Old 10-02-2016, 04:36 PM   #1
ajcarson11
Drives: 2013 Subaru BRZ Limited (Black)
Preparing for age of BRZ... Rust risk?
Having an intention of keeping my car for a long time, and having just recently had rust pop up all over my very-well-cared-for (but 21 year old) truck, I'm beginning to wonder if/when we will have to deal with rust issues on the twins.
I wonder if there are particular places which may rust first, and will need preventative care?
I live in Indiana where they salt the roads heavily every winter. Simply no way around this, short of completely avoiding driving of the car until things warm up again (and sometimes there is still salt on the roads for weeks after it getting warm).
I know that newer cars these days are treated for rust -- but our cars are nearing the 6 year mark (if you have a 2012/2013 model) and I think this is worth a thought!
ajcarson11 is offline   Reply With Quote
Old 10-02-2016, 04:49 PM   #2
They will. The stamped parts are reasonably priced. I feel the fasteners are the things to watch.
For instance, the shoulder screws that fasten the top of the bumper are prone to contamination and rust. I'm sure there are many places that could be addressed for periodic inspection and cleaning.
Another one which comes to mind is the cavity above the rear light fixture.
Luftwaffel (10-02-2016)
Old 10-02-2016, 04:52 PM   #3
The upper ball joint of the front endlinks.
Alternatively, you could resolve to only disconnect them from the sway bar.
Old 10-02-2016, 06:03 PM   #4
Luftwaffel
Boost Creep
Luftwaffel's Avatar
Drives: 2016 HyperBlue BRZ
Agreed. Our fasteners are garbage. Almost all of them, with few exceptions.
SBD400X Turbocharged 2016 Series.HyperBlue BRZ
Luftwaffel is offline   Reply With Quote
Old 10-02-2016, 06:23 PM   #5
I wouldn't go so far as to say they're garbage. They are adequately specified for a reasonably priced sports car.
There's also the idea of replacing the OEM fasteners with more corrosion resistant aftermarket ones. Better finishes cost money.
Do not assume that if a grade-5 was specified, a grade-8 is better. Consider which you would like to fail first if over-torqued. Should it be the bolt, or the weld nut on that fifty-dollar bracket.
Old 10-02-2016, 06:53 PM   #6
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
Salt? What's that?
Stang70Fastback is offline   Reply With Quote
The Following 12 Users Say Thank You to Stang70Fastback For This Useful Post:
ajcarson11 (10-03-2016), Eighty 6 (10-03-2016), Fastbrew (10-04-2016), JDM4E (10-02-2016), Lynxis (10-03-2016), MasonL1997 (10-02-2016), one2onejackpot (10-03-2016), soulreapersteve (10-03-2016), Tcoat (10-02-2016), ToySub1946 (10-02-2016), Ultramaroon (10-03-2016), why? (10-02-2016)
Old 10-02-2016, 10:38 PM   #7
ToySub1946
ToySub1946's Avatar
Drives: 15FRS, 05MustangGT, 85Toyota truck
Move to just anywhere they don't put salt on the roads.
Doing anything else is a waste of time.
Hopeless to attempt to keep ahead of salt damage...been there, tried that.
The newer car bodies hold up quite well, it's all the things attached to underside of car which rot, and quite quickly.
Make enough money to replace car every two years....your best option if you must stay in salted street climate.
I grew up in salt country, moved away from it for about thirty years, made the mistake of moving back for about five years. Relearned my lesson. Now I'm out of salt country for good. Few car repairs and in a warmer climate utility bills are way less. Just makes sense to me.
If I were the president, I'd outlaw salt on roads, require four snow tires on all vehicles being driven in snow/ice.
ToySub1946 is offline   Reply With Quote
The Following User Says Thank You to ToySub1946 For This Useful Post:
Old 10-02-2016, 10:56 PM   #8
Takumi788
JHerbert Racing
Takumi788's Avatar
Drives: 2013 Scion FRS
Anti-seize all the hardware as you replace things
- #813 2013 Scion FRS Build Thread
- JHerbert Racing Website
Takumi788 is offline   Reply With Quote
The Following User Says Thank You to Takumi788 For This Useful Post:
Ultramaroon (10-02-2016)
Old 10-02-2016, 11:33 PM   #9
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
sand is almost as bad. And seriously if you wash the underside of the car weekly it should be fine. But every manufacturer and vehicle is different.
why? is offline   Reply With Quote
Old 10-03-2016, 12:52 AM   #10
Stang70Fastback
A.K.A. Starlord
I had a 1998 Subaru Outback that had 286,000 miles, and 16 salt-covered winters on it. Did it have rust? Sure. Was it falling apart the way ToySub1946 makes it sound like it should have? No. We washed it often enough that this wasn't an issue.
I've had my BRZ through two salt-covered winters so far, as seen above. Here is the underside after those two winters:
The Following User Says Thank You to Stang70Fastback For This Useful Post:
Old 10-03-2016, 01:26 AM   #11
ajcarson11
I would absolutely love to move elsewhere. I've complained about the salted roads for years. Unfortunately that isn't in the cards for a while, despite my wishes. I just need to invest in a lift and then I can power wash the underbody all the time..
The Following User Says Thank You to ajcarson11 For This Useful Post:
ToySub1946 (10-03-2016)
Old 10-03-2016, 09:08 AM   #12
ajcarson11
Originally Posted by Stang70Fastback View Post
Salt? What's that?
This looks remarkably similar to the DIY wash we have here in Muncie, IN...
Enough so, that i've stared at the picture for several minutes now. I'm sure they all look the same.. but dang..
Old 10-03-2016, 11:12 AM   #13
Stang70Fastback
A.K.A. Starlord
Haha, this was in Schaumburg, Illinois. A car wash called Busy Bee. Not too far from IN, tho :P
Old 10-03-2016, 12:18 PM   #14
JD001
JD001's Avatar
Drives: Subaru BRZ
My all time pet hate (driving related) is coming across a gritting truck spraying salt onto the roads before the anticipated snow fall! The salt/grit is scattered at such force that I fear for my car's paint finish..
The Following 2 Users Say Thank You to JD001 For This Useful Post:
ajcarson11 (10-03-2016), Ultramaroon (10-03-2016)
What should I do to my car in preparing for a supercharger? djdrugga24 Forced Induction 26 02-21-2016 01:18 PM
Preparing for winter! Elliryx Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 17 09-03-2015 10:14 AM
Preparing for a road trip nickw14 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 11 05-07-2015 01:42 PM
EcuTek preparing to release PRO ECU software for BRZ Visconti Engine, Exhaust, Transmission 335 08-14-2012 12:34 AM
