Old 10-16-2016, 02:07 AM   #1
Eazy-V
EcuTek Launch Control not working
I've had my car tuned with EcuTek and had Launch Control on map 2 working since June; however, after I got my redline hard fuel cutoff changed to soft fuel cutoff at 7200rpm (timing retard from 7200rpm, 7400 rev limit), the Launch Control no longer works.
I put my car in Map 2, 1st gear, clutch pressed then full throttle...it goes up to my preset of 4000rpm, but then slowly goes down to idle and stalls. My tuner took off the timing retard at 7200rpm, but issue still occurs.
My tuner is going to contact EcuTek, but anyone have any ideas?
Eazy-V is offline   Reply With Quote
Old 10-16-2016, 05:32 AM   #2
steve99
Drives: FT86
Did they adjust the target AFR for launch and Flat foot shift, if so get them to chage it back to default value 9.5 i think it a combined value for both features.
is the cruise stalk able to adjust the default launch setting ?
are they using latest race rom 9 patch ?
Old 10-17-2016, 01:52 PM   #3
Eazy-V
The cruise stalk seems to work, but once rpms reach the set limit it just goes down slowly until stall.
I'll see what AFR my tuner has set in tune.
Any other thoughts?
FBM Base Turbo Kit with GTX2867R and FlexFuel Kit with Walbro 485 / 550cc Injectors
EcuTek Tuned witih Greddy Profec @ 12PSI Shell 91-E73 and 18PSI E73
1993 Mazda MX6 N/A Fully Built on MegaSquirt (work in progress)
2023 Chevrolet Corvette Z51 Stock
Old 10-17-2016, 02:26 PM   #4
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Actually have something similar. First time trying. It was hit or miss whether it would even work or not. Some times it would just shoot to redline, some times it would activate launch control. The times it did activate launch control, it would either start raising the RPM slowly or would only activate for a couple seconds then go to redline. I only got 2 out of almost a dozen launch attempts that I was actually able to use. Both times the car fell on its face though.
Interesting to note I have had nothing but issues with Ecutek. Car ran great on OFT with Speed by Design Turbo kit. Once I loaded the Ecutek tune car ran like crap. Spent hours troubleshooting issues with my car to find nothing (Even paid a shop to look over the car for me to make sure I didn't miss anything) and the Tuner swears up and down that the tune is solid and not causing the issues. Before the winter tear down I might load back the OFT tune and see what happens.
Old 10-17-2016, 03:11 PM   #5
Cockatoo
TALLY FT86
Cockatoo's Avatar
Drives: 2014 FR-S Monogram -- SBD Turbo --
Did you ever try another tuner?
Cockatoo is offline   Reply With Quote
Old 10-17-2016, 03:23 PM   #6
Kodename47
Kodename47's Avatar
Drives: UK GT86
.... or load the OFT tune via ECUtek. I would be tempted to pass the OFT tune to the tuner and get him to base his tune from that.
To get launch control to work you have to be in neutral 1st, clutch not depressed. This is often overlooked. No idea why the revs would rise or fall. I suspect that it may be changed settings that cause this weird behaviour. There is little reason to change from the default config in ECUtek.
.: Stealth 86 :.
Kodename 47 DJ:
Old 10-18-2016, 02:21 AM   #7
Eazy-V
I tested it again today...same thing
It hits the rev limit then just drops until stalling; however, if I let go of the gas then I can prevent it from stalling, but it will just repeat the cycle.
The only thing the tuner changed was adding a timing retard at 7200 to prevent over revving to hit the hard fuel cutoff of 7400. We removed the timing retard and put hard cutoff at 7600, but still no launch control.
Old 10-18-2016, 03:30 AM   #8
Kodename47
Kodename47's Avatar
Drives: UK GT86
Have you tried logging it to see what's happening? Strange that it would suddenly start to do that, however it would be wise to get the data and get it over to the guys at ECUtek to see if there's a bug, setting or hardware issue.
.: Stealth 86 :.
Kodename 47 DJ:
Old 10-18-2016, 12:41 PM   #9
DustinS
DustinS's Avatar
Wasn't worth paying to get another tune at the time. Set-up was changing over winter pretty drastically and a new tuner most likely selected. Car runs decent on E85 (besides miserable MPG). So I just don't run pump gas.
Old 10-18-2016, 10:06 PM   #10
ztan
Drives: Toyota 86
Probably software related.
The LC implemenation that I have seen checks if clutch is depressed and speed in under a threshold. A value is then added to the RPM value which is checked against the fuel cut RPM value. I suspect that the conditions where you are at launch RPM has your ECU thinking that you are at peak RPM for some parts of the code and not for others and this is at the root of your issue.
ztan is offline   Reply With Quote
Old 10-29-2016, 10:13 PM   #11
Eazy-V
My tuner removed LC from all maps and re-added and still the same thing, so they are going to send the data logs to EcuTek to check.
Anyone know exactly how launch control works in terms of what the software actually is doing?
Old 10-30-2016, 11:30 PM   #12
COO86L
COO86L's Avatar
Drives: 2015 86 GTS + Mitsi Lancer GSR
Sad to hear you've had troubles. Who did you tune with for EcuTek?
If you want to shoot me a copy of your OFT tune I can change it to EcuTek properly for you when I have some spare time?
EcuTek VS OFT is just a tune file access system so essentially the same tune should run the same regardless of if you are using EcuTek, OFT, EcuFlash, brzEdit, RomRaider or any other system that will open edit and save out ROMs.
In regards to the LC issue, you say when you release the gas after it starts to die, it comes back to life and doesn't stall? That tells me it's an issue in the tune. Possibly when changing the fuel cut logic, your tuner has accidentally changed something OR forgot to change something back? Do you have a copy of the ROM file from BEFORE you asked for the change in fuel cut/rev limiter? Try flashing that on if you do. That will tell you 100% if it is in the new tune file or if it is the car itself (unlikely)
COO86L is offline   Reply With Quote
Old 06-11-2017, 09:31 PM   #13
Eazy-V
The tuner and I were able to get this resolved a few months ago. I noticed my rev limiter was behaving the same way as the LC limiter, so the tuner fixed the rev limiter to properly bounce which fixed the LC bounce.
Ecutek launch control puma Software Tuning 6 06-29-2015 04:55 PM
EcuTek RaceROM Launch Control just86 Software Tuning 47 03-14-2014 02:55 PM
ECUTEK Launch Control for AT transmission Kinaa Software Tuning 10 12-22-2013 01:45 AM
ECUTek Launch Control in Automatic 01s0uljah Software Tuning 2 08-12-2013 08:45 PM
Ecutek Launch Control test video NoFear99 BRZ Photos, Videos, Wallpapers, Gallery Forum 1 06-25-2013 08:53 PM
