Old 10-23-2016, 08:03 PM   #1
shattered_memory
Drives: Satin White BRZ Limited
Any advice on making steering heavier?
Does anyone have advice on making steering feel a bit more heavy? Are there any alignment settings or modifications that can do this? I have done several suspension mods to try and get a heavier steering feel. The mods have definitely improved overall handling, but have not helped in a more weighted steering feel. Below are my current suspension mods. I am looking into sway bars to see if this may help. Any suggestions will be greatly appreciated!
Current Suspension Mods:
Tein Flex Z (lowered 1.4 inch front/1 inch rear) 7/8 clicks from full stiff.
Grimmspeed Front strut bar
Energy Suspension Poly Front LCA bushings
Energy Suspension Poly steering rack bushings
17X9 +45 RPF1 w/ 245/40/17 Hankook RS3 (running 30 PSI cold all around)
Alignment Settings from the top of my head:
Front Camber: -1.5
Front Toe: 0
Front Caster: little over 6 degrees
Rear Camber: -.9
Rear Toe: Can't remember, but I know it is slight toe in.
shattered_memory is offline   Reply With Quote
Old 10-23-2016, 08:07 PM   #2
swarb
More camber.
Old 10-23-2016, 08:15 PM   #3
twag4
Drives: frs
Whiteline caster correcting bushings. KCA-434 is the part number.
twag4 is offline   Reply With Quote
The Following User Says Thank You to twag4 For This Useful Post:
shattered_memory (10-25-2016)
Old 10-23-2016, 08:19 PM   #4
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
Yeah up the caster a few degrees. I don't know exactly how much. But bear in mind, you'll be changing the front suspension geometry which will have effects on front end grip and you may end up over working the electric steering motor.
Changing caster is a fundamental change.
guybo is offline   Reply With Quote
Old 10-23-2016, 08:21 PM   #5
DAEMANO
Time Traveller
Wider tires, wheel spacers.
Old 10-23-2016, 08:42 PM   #6
Marat
Drives: '15 Ultramarine FR-S
Smaller steering wheel
Marat is offline   Reply With Quote
The Following User Says Thank You to Marat For This Useful Post:
SkAsphalt (10-24-2016)
Old 10-23-2016, 08:44 PM   #7
gramicci101
Off Topic
Air the tires out to 20 psi.
The Following User Says Thank You to gramicci101 For This Useful Post:
Old 10-23-2016, 09:44 PM   #8
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
remove the fuse for the electric steering.
why? is offline   Reply With Quote
The Following 3 Users Say Thank You to why? For This Useful Post:
bhmax (10-24-2016), Captain Snooze (10-24-2016), wparsons (10-24-2016)
Old 10-23-2016, 10:10 PM   #9
Tor
Tor's Avatar
Drives: Toyota GT86
Some of the other suggestion might help, but the most cost-effective would be slight toe-in at the front. It will make it stay in lane better too, but at the cost of turn-in.
Personally, I'll take a light feel (toe out) and good turn in over heavy steering feel.
With toe, we are talking miniscle differences with large effect. Try 0.05 inch deg toe-in instead of 0.
Tor is offline   Reply With Quote
The Following User Says Thank You to Tor For This Useful Post:
Old 10-24-2016, 05:26 PM   #10
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Go to a +35, or get 10mm spacers.
Cheap to try.
Old 10-24-2016, 05:37 PM   #11
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
There are some bigger steering bolts and you can change also the bushings. Image of bolts:
After installation it is definetly heavier, but after a few days you'll get used to it ...
The Following User Says Thank You to nikitopo For This Useful Post:
Old 10-24-2016, 06:51 PM   #12
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Drive a car with lighter steering for a few days and then swap back
FX86 (10-25-2016)
Old 10-24-2016, 07:04 PM   #13
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
50 pound wheels
Old 10-24-2016, 07:20 PM   #14
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Buy a tractor.
The Following 4 Users Say Thank You to Captain Snooze For This Useful Post:
churchx (10-25-2016), NissanGuy (10-25-2016), shattered_memory (10-25-2016), why? (10-24-2016)
Subaru 216A confirmed with 2.0L turbo, AWD, bigger and heavier than FT-86 Hachiroku BRZ First-Gen (2012+) — General Topics 118 11-16-2017 03:19 PM
[Power Steering/Electrical/Warranty] Problems, could use some advice. Ajax969 Issues | Warranty | Recalls / TSB 7 07-26-2015 08:01 PM
How different is handling with heavier/rep wheels? HachiRo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 02-28-2015 11:19 AM
Swapping steering wheels with a new tC steering wheel. jonathan9573 Cosmetic Modification (Interior/Exterior/Lighting) 4 12-21-2013 12:45 AM
Steering Feel Question Concerning Tic Solid Steering Bushings brillo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 10-31-2013 05:52 PM
