Old 09-26-2016, 04:39 PM   #113
jcw99
Drives: swp mt '14 brz premium
Originally Posted by brandonblt2 View Post
So I learned to drive manual on this car and I'm actually pretty smooth rowing the gears after putting 70k miles on the car. Would it be worth taking out the spring if I can already shift smoothly?
I would say if you can consistently take off smoothly from red lights on steep hills you're not having trouble 'finding' the engagement point and don't need to remove the spring. You mentioned that your shifts are smooth, so you've got that part licked already.
jcw99 is offline   Reply With Quote
The Following User Says Thank You to jcw99 For This Useful Post:
brandonblt2 (09-27-2016)
Old 09-30-2016, 01:15 AM   #114
iNcontroL
Drives: 2014 Scion FR-S Monogram (Whiteout)
Say... Hypothetically, someone had somehow dropped the e-clip into the opening near the driver side and needed a new one. Where we he/she be able to purchase one?
iNcontroL is offline   Reply With Quote
Old 09-30-2016, 01:42 AM   #115
darko
Drives: RAVEN FRS
http://lmgtfy.com/?q=E-Clips+Scion+Ebay
darko is offline   Reply With Quote
Old 09-30-2016, 04:42 AM   #116
iNcontroL
Originally Posted by darko View Post
All that brings up is a bunch of RC Model E Clips
Old 09-30-2016, 02:06 PM   #117
darko
Drives: RAVEN FRS
http://www.homedepot.com/p/Everbilt-...iyIMbg&cj=true
The Following User Says Thank You to darko For This Useful Post:
trvth (05-02-2017)
Old 10-01-2016, 12:50 AM   #118
2ZZW30
Drives: 2000 Toyota MR2 Spyder
Kind of like beating a dead horse now but deleting this assist spring is the single best thing I've done to my car. This is how the clutch should have felt all along. I was skeptical that it could have made that much of a difference but WOW.
2ZZW30 is offline   Reply With Quote
The Following 2 Users Say Thank You to 2ZZW30 For This Useful Post:
funwheeldrive (01-11-2017), xxBrun0xx (10-02-2016)
Old 10-01-2016, 10:37 AM   #119
jcw99
It's too bad the car doesn't have a switch for the clutch spring like it does for the traction stuff--we could all put a paperweight on the button and get on with the program.
SLVRSRFR (10-01-2016)
Old 10-16-2016, 02:29 PM   #120
marcom
Drives: toyota 86
help guys, i was able to remove the e-clip and pin. but i could not move the clevis and remove the springs. took me 2 hours today and i really cant take it off.
marcom is offline   Reply With Quote
Old 10-16-2016, 05:02 PM   #121
jcw99
push the clutch in all the way with your left hand--take a long screwdriver and find a spot down there to use as a fulcrum and apply a lot of pressure with the end of the screwdriver on the upper side of the spring--it's hard and then it's all over with when it finally moves
Old 10-19-2016, 11:37 AM   #122
marcom
Drives: toyota 86
got it out today. just took me 5mins. thanks for the advice
The Following User Says Thank You to marcom For This Useful Post:
jcw99 (10-19-2016)
Old 01-29-2017, 01:21 AM   #123
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
I've been wanting to try this mod for a while and I finally got around to it today. I have to say so far I'm really liking the change. It does make the clutch stiffer, but it's definitely still tolerable. Just takes a little while to adjust to the change.
The hardest part of the whole process for me was getting that stupid E clip out. I kept trying to push it out with needle nose pliers, but couldn't get it. Finally I was able to get both sides of the pliers positioned right and pushed really hard and the clip went flying off. Ended up busting my knuckles pretty good in the process.
After that I hammer the clevis bolt a little with the handle of my screwdriver and then pried it out when there was enough space to get the flathead in there. Finally I just pushed the clutch pedal all the way to the floor and pulled the spring assembly toward me until it finally came out. Like a lot of people, I just put the spare parts in a ziploc bag.
I think this spring delete is really going to do a lot to improve the clutch feel. I've been driving my FRS for over 3 years and was never real happy with the clutch. Always seemed like way too much travel and way to vague feeling. Now I've just got to get the pedal height exactly where I want it. Currently it's even with the brake pedal, but I may tinker with it a bit more.
smg1138 is offline   Reply With Quote
Old 01-29-2017, 05:41 PM   #124
funwheeldrive
Doesn't the added play in the peddle bug you guys? I've been considering this for a while, but I don't think I would be able deal with the added looseness.
Old 01-29-2017, 07:13 PM   #125
smg1138
smg1138's Avatar
With my pedal lowered, I only have a tiny bit of play. It doesn't really bother me though. I think at stock height it's probably worse though.
Old 01-29-2017, 07:19 PM   #126
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
I have never even noticed- stock height. Is this even a thing because I have just never even felt it.
guybo is offline   Reply With Quote
Clutch return spring removal MikeyBRZ Engine, Exhaust, Transmission 186 09-16-2020 01:40 PM
How To: Clutch Spring Removal in 15 Minutes eric6 DIY (Do-It-Yourself) Guides 165 02-15-2017 12:44 AM
FS: MTEC Shifter Spring Kit + Clutch Spring Kit BRAND NEW $59 shipped susko Transmission and Driveline 2 01-21-2016 04:42 AM
Clutch spring removal Sandy AUSTRALIA 4 07-22-2015 11:14 PM
Clutch Spring Removal & Throwout Bearing DemonRawr Issues | Warranty | Recalls / TSB 2 05-13-2015 09:08 PM
