scanner and couldn't find anything. And they didn't see any TSBs for the car, either. I have no power mods done to the car. Actually, this has been holding me back from doing anything to the car. As I don't completely trust it right now, I'd hate to throw some headers and a tune on it only to get a CEL later and have the dealer tell me I've voided my warranty. |
#13 | |
Drives: Track preped NA FRS
#14 |
Drives: 2013 satin white brz limited
| Turbo Rough Idle & Stall | BRZtoni | Forced Induction | 40 | 05-25-2016 06:28 PM |
| Rough Idle, Cel, Skid light... | Freeze2196 | Issues | Warranty | Recalls / TSB | 2 | 06-10-2015 12:58 AM |
| '14 BRZ Ltd. - Rough Idle | leicaboss | BRZ First-Gen (2012+) — General Topics | 20 | 05-22-2014 07:40 PM |
| Looks like CEL/Rough Idle is getting a lot more attention. | wawro569 | Scion FR-S / Toyota 86 GT86 General Forum | 11 | 10-06-2012 01:24 AM |
| Rough Idle & CEL *video | JiB | Issues | Warranty | Recalls / TSB | 5 | 10-04-2012 11:28 PM |
