go_a_way1
Old 09-27-2016, 08:44 AM   #3697
axelthrasher
Drives: BRZ, 2 WRXs, 818S, motorcycles, etc
Originally Posted by phanguy View Post
Been battling my install since almost the beginning (August of last year). Continue to get the issue a lot of people have which is the CEL P0172. I've done everything I've found in this thread. Make sure the connection isn't too close to the alternator, clean the MAF, make sure the MAF is as vertical as possible. Checked all connections and everything is tight. I continue to get the CEL. Sometimes I'll get it within weeks, sometimes days. When everything is working it is such a joy to drive, but when it isn't working...
I just put in an order to CSG for a new air filter since mine is a little beat up(my kit is second hand) so I'm really hoping that will fix the issue. Otherwise I'm going to look into using the delicious tune with MAP sensor instead. Prefer to drive stock carb, but even more important is driving something reliable. I don't track and don't drive super hard all the time. I just want it working reliably. I'll report back one way or the other if the replacement filter works.
Not sure what other symptoms you may be having, but check my post here: http://www.ft86club.com/forums/showt...23#post2445223
My issues were caused by a MAF extension harness that had wires pulling out from the connector. This was something that I believe was a manufacturing issue (in regards to the harness). Once I replaced the MAF extension harness - all my issues went away. This was a regular issue for me and I just thought it was a nuance at first. Then all of a sudden the car died and it seemed to get worse so I knew it was something faulty.
axelthrasher is offline   Reply With Quote
The Following User Says Thank You to axelthrasher For This Useful Post:
phanguy (09-27-2016)
Old 09-27-2016, 12:31 PM   #3698
phanguy
phanguy's Avatar
Drives: Scion FR-S Ultramarine
where did you get a replacement extension?
phanguy is offline   Reply With Quote
Old 09-27-2016, 01:58 PM   #3699
CSG Mike
CSG Mike's Avatar
You can order from @CounterSpace Garage or directly from @Jackson Racing.
Old 09-27-2016, 02:03 PM   #3700
phanguy
phanguy's Avatar
damn it and after i just bought a new air filter from you guys... could have saved on shipping!
i couldn't find it on the site. where should i be looking?
Old 09-27-2016, 02:56 PM   #3701
CSG Mike
CSG Mike's Avatar
PM directly!
Old 09-27-2016, 02:59 PM   #3702
phanguy
phanguy's Avatar
PM directly!
sent! and big thanks to you guys for continuing to be rock stars to our community!
Old 09-27-2016, 04:45 PM   #3703
axelthrasher
I recommend inspecting yours first - not saying you will 100% be able to see the wires pulling out from the harness plug, but you will see the red insulators appearing to be different lengths coming out of the plug. I HIGHLY suggest playing around with this to see if this is where your issue is coming from.
Old 09-27-2016, 05:26 PM   #3704
phanguy
phanguy's Avatar
i already ordered it, but this is good to note. this and the air filter are the only two things left i can possibly think of as being the issue anyway. and at least this way i am replacing both with the official part so i can hopefully get help from csg or jackson if it still doesn't work afterwards.
Old 10-03-2016, 04:07 PM   #3705
Ak1m0to
G20 Guru
Ak1m0to's Avatar
Drives: Infiniti G20 / FRS
Send a message via AIM to Ak1m0to
I had similar issues with mine and ended up getting Moto-East to send me a SD (Speed Density) tune. Up to this point, the car was running fine until the SC went out on me. It's currently with Rotrex/Jackson Racing getting looked at. I don't track my car either and don't drive it hard. It's my daily that I drive to and from work with the occasional cruise. I just want to be able to enjoy the car. I hope this helps you.
Slowmatic Drfiterz, from P to D in a heartbeat.
Ak1m0to is offline   Reply With Quote
The Following User Says Thank You to Ak1m0to For This Useful Post:
phanguy (10-03-2016)
Old 10-03-2016, 04:41 PM   #3706
phanguy
phanguy's Avatar
were you on carb tune?
i currently have the new filter in and after a few CELs(different from what i was getting before) from not having tightened a tube it's fine for the last day or so, but like i said my issue is pretty intermittent so i won't call this case closed for awhile. i have the new maf extension waiting for install too. i want to be 100% certain that the new filter either does or doesn't make a difference so i won't install the extension until i get another p0172.
Old 10-10-2016, 05:24 AM   #3707
RevoG
RevoG's Avatar
Drives: Hot Lava 86 MT
Got a quick question for everyone running the JR SC setup: Anyone ever had any problems with the pulleys supplied in the kit? I just replaced both pulleys as the bearings inside were shot. If you shake the pulley you can hear them running loose inside. I replaced them since they looked to wobble when the car is running.
JR Supercharger, JR RS Pulley, JR Oil cooler, JDL UEL header, Dual resonated 3" JDL Overpipe Front pipe, Perrin 3" resonated cat back exhaust, Upgraded Koyorad radiator, ECUTek tune, Enkei RS05RR 18x9.5, Bridgestone RE003 265/35/18, KW V3 Coilovers, Valenti sequential taillights, Kartboy short shifter kit
RevoG is offline   Reply With Quote
Old 10-11-2016, 10:51 PM   #3708
dp1
driving smoother faster
Drives: Sold
AEM air filter wrap that fits 6.5"x5" Jackson Racing C38 kit air filters (http://www.ft86club.com/forums/showp...6&postcount=69)
dp1 is offline   Reply With Quote
The Following User Says Thank You to dp1 For This Useful Post:
Bramick (10-24-2016)
Old 10-12-2016, 02:59 AM   #3709
CSG Mike
CSG Mike's Avatar
Make sure your belt is properly aligned; a mis-aligned belt can put abnormal stress on the pulleys.
Old 10-17-2016, 04:50 PM   #3710
hamlet
Drives: blue brz, silver R8 5.2, orange s2K
Another update on my system too rich code:
The code kept coming back so we pulled off the exhaust manifold and it turns out the precat is mostly toast and the O2 sensor is completely fried.
I could have replaced the exhaust manifold but I thought it was only a matter of time before the problem recurred so I had to replace the exhaust manifold with a header (so I'm technically no longer carb legal) and replaced the o2 senser. Everything seems to be running better now and no code yet. It's all a little bit louder and rougher.
Will plan to part out the car in 6 months so anybody that wants in on the goodies hit me up.
hamlet is offline   Reply With Quote
The Following 2 Users Say Thank You to hamlet For This Useful Post:
CSG Mike (10-17-2016), SoCalArgento (10-18-2016)
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 05:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 10:04 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 04:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 05:14 PM
