Old 07-29-2016, 03:22 AM   #1
gMit
Drives: Pearl BRZ
Hella horn Subimods v2 harness install help
Hi all.
I have a pair of sharp tone hella horns as well as the Subimods v2 harness kit for Subaru. The people i bought it off said it will work fine and direct connect to my 2015 BRZ. http://www.carmodsaustralia.com.au/c.../view/id/8088/
I'm having some trouble figuring out where to connect the trigger wire from the harness to the BRZ. I feel like i may have found the connection in the low horn connector but honestly I'm confused. Would someone be able to chime in and help me out.
Cheers!
gMit is offline   Reply With Quote
Old 07-29-2016, 08:13 PM   #2
ryoma
ryoma's Avatar
[ame="https://www.youtube.com/watch?v=JYQE9sO-Lhc"]Subimods V2 Hella Horn Kit Installation 2015-2016 WRX / STI - YouTube[/ame]
go to the 3:30 mark. find the plug that looks like that and plug it in. the plug only goes in 1 way so I doubt you will get it wrong. the plug should be near the lower passenger side corner of the radiator if I recall correctly and also next to the temperature sensor.
I personally have not installed this harness, but I remember unplugging my horn down there when I was installing my oil cooler. it should be the plug you're looking for.
EDIT: the website you bought the harness from does not have the BRZ under the compatibility list. from the pictures, it seems as the harness you bought is different from the one Subie mods offers for the BRZ and 2015+ WRX since they both share the same horn plug (the compatibility for the harness you linked stops at 2014 WRX). this is the harness you want: https://subimods.com/subimods-v2-hel...m-h-hv2va.html
Old 10-10-2016, 01:23 PM   #3
BRZSteve
BRZSteve's Avatar
Drives: WRB BRZ
Originally Posted by gMit View Post
Hi all.
Cheers!
I'm actually having the same problem as you. I have the Grimmspeed Harness. Did the new harness work?
WRB BRZ
BRZSteve is offline   Reply With Quote
Old 10-10-2016, 02:01 PM   #4
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
A plug and play harness that isn't plug and play, brought to you by: SUBIMODS! The same group that told you to mount a non-sealed relay in the way of the elements. Typical. Cut that connector off, crimp on a spade, and insert it into the connector of the low horn.
Alternatively, return this harness and buy a few feet of wire and connectors from home depot. You don't need the relay. This has been proven time and again.
JazzleSAURUS is offline   Reply With Quote
Old 10-10-2016, 02:10 PM   #5
BRZSteve
BRZSteve's Avatar
Drives: WRB BRZ
Wow who would have thought that plug and play wasn't actually plug and play. I guess I'll just buy the wires and do it myself like you said.
WRB BRZ
Old 10-11-2016, 10:51 AM   #6
JazzleSAURUS
No worries!!
Find a ground, (you can use the lower horns mounting point,) put a ring terminal on it and run two leads from that ring terminal, one to each of your horns. Then, run spades one each from each of the stock horn trigger wires to the other terminal on the horn. If they don't do horn things, swap the terminals. I believe the horns are marked I can't recall.
The Following User Says Thank You to JazzleSAURUS For This Useful Post:
BRZSteve (10-12-2016)
Old 10-11-2016, 10:55 AM   #7
JazzleSAURUS
http://www.ft86club.com/forums/showp...1&postcount=89
In my post I had mentioned running a single spade, one to each horn. This works, fine, but technically my post above, (#6 in this very thread,) should give you a bit more redundancy.
Old 10-15-2016, 05:52 PM   #8
BRZSteve
BRZSteve's Avatar
Drives: WRB BRZ
Got the horns on and they work great! Although when I lock my car, it sounds like only one of the horns is working and is not as loud.
WRB BRZ
Old 10-17-2016, 10:27 AM   #9
JazzleSAURUS
Did you use one trigger from high and one from low, or split the trigger wire to each horn from one point?
I actually like having only one horn fire for locking, it makes it a distinct sound for that action!
Old 10-18-2016, 09:15 PM   #10
BRZSteve
BRZSteve's Avatar
Drives: WRB BRZ
Yes I'm pretty sure it's all wired correctly. The sound is kind of growing on me actually.
WRB BRZ
The Following User Says Thank You to BRZSteve For This Useful Post:
JazzleSAURUS (10-19-2016)
WTB: cruise control/horn harness bryzter Want-To-Buy Requests 1 04-04-2016 02:23 PM
Sold: 2x Cipher Racing Harness Set 4 Point 2 Inch and Harness Bar siuhen Interior Parts (Incl. Lighting) 12 12-27-2014 10:38 AM
AgencyPower Harness Bar Install | Video vividracing DIY (Do-It-Yourself) Guides 0 09-30-2014 09:51 PM
Need help w/ FRS radio install / harness info varun Electronics | Audio | NAV | Infotainment 6 02-19-2014 10:40 PM
Anyone manage to succesfuly install the DDM HID wiring harness in their car? wawro569 Cosmetic Modification (Interior/Exterior/Lighting) 5 09-26-2012 12:02 AM
