#3697 | |
Drives: BRZ, 2 WRXs, 818S, motorcycles, etc
My issues were caused by a MAF extension harness that had wires pulling out from the connector. This was something that I believe was a manufacturing issue (in regards to the harness). Once I replaced the MAF extension harness - all my issues went away. This was a regular issue for me and I just thought it was a nuance at first. Then all of a sudden the car died and it seemed to get worse so I knew it was something faulty. |
| The Following User Says Thank You to axelthrasher For This Useful Post: | phanguy (09-27-2016) |
#3698 | |
Drives: Scion FR-S Ultramarine
#3699 |
You can order from @CounterSpace Garage or directly from @Jackson Racing.
#3700 | |
i couldn't find it on the site. where should i be looking? |
#3702 |
#3703 |
I recommend inspecting yours first - not saying you will 100% be able to see the wires pulling out from the harness plug, but you will see the red insulators appearing to be different lengths coming out of the plug. I HIGHLY suggest playing around with this to see if this is where your issue is coming from.
#3704 | |
#3705 | |
G20 Guru
Slowmatic Drfiterz, from P to D in a heartbeat. |
| The Following User Says Thank You to Ak1m0to For This Useful Post: | phanguy (10-03-2016) |
#3706 | |
i currently have the new filter in and after a few CELs(different from what i was getting before) from not having tightened a tube it's fine for the last day or so, but like i said my issue is pretty intermittent so i won't call this case closed for awhile. i have the new maf extension waiting for install too. i want to be 100% certain that the new filter either does or doesn't make a difference so i won't install the extension until i get another p0172. |
#3707 |
Drives: Hot Lava 86 MT
Got a quick question for everyone running the JR SC setup: Anyone ever had any problems with the pulleys supplied in the kit? I just replaced both pulleys as the bearings inside were shot. If you shake the pulley you can hear them running loose inside. I replaced them since they looked to wobble when the car is running.
JR Supercharger, JR RS Pulley, JR Oil cooler, JDL UEL header, Dual resonated 3" JDL Overpipe Front pipe, Perrin 3" resonated cat back exhaust, Upgraded Koyorad radiator, ECUTek tune, Enkei RS05RR 18x9.5, Bridgestone RE003 265/35/18, KW V3 Coilovers, Valenti sequential taillights, Kartboy short shifter kit
#3708 |
driving smoother faster
Drives: Sold
AEM air filter wrap that fits 6.5"x5" Jackson Racing C38 kit air filters (http://www.ft86club.com/forums/showp...6&postcount=69)
| The Following User Says Thank You to dp1 For This Useful Post: | Bramick (10-24-2016) |
#3709 | |
#3710 |
Drives: blue brz, silver R8 5.2, orange s2K
Another update on my system too rich code:
The code kept coming back so we pulled off the exhaust manifold and it turns out the precat is mostly toast and the O2 sensor is completely fried. I could have replaced the exhaust manifold but I thought it was only a matter of time before the problem recurred so I had to replace the exhaust manifold with a header (so I'm technically no longer carb legal) and replaced the o2 senser. Everything seems to be running better now and no code yet. It's all a little bit louder and rougher. Will plan to part out the car in 6 months so anybody that wants in on the goodies hit me up. |
| The Following 2 Users Say Thank You to hamlet For This Useful Post: | CSG Mike (10-17-2016), SoCalArgento (10-18-2016) |
| Jackson Racing Rotrex Supercharger System Info and Discussion | Jackson Racing | Forced Induction | 827 | 04-06-2020 05:56 PM |
| Jackson Racing Supercharger Press Release and Info | CounterSpace Garage | Forced Induction | 110 | 01-03-2017 10:04 PM |
| jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! | CSG Mike | Forced Induction | 24 | 04-27-2016 01:59 PM |
| Jackson Racing supercharger | NoppyNop | Forced Induction | 241 | 06-26-2014 04:05 PM |
| Jackson Racing Supercharger Pre-Order Sale, $200 off! | Xero-Limit | Forced Induction | 2 | 03-05-2014 05:14 PM |
