| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
Drives: 2014 Subaru BRZ
Slightly Stretched Tires Concern
Hello!
I'll admit: I'm still new to this whole car modification game and I have absolutely no idea what the heck I am doing. My current situation is this: I am about to purchase some 17x9 35 Rpf1s. However, I currently have the stock tire size. I don't want to purchase new tires since I have only put maybe 5, 10k miles on these tires. I want to use these tires up until I indeed do need new tires, but if I do that I'll be riding on a stretched wheel until then. My question is this: If I stay with the stock size until these tires are used up and ready to replace, will the handling of the car be a huge issue? As far as how I drive it, it is a daily driver, but I live in the mountains currently and love to go fast up and down these mountain roads. |
#2 |
Drives: Toyobaruion
You'll be fine. Keep an eye on the tire pressures. Extremely stretched tires can unbead if theres a low pressure (think in terms of why offroaders use bead-lock wheels). You'll have a slightly stiffer sidewall feel compared to a narrower wheel with same tire; that's about it. Drift cars beat the hell out of their tires and a lot of them run some sort of stretch for the stiff sidewall reasoning.
Also, no, your car won't magically explode into a big ball of fire and you die a tragic death. So, INB4 all the crazy people who think like that. |
#3 |
Shibby!
Drives: '14 White FR-S, '01 turbo mini taco
OEM tires from a 7" wheel to a 9" wheel is more than just a "little" stretched. And yes, tire wear and performance will be noticeably affected, but it will not explode
| The Following 2 Users Say Thank You to Toyarzee For This Useful Post: | Cole (09-29-2016), Summerwolf (09-29-2016) |
#4 |
Drives: Toyobaruion
#5 |
Not Bаnned Anymore
Drives: Heavily Modified FRS
.... Ball of fire.... crazy death... reference to goats..... "hella flush".... you will be fine....
there I about summed up the thread in advance
| The Following User Says Thank You to go_a_way1 For This Useful Post: | Toyarzee (09-29-2016) |
#6 |
Drives: Track preped NA FRS
What @c4lvinnn is about right. Just want to say that 215 on 9" is not a slight stretch, its a big stretch, probably as big as there can be. They are already stretched quite a bit at 8" wheels, imagine what an extra inch will do to that. Go ahead and do it, just keep an eye on tire pressure frequently and beware of temperature drops (pressure is lower with colder air).
#7 |
Shibby!
#8 |
Drives: Toyobaruion
#9 |
Drives: 2013 BRZ Limited
I'd expect high shoulder wear. Have to increase pressure to keep tread flat.
#10 |
Drives: Toyobaruion
#11 |
Shibby!
Ok please explain. This is hellaflush type stretch here which others have already +1'ed. And yes, if you have to babysit the tire like that, then its performance has been compromised. Will it work? Yes. Would I trust this setup for the long haul? Nope.
No yourself lol |
| The Following 3 Users Say Thank You to Toyarzee For This Useful Post: |
#12 |
#FiftyShadesOfBlue
Drives: 2015 FR-S
Let me offer a couple options/play devil's advocate
1: keep the stock tires on the stock wheels and keep them on the car until the tires are worn down. After these are done buy tires that properly fit the wheels you bought and then go on your way without worrying about stretching the tires or monitoring your tire PSI all the time. 2: Buy new wider tires for your new wheels now and keep your stock wheels/tires as a back up set. Notice how both of these suggestions solve the stretched tire problem
Engine/Exhaust: OFT w/ E85 Tune | FT86SF Catted UEL | Invidia Q300 Catback
Wheels/Tires/Suspension: Avid.1 AV-20 18x8.5 +33 w/ 245/35/18 PSS | RCE Yellow Springs | Velox LCAs Cosmetic: Valenti FT86SF Special Edition Tails | Diode Dynamics Full HID/LEDs | BRZ Fender Garnishes ![]() |
#13 | |
Not Bаnned Anymore
I 100% agree. Its like having the choice between a horse and a goat for a race and choosing the goat. It puts your performance at a disadvantage for no necessary reason |
| The Following User Says Thank You to go_a_way1 For This Useful Post: | Shark_Bait88 (09-29-2016) |
#14 |
Country Boy 4 Life
| Slightly stretched tires = stiffer sidewalls? | ayau | Tracking / Autocross / HPDE / Drifting | 27 | 07-20-2016 04:17 PM |
| stretched stock frs tires on aftermarket wheels | JarredH | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 42 | 01-27-2016 08:18 PM |
| Pilot Super Sports Look Stretched? | luuser75 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 8 | 10-22-2014 02:15 AM |
| can we get a slammed and stretched subforum? | fatoni | Site Announcements / Questions / Issues | 17 | 05-22-2014 05:52 PM |
| Oil slightly overfilled on last oil change any concern? | wbradley | Issues | Warranty | Recalls / TSB | 7 | 12-22-2013 11:01 AM |
