Old 05-19-2016, 08:07 PM   #323
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
My Whiteline end links have little rub marks and that's it, and I'm clearly also on the soft hole. No issues on track either, so I don't know what to say
Old 09-27-2016, 12:01 PM   #324
RavioliG
Poor Adult Male
RavioliG's Avatar
Drives: 2013 Subaru BRZ
Does anyone know the spring inner diameter, outer diameter, and length for these things off the top of their heads?
RavioliG is offline   Reply With Quote
Old 09-27-2016, 12:06 PM   #325
ajc209
Drives: GT86 Cosworth
for the mi20 kit
I.D is 2.5" (63.5mm)
Length 200mm
60N/mm f&r
Not sure on the O.D
The instructions say the I.D is 65mm but it is incorrect.
ajc209 is offline   Reply With Quote
The Following User Says Thank You to ajc209 For This Useful Post:
DocWalt (03-07-2017)
Old 10-10-2016, 10:56 PM   #326
jk86freek
jk86freek's Avatar
Drives: fr-s
got my Ohlins MP20 spring rate f4kg/r3kg , normal daily driving very comfortable. Performance wise , i was quit disappointed, I get bottoming out very often between55-70km hitting bumps.
I don't understand why the new spec ohlins is equipped with the spring rate that soft.
jk86freek is offline   Reply With Quote
Old 10-11-2016, 03:46 AM   #327
ajc209
To be honest the 60N front and rear isn't fantastic about bottoming out. The mp20 kit runs a bit more preload so bump travel is a bit longer to compensate the softer rate. Perhaps a set of Bilsteins b6 and some lowering springs will work better for you.
Old 10-11-2016, 06:40 AM   #328
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
When you are lowering the springs and use moderate rates, then you have more issues with bottoming. A solution used in a rally car was to to increase the suspension height and use stiffer spring rates.
Old 10-14-2016, 05:51 AM   #329
ajc209
Rally suspension is a different kettle of fish though, for a start the forces are way beyond anything you see in a road racecar.
Hydraulic bumpstops and progessive damping are often used in a well setup rally damper.
Back on track,
Have you tried the MI20 kit? What are the damper settings? Personally I dont recommend anything less than 12 clicks on the MI20.
Old 10-14-2016, 10:30 AM   #330
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Back on track,
I was referring on tarmac rally setup. Thanks.
Old 10-21-2016, 04:18 PM   #331
wbradley
Sarcastic SOB
wbradley's Avatar
Interesting reading in this thread, really helped me a lot making a decision to buy these.
Just trying to get everything dialed up but I like firmer in the back, less in front hopefully to try and minimize understeer in hard cornering.
The comfort is definitely very on par with stock but with less lean. Only a tiny bit more noise with the front pillow ball top mounts I am using.
Running some camber in the front also to try and offset any understeer this system might introduce.
Looking forward to doing some track time next spring.
The biggest factor for me deciding on Ohlins was the daily driving comfort with minimal compromise. The consensus was that this product is one of the best for road and track just as the name implies.
The Following 2 Users Say Thank You to wbradley For This Useful Post:
ajc209 (10-21-2016), BigFatFlip (10-21-2016)
Old 02-16-2017, 05:04 PM   #332
asdf
Loading...████████] 99%
asdf's Avatar
Drives: #0517
How much camber are the front top hats able to dial in w/o using camber bolts at the bottom? I assume it should be enough to dial in -2.5, right?
Thanks guys!
asdf is offline   Reply With Quote
Old 02-16-2017, 05:10 PM   #333
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
Thanks guys!
When my alignment guy did a sweep, he was able to get to ~-2.8/3 degrees, so yes. Although I didn't think they sold these with camber plates any more...
The Following User Says Thank You to BigFatFlip For This Useful Post:
asdf (02-16-2017)
Old 02-16-2017, 05:26 PM   #334
ajc209
Mine maxed out at -2.7 on one side.
Yes the new mp20 kit has optional top mounts
asdf (02-16-2017)
Old 03-07-2017, 01:19 PM   #335
choi0706
Drives: t
stock strut mounts fit the new ohlins? what about the sti rear mounts and group N front mounts?
choi0706 is offline   Reply With Quote
Old 03-08-2017, 02:46 PM   #336
Sleepypistonracing
Sleepypistonracing's Avatar
Drives: GT86 Road legal time attack car.
Yeah they are supposed to go with the oem top mounts so anything that's supposed to go on the oem strut should fit them. I use mine with velox adjustable top mounts in the front and oem bearing in the rear. Öhlins are using some spacecraft grade bearings in their top mounts and they are not worth the money (500ish a pop).
Skickat från min iPad med Tapatalk
Sleepypistonracing is offline   Reply With Quote
ohlins road and track shock absorbers CyberFormula Suspension | Chassis | Brakes -- Sponsored by 949 Racing 31 11-11-2014 06:00 AM
>> OHLINS Road & Track Coilovers - First Shipment IN - FT86 Special - FREE Shipping! Circuit Motorsports Brakes, Suspension, Chassis 90 08-16-2013 01:39 PM
Ohlins Road & Track Coilovers - IN STOCK!!! RallySport Direct Brakes, Suspension, Chassis 7 05-28-2013 05:11 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 09:15 AM
Ohlins Road & Track Subaru BRZ and Scion FR-S HP Autowerks Brakes, Suspension, Chassis 0 04-24-2013 04:27 PM
