Old 09-16-2016, 02:01 AM   #43
RJasonKlein
RJasonKlein's Avatar
Drives: 2013 Scion FR-S 10 Series
Originally Posted by mav1178 View Post
Ah I think it was wrong words used. The one we tested was very very good, great dyno chart after running for 30 minutes.
Thanks for the clarification - I stand corrected!
RJasonKlein is offline   Reply With Quote
Old 09-16-2016, 03:14 AM   #44
86TX
86TX's Avatar
Drives: 2016 FRS
Originally Posted by 86TX View Post
So I've been surfing the forums for thoughts on coilovers and from what I've seen, the best coils for a good price are the notorious BC racing or megan coilovers. I've found through digging and being nosy is that they make noise and aren't that great. I dont know if this is just the area they are in or bad driving etc, but I would rather see more recent coilover discussions that are after 2014.
I want a pretty good performance oriented coilover but also want some that drop me pretty low without bottoming out on the threads.
The roads here in north texas are pretty terrible but since i live in the suburbs i can easily avoid said roads.
Please bless me with yalls wisdom!
UPDATE: I've decided to get the Meister CRDs
Ive heard they are pretty good quality and a good ride, and they even have the ride height i want without bottoming out on threads, a friend of mine runs a setup for track and DD and he doesnt have noise or any problems do far with his Meister coils and hes had them for 15k miles
sounds good to me, thank you all for helping me out!
-Willus
86TX is offline   Reply With Quote
The Following User Says Thank You to 86TX For This Useful Post:
rcm47 (03-16-2017)
Old 09-16-2016, 03:16 AM   #45
86TX
86TX's Avatar
Drives: 2016 FRS
Originally Posted by MeisterR View Post
Here is what I have seen:
1. Cheaper suspension isn't all bad
You CAN make a good suspension within the $1000 mark.
You will have a few design limitation, but it is something that can be over come if you have the right experience.
Just because ONE suspension isn't great at that price range, it doesn't mean ALL suspension is bad at that price bracket.
2. NOT all suspension in the same price bracket are the same.
While some factory do make suspension for multiple brands, OEM supplier can make specific request because it is their unique product.
There will again be limitation as well as increase in production cost, but it is something many do all the time.
These specific request are cover under a non-disclosure agreement.
The details of one customers are not share with anyone else.
What that mean is even if it's the factory own product line, it will not have the specific request of an OEM supplier.
To "steal" the customer request and implement it in any other product is a direct breach of the non-disclosure agreement.
3. Expensive suspension doesn't always mean a better track suspension.
One of the very common questions I get ask is how well MeisterR suspension will work on track.
I get ask this a lot because customers who decide to track their car but purchase twin-tube suspension (Tein / Koni / GAZ / etc) have often experience fade near the end of the session.
That is when the damper get hot enough where the oil inside have change viscosity.
So the overall damper feel "softer", because the thinner oil is providing less resistance.
A good mono-tube damper such as MeisterR will handle a full track session without fade issue.
The mono-tube are able to deal with the heat generated from the damper.
This provide consistent performance during hard usage.
This is one point I try to stress because I seen it time and time again where twin-tube dampers just don't live up to hard track usage.
There are exception, but this is a general over view.
4. Coilovers DOES NOT have to be a hard ride
A common view is that coilovers aren't good for street car because they are design for track and will ride very stiff.
That is wrong as coilovers can be just as comfortable as any OEM dampers.
The difference between a stiff ride or a comfortable ride is how the suspension were designed.
The reason that this get pass around because alot of coilovers provider simply focus on "track use" on their product.
This mean customer buy their product, install onto their road car, and the ride is horrible no matter how you adjust the suspension.
It is always going to be a compromise.
You cannot have a suspension that will work well on a track car using slick tires, that will also do well on a tarmac rally stage.
But you can get a suspension that will work in a tarmac rally stage to work relatively well on the track.
It might not be as hardcore as a pure track setup, but it will work well enough as an all rounder.
That is how we generally valve our fast road suspension.
You want the suspension to do everything well, but you want the suspension to focus on it's main job.
That is to provide good ride quality and compliancy over uneven road surfaces, something we face 90% of the time when we are driving our car.
Hope that is a few point to help out members who are thinking about what to do.
