Old 10-23-2016, 07:41 PM   #799
alxtheoreo
alxtheoreo's Avatar
Originally Posted by MrFisty View Post
I actually did that.
Here's an update. When I put my original file back on my car, I read the ECU info to check the cal. It ended in A01C. Then, whilst downloading the new stuff, which I was simply re-downloading, I checked the cal via OFM. It read A00.
Now, I've put the stage 1 back on and I checked the cal through my tablet and ecu. Now, the read calibration on the car ends in B01C. Why is what OFT reads my ecu's calibration to be changing?
The latest maps from OFT are based off of the B01C file. Some of the .bins are interchangeable, hence why the default map works.
Sent from my SM-G930V using Tapatalk
Invidia catless FP & Q300. Enkei TS-10s. Conti ExtremeContact Sport tires. Hawk HPS pads. Centric Rotors.
alxtheoreo is offline   Reply With Quote
The Following User Says Thank You to alxtheoreo For This Useful Post:
MrFisty (10-23-2016)
Old 10-29-2016, 06:43 PM   #800
smbstyle
smbstyle's Avatar
Drives: 2013 SWP BRZ
So I've plugged my OFT into the computer for the first time in about 3 years, it did a bunch of automatic updates for a while, plugged it back into the car to do some logging and keep getting "please update template file", but do not see any updated template file on the OFT website, and the OFT manager is showing everything has been updated. Any help? Thx
2013 SWP BRZ
Build Thread: http://www.ft86club.com/forums/showthread.php?t=38781
smbstyle is offline   Reply With Quote
Old 10-29-2016, 07:38 PM   #801
Teseo
Drives: frs
Flash to stock tune and then flash to your current stage you was before update?
The Following User Says Thank You to Teseo For This Useful Post:
smbstyle (01-03-2017)
Old 10-29-2016, 08:36 PM   #802
TheMedakaBox
[EUROBEAT INTENSIFIES]
TheMedakaBox's Avatar
Drives: 2015 Scion FR-S Steel
Here you go bro.
http://www.ft86club.com/forums/showp...79&postcount=2
TheMedakaBox is offline   Reply With Quote
The Following User Says Thank You to TheMedakaBox For This Useful Post:
Old 11-01-2016, 11:18 PM   #803
Nah
Drives: 2013 Scion Frs 6mt
Random thought... what would happen if you interpolated the throttle tip in tables? and started it at 1% throttle delta vs the 4% you've displayed as an example
Thanks
Nah is offline   Reply With Quote
Old 11-02-2016, 02:22 AM   #804
steve99
Drives: FT86
Thanks
you might get bad economy as ecu would be adding fuel for extremly minpr throttle movement, like during highway cruise. you shoulnt have to resort to altering stuff like that to supress knock get the timing fueling correct, cam timing can also effect knock , and intake air temps.
Nah (11-02-2016)
Old 11-02-2016, 02:50 AM   #805
6-Shift
Señor Member
6-Shift's Avatar
Drives: 2013 Raven, Drifty things
Probably a stupid question, but is there a reason my throttle % only reads 96% under
full throttle according to pedal travel?
T O U G E - C U L T U R E
Follow me on instagram! :@tougeculture_chris
'13 FR-S, SBD Turbo kit, Tein Flex Z coils, other stuff. Drifting and autocross.
6-Shift is offline   Reply With Quote
Old 11-02-2016, 04:57 AM   #806
Kodename47
Kodename47's Avatar
Drives: UK GT86
It's just what it does.
.: Stealth 86 :.
Kodename 47 DJ:
Old 11-14-2016, 12:17 PM   #807
neilvosko
neilvosko's Avatar
Drives: Hyper Blue BRZ
just a quick question:
what would be the advantage/difference in stage 2 vs stage 1 for Catted UEL Headers, FP, ARK + drop in filter if my main goal is power/torque linearity and get rid of the torque dip ?
should i stay on stage 1 or is there an advatage (ie +25 hp tq) in stage 2 ?
thanks in advance
neilvosko is offline   Reply With Quote
Old 11-14-2016, 01:16 PM   #808
Nah
Stg 2 is optimized for the additional air flow your adding from your headers.
thanks in advance
Old 11-14-2016, 01:41 PM   #809
neilvosko
neilvosko's Avatar
well, that helps. catless or catted doesnt matter?
, aftermarket systems are 2.5"+ inner diameter while OEM is 2.125" so i guess even catted headers is Stage 2 ?
Old 11-14-2016, 01:48 PM   #810
Nah
It may matter with custom tuning... OTS id definitely go with the stg2.
Old 11-14-2016, 02:48 PM   #811
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
What was the solution to this?
Originally Posted by humfrz
I'm old and lazy
Old 11-14-2016, 03:56 PM   #812
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
catless only. A bigger diameter catted header still has a huge clog in it. Stage 2 is for catless setups only. What will end up happening is that the exhaust gas temps will run too high and you'll melt the cat.
guybo is offline   Reply With Quote
WTB: Open Flash Tablet TOZER Canada Classifieds 3 07-05-2015 08:13 PM
Open Flash Header & Open Flash Tablet Calavera Engine, Exhaust, Bolt-Ons 9 05-11-2015 09:27 PM
FS: open flash headers / open flash tablet - SOLD alanhung85 Canada Classifieds 12 02-10-2015 03:08 PM
FS: Open Flash Tablet (OFT) mex2309 Engine, Exhaust, Bolt-Ons 1 10-29-2014 03:49 PM
Open flash tablet. cooldandani Scion FR-S / Toyota 86 GT86 General Forum 1 02-22-2014 08:14 PM
