#3039 |
#3040 |
Drives: subaru
Stock motor & tranny
Catless pt tuning header Nameless 2.5" downpipe/overpipe catted Stock catback 94 octane custom tune. Car has 27k kms on it. The stumble is a quick .5 second and i only notice it between 3-4 under partial throttle. |
#3041 | |
Drives: '14 BRZ, '01 S2K
Do be prepared to wait for at least 2-3 weeks if you send it in. That's how long I had to wait anyway. Last edited by Xiao Li; 11-07-2015 at 02:27 AM. |
| The Following User Says Thank You to Xiao Li For This Useful Post: | dkstylezz (11-07-2015) |
#3042 |
Drives: 2013 Subaru BRZ
Rotrex will replace it. I know that painful ear piercing sound. I couldn't stand it with the hood open.
Sent from my SAMSUNG-SM-N900A using Tapatalk |
#3043 | |
Just got my replacement in today. I never realized how quiet it supposed to be lol. I had gotten used to the old one. |
#3044 | |
#3045 | |
#3046 |
#3047 |
Drives: BRZ, 2 WRXs, 818S, motorcycles, etc
For those that may have the RPM stumble...
My car is bone stock except for the JR SC kit, using the JR tune on 93 octane. I get periods of the powerband where it feels off or it is just missing... I have had the P0172 (System Too Rich Bank 1) and P1170 (Port Injector Fuel Performance) twice in a month. Car was sluggish, felt like it retarded all timing and threw a lot of fuel at it. Cleared the codes, went back to normal. Talked to Jackson Racing a while back about this issue - they said clean MAF and try to keep the harness extension away from the alternator, that it can cause interference. Did both. Yesterday was cruising on the highway at about 65-75. Car started feeling strange again... this time I pulled of the road, shut it off. Started the car back up, and it died right away. Popped hood, made sure all throttle body connections, ecu connections, and maf connections were snug. Also ensure battery (positive and negative) were tight, no issues on anything. Started the car again, same thing. Started again, revved it (2-3k) to keep it running and it would stay running, then back to idle it died out. Did this 2-3 times. Let it sit for 5-10 mins and then it started and acted normal. Now, for the CEL I received during this start/idle issue. P0102 (Mass or Volume Air Flow Circuit Low Input) and P0113 (Intake Air Temperature Circuit High Input). Anyone experience this before? Any idea on what is actually going on with it? |
#3048 | |
Drives: Subaru BRZ
i believe i got p0102 before when my MAF sensor was disconnected ( I was cleaning it) and I turned the acc on to get power steering to push my car off the driveway. Keep in mind the Intake Air Temperature sensor is also on the MAF.
2014 WRB BRZ
| The Following User Says Thank You to Xuningshen For This Useful Post: | Cosworth_0686 (12-12-2018) |
#3049 | |
#3050 |
Realtor/ Principal Broker
Drives: JRSC BRZ GBS LTD 2010 LTD Outback
#3051 | |
#3052 |
Thanks for the suggestion, I am 100% certain that everything is/was tight. I will try to disconnect everything, then plug it all back in, but this is one of the first things I checked as that's what I also assumed.
| Jackson Racing Rotrex Supercharger System Info and Discussion | Jackson Racing | Forced Induction | 827 | 04-06-2020 05:56 PM |
| Jackson Racing Supercharger Press Release and Info | CounterSpace Garage | Forced Induction | 110 | 01-03-2017 10:04 PM |
| jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! | CSG Mike | Forced Induction | 24 | 04-27-2016 01:59 PM |
| Jackson Racing supercharger | NoppyNop | Forced Induction | 241 | 06-26-2014 04:05 PM |
| Jackson Racing Supercharger Pre-Order Sale, $200 off! | Xero-Limit | Forced Induction | 2 | 03-05-2014 05:14 PM |