Jerrick
thanks for this im gonna run the CRDs
Old 09-16-2016, 10:41 AM   #46
wparsons
wparsons's Avatar
Originally Posted by gled21 View Post
increased performance when spirited driving mainly, also to get rid of the wheel gap
Most people are far better off with a good set of springs (Swift sport, RCE yellows) than coilovers. If you aren't going to be fiddling with damping adjustments, get something like the ST's. Good price point, good performance.
flickr
Old 10-19-2016, 01:17 PM   #47
Mach Midnight
MIDNIGHT
Mach Midnight's Avatar
Drives: MY16 Raven
What are the most expensive/best currently available?
Mach Midnight is offline   Reply With Quote
Old 10-19-2016, 01:40 PM   #48
cjd
cjd's Avatar
Drives: 2017 BRZ
For what?
Most expensive is probably Penske 4-way adjustable...
Old 10-19-2016, 01:57 PM   #49
kch
Senior Misanthrope
kch's Avatar
Custom 4-way Penskes are the most expensive. Probably the best on track, but I can't provide proof of that.
http://counterspacegarage.com/produc...-frs-gt86.html
Other good choices for high-end suspension include these JRZs:
http://counterspacegarage.com/produc...o-brz-frs.html
Or the Tein SRC:
http://counterspacegarage.com/produc...c-brz-frs.html
But these are all overkill unless you're doing serious track driving.
Old 10-19-2016, 03:14 PM   #50
Mach Midnight
MIDNIGHT
Drives: MY16 Raven
Originally Posted by cjd View Post
For what?
Or the Tein SRC:
Thanks dudes. I know it's a really general question, just curious lol.
Old 10-19-2016, 03:36 PM   #51
churchx
churchx's Avatar
Drives: 2014 GT86
Tein SRCs from these listed should be of rather good price/performance. Yes, not THE best, but good enough, better then lot of other alternatives, and at 1/4 the price of penskes. Certainly not 4x worse then them
Old 10-19-2016, 04:52 PM   #52
Ashikabi
Ashikabi's Avatar
Only $12000? What a deal
Old 10-20-2016, 01:25 AM   #53
MeisterR
MeisterR's Avatar
Drives: BNR32
Depend on what you want, we can certainly custom build something that are expensive.
You want to have gold color damper rod?
No problem... we can coat our damper rod in Titanium Nitrate for that bling gold look (done this before for a customer on special request).
You want to have full alloy body, 3-way suspension custom build to the car's exact specification and vehicle dynamics?
No problem, we have in house engineers available for all calculation.
You want to have every single seal custom CNC made for the specific damper?
We can make those in house.
You want to run 2 pistons inside the damper?
Doing that already with our GT1 coilovers.
You want to run 5 dampers on the car?
No problem... done that before also.
As for best, we can probably get right up there on a custom build and win championship.
But then "best" is subjective so it will depend on how you classify it.
The major concerns is always what is the budget and what is the goal.
The sky is the limit with suspension, it is using the right part effectively to give you the result you want that is more difficult.
Jerrick
MeisterR is offline   Reply With Quote
Old 10-20-2016, 02:42 AM   #54
churchx
churchx's Avatar
Drives: 2014 GT86
5 dampers? What might be the usage case? :/
Old 10-20-2016, 09:12 AM   #55
Ashikabi
Ashikabi's Avatar
I'm curious about this too... I get six but an odd number is baffling me
Old 10-20-2016, 10:41 AM   #56
Racecomp Engineering
You could have a lot more than 4 dampers on a car. 4 corners + 2 for pitch + 2 for roll + 2 for ride.
- Andrew
Coilovers Coilovers, Coilovers: Tein, KW, BC, D2, Cusco, Eibach + more FREE SHIPPING! No Limit Motorsport Brakes, Suspension, Chassis 204 05-26-2017 01:09 PM
Conflicted with TINT%! babylobster Cosmetic Modification (Interior/Exterior/Lighting) 75 06-06-2014 04:54 AM
* BC Racing BR Coilovers & Stance Super Sport Coilovers | IN STOCK | FAST SHIPPING * Speed Element Brakes, Suspension, Chassis 21 03-03-2014 09:56 PM
FS: (IL) KW Variant 3 coilovers and Stance Super Sport Coilovers ill roller Brakes, Suspension, Chassis 5 12-14-2013 04:02 PM
I'm conflicted FR-S now or BRZ later? Evil86 Scion FR-S / Toyota 86 GT86 General Forum 6 05-09-2012 08:45 PM
