Old 10-20-2016, 10:44 AM   #57
Mach Midnight
MIDNIGHT
Mach Midnight's Avatar
Drives: MY16 Raven
Originally Posted by MeisterR View Post
Depend on what you want, we can certainly custom build something that are expensive.
You want to have gold color damper rod?
No problem... we can coat our damper rod in Titanium Nitrate for that bling gold look (done this before for a customer on special request).
You want to have full alloy body, 3-way suspension custom build to the car's exact specification and vehicle dynamics?
No problem, we have in house engineers available for all calculation.
You want to have every single seal custom CNC made for the specific damper?
We can make those in house.
You want to run 2 pistons inside the damper?
Doing that already with our GT1 coilovers.
You want to run 5 dampers on the car?
No problem... done that before also.
As for best, we can probably get right up there on a custom build and win championship.
But then "best" is subjective so it will depend on how you classify it.
The major concerns is always what is the budget and what is the goal.
The sky is the limit with suspension, it is using the right part effectively to give you the result you want that is more difficult.
Jerrick
Thank you for an epic reply to a very vague question
Mach Midnight is offline   Reply With Quote
Old 10-20-2016, 03:01 PM   #58
turtlefeeder
turtlefeeder's Avatar
Drives: UltraMFrS
Hmm from my experience with coilover a lower drop needs compensation to balance stiffness and performance. I'm currently on Tein street flex and I gotta say ride quality is like oem and my front fender closed the gap to my tires. However my rear is a whole finger higher fender to tire. I kind of do not like this for the looks but I really appreciate ride quality since I already tried Megan lowering spring and cheap coilover.
My next project will be getting ST XTA which I hear is about equivalent to KW V2 and the price is much cheaper. Also there are 2 separate springs one for high speed the other for lower speed which is ideal for spirited driving and daily cruise to work or to hang out. I feel the KW/ST will meet my need since it can drop lower than my Tein but can compensate for bad ride by having 2 springs on each shock. Maybe you should look into KW or ST XTA
None related. It's nice reading some of these comments and getting to know the market a bit better
turtlefeeder is offline   Reply With Quote
Old 10-20-2016, 03:12 PM   #59
Ashikabi
Ashikabi's Avatar
Why can't you drop your rear another 1/2 inch to even it up? Maxed out? Might consider an LCA like Stance's that offers a static drop without changing coil length length. They are kind of a shallow U shape do the mounting point for the damper is below the knuckle. There are other brands on the market also
Old 10-20-2016, 03:13 PM   #60
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Do you have a Swiss ex-watchmaker available to machine by hand all the necessary components?
CNC just doesn't have the same results as a true craftsman.
ineedyourdiddly
Old 10-20-2016, 03:19 PM   #61
strat61caster
You misunderstand what those are for. The small spring is very soft, maybe 50-60 lbs to fully compress it, it exists solely to keep the main spring in place when the suspension is unloaded, when on the ground that spring will be fully compressed.
That doesn't mean you shouldn't get them, it will likely do a pretty good job from what I hear. But, the more you know.
Here's there marketing material:
And here's a picture of what it will look like when sitting on the ground (this is a KW setup):
ineedyourdiddly
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
rcm47 (03-16-2017), turtlefeeder (10-20-2016)
Old 10-20-2016, 04:18 PM   #62
turtlefeeder
Drives: UltraMFrS
Thanks for pointing it out. It's still helpful for my plans to flush my fender with the tire, helps it not go lower under load
Old 10-20-2016, 06:13 PM   #63
bfrank1972
Drives: 2013 FR-S Argento
Que? The rear has more threads/room than the front, at least on mine when I had street flex. Also now have RCE T2's (based on KWs) and don't see a lot more drop-ability than the Teins I had. You should have room to remove the gap on your Teins as they are...
Old 10-20-2016, 11:52 PM   #64
MeisterR
MeisterR's Avatar
Drives: BNR32
Ah, when it comes down to CNC we do some odd things.
One reason why not many company offer CNC seals is because it is a VERY specialist field.
When a piece of polyurethane is in your hand, it is a solid.
However, when it is being spun in the CNC, it is expand because it isn't really solid.
So unless one know how to calculate the expansion rate for the specific seal you are making, you end result is all going to be wrong even if the program you put into CNC was correct.
We might not build Swiss watch, but I doubt any of those craftsman will have to calculate expansion rate like we can and have to.
Jerrick
MeisterR is offline   Reply With Quote
Old 10-21-2016, 01:05 AM   #65
turtlefeeder
Drives: UltraMFrS
Well I tried to lower hem more but they won't move and I went to auto shop they also said it won't go much lower neither
Old 10-21-2016, 04:07 AM   #66
MeisterR
MeisterR's Avatar
Drives: BNR32
Originally Posted by churchx View Post
5 dampers? What might be the usage case? :/
I'm curious about this too... I get six but an odd number is baffling me
It was used on a Pike Peak Ford RS200.
The suspension was design and made by our in house technical partner Black Art Design (BAD), who also engineered and produce our GT1 coilovers.
This Ford RS200 driven by Mark Rennison finished 4th place in the Unlimited Class at Pike Peak 2013.
The fastest privateer team, finishing behind 3 factory works team.
With the final time of 9:46.634, it is also one of 8 cars in the world to reach the top in under 10 minutes (Call the 9 Minutes Club) in 2013.
The 5th damper was used in the middle.
From my understanding, it basically works like an infinitely adjustable anti-roll bar.
I haven't got the full details of the suspension system as I only briefly over look the car's suspension, but it is certainly something that BAD can produce if necessary.
And I know the system works looking at the result the car posted.
Jerrick
Old 10-21-2016, 10:58 AM   #67
bfrank1972
Hmmm odd - I've attached a pic of what the Teins look like lowered/leveled to max, the fronts should max out first and the rears should have more threads (or so I thought!). You can see on the rears where I circled, if you see threads there, you can lower. The fronts are an example of where you have no more room to lower (you can't see threads). If you see threads on your rear, you should be able to loosen the lower collar, move it up and then rotate the body to lower the car.
Old 10-21-2016, 02:05 PM   #68
turtlefeeder
Drives: UltraMFrS
Yeah my front and rear looks like that picture but the rear won't go lower
Old 10-21-2016, 02:07 PM   #69
Ashikabi
Ashikabi's Avatar
Bad threads maybe?
Or the body bottomed out in the base/mount/bracket
Old 10-21-2016, 02:08 PM   #70
turtlefeeder
Drives: UltraMFrS
Bad threads maybe?
Idk but either way I still want to try out those st xta looks like they'll do a nice job😎
Coilovers Coilovers, Coilovers: Tein, KW, BC, D2, Cusco, Eibach + more FREE SHIPPING! No Limit Motorsport Brakes, Suspension, Chassis 204 05-26-2017 01:09 PM
Conflicted with TINT%! babylobster Cosmetic Modification (Interior/Exterior/Lighting) 75 06-06-2014 04:54 AM
* BC Racing BR Coilovers & Stance Super Sport Coilovers | IN STOCK | FAST SHIPPING * Speed Element Brakes, Suspension, Chassis 21 03-03-2014 09:56 PM
FS: (IL) KW Variant 3 coilovers and Stance Super Sport Coilovers ill roller Brakes, Suspension, Chassis 5 12-14-2013 04:02 PM
I'm conflicted FR-S now or BRZ later? Evil86 Scion FR-S / Toyota 86 GT86 General Forum 6 05-09-2012 08:45 PM
