Old 09-14-2016, 11:13 PM   #1
VeganGirl
Drives: Scion FR-S 2013
Rocket bunny v2 wheel hitting the body of the car. Can't make u-turns
Hi does anyone know how to fix this issue. Rocket bunny v2 with forgestars f14 9.5 inch * 18 inch wheels in the front and when I turn the wheel the whole way it's hitting the body of the car. Can an alignment fix this or do I need to cut the body of the car? It's welded in the place it's hitting is it safe to cut there?
VeganGirl is offline   Reply With Quote
The Following User Says Thank You to VeganGirl For This Useful Post:
Summerwolf (09-15-2016)
Old 09-14-2016, 11:34 PM   #2
ryoma
ryoma's Avatar
an easy fix would be to get 17 wheels or lower profile tires, or a combo of both. I personally would not want to cut/grind anything on the car unless you have no other option.
Old 09-14-2016, 11:46 PM   #3
HachiRo
Drives: 2013 White-Out FRS
Cheapest thing to do is get different tires for just the front.
What I find strange is that you're only on 18s and it's hitting that. I've only seen 19s with semi-meaty tires hit that. Didn't think 18s hit that. Even my friend with 19s and low-profile tires has about an inch gap between his wheel and that area..
Edit*
Stay Crushing had this same issue. I'll post the thread if I find it.
Double edit*
He was on 19s, so yeah.. not sure why your 18s are doing this :\.
I live my life one quarter-pounder at a time.
HachiRo is offline   Reply With Quote
Old 09-15-2016, 12:44 AM   #4
Johnny.
Johnny.'s Avatar
Drives: A work in progress.
I had to cut off like the lip of that area to stop rubbing. All the local RBs also cut this area to stop rubbing.
I'm also running a really low offset so you probably won't have to cut as much as I did.
Johnny. is offline   Reply With Quote
Old 09-15-2016, 03:26 AM   #5
turtlefeeder
turtlefeeder's Avatar
Drives: UltraMFrS
Mmh wither go thinner tires or shave till it give enough room
Sent from my SM-P600 using Tapatalk
turtlefeeder is offline   Reply With Quote
Old 09-15-2016, 09:58 AM   #6
VeganGirl
Getting different tires or rims is out of the question, had these custom made and paid a pretty penny for them brand new. Plus only had them for like 2 weeks. Just got the car back!
I had rays gram lights 57 xtreme before 18" with meatyer tires and never had this issue. Someone said it could be "offset" but honestly I have no idea what offset is and what that effects. Is cutting that area safe? If someone sideswipes my car does that area still hold up? I'm hesitant to modify the body of the car especially since there is a weld there.. How will it hold up in terms of side collision?
Old 09-15-2016, 10:27 AM   #7
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
THIS is a huge red flag.
Why do you have a rocket bunny bodykit?
The Following 10 Users Say Thank You to Summerwolf For This Useful Post:
8R6 (09-16-2016), Cole (09-15-2016), DustinS (09-16-2016), Hostile_Kittens (09-16-2016), kch (09-15-2016), Kestrel (10-02-2016), NyC Zn6 (09-16-2016), PandaSPUR (09-16-2016), themadscientist (09-15-2016), wparsons (09-15-2016)
Old 09-15-2016, 11:00 AM   #8
CBR600RR
Drives: Raven Black
says the person with a rocket bunny kit on their 86
The Following 7 Users Say Thank You to CBR600RR For This Useful Post:
8R6 (09-16-2016), ajcarson11 (09-21-2016), Cole (09-15-2016), dattran86 (09-15-2016), DustinS (09-16-2016), kch (09-15-2016), wparsons (09-15-2016)
Old 09-15-2016, 02:00 PM   #9
turtlefeeder
Drives: UltraMFrS
okay basically offset is how much your wheel suck inward or outward from rotors. with the right offset the rim could sit flush, stick out, or slightly tucked behind fender.
if you do shave body you can have it reinforced by having it attach to another part near the area of effect. probably will have to have a body shop custom fit it for you. it'll help it more in a collision, but let's face it either way if something hit your car it'll damage it no matter how strong the body is.
BTW tucking the wheels behind fender a bit is kind of the goal to not scrapping the fenders as you turn since there's space behind the fenders. if this is not done. you must compensate by having wheel size/tires size that's smaller than fender gaps
Old 09-15-2016, 04:22 PM   #10
VeganGirl
That doesn't matter...
Response to turtle thanks, I still don't really understand the offset factor but I guess the fender will have to come off and cut that area. I'll take it to a professional who can let me know if I'm hurting the structure of the car by eliminating that area or not
Old 09-15-2016, 04:24 PM   #11
CBR600RR
Drives: Raven Black
I don't have to know car terms in order to know how I want it to look.
That area of your car should be repaired, yes. But, to solve your problem you should get wheels and tires with a fitment that works for your car.
Old 09-15-2016, 04:25 PM   #12
Summerwolf
Panda Trueno
Summerwolf's Avatar
Okay, so you don't care about the handling, you want the basic look.
You've already done irreparable modifications to the car, to get the functionality back without buying correct offset wheels you will be cutting. Why not go back to the people that installed the kit?
Do you have sideview pictures of the wheels and general fitment?
The Following User Says Thank You to Summerwolf For This Useful Post:
dattran86 (09-16-2016)
Old 09-15-2016, 04:51 PM   #13
turtlefeeder
Drives: UltraMFrS
np, but if you look at the picture you posted. the face of the wheel is sticking out of fender? offset basically determine how much that sticks out or goes into fender. when you turn the wheel base on the offset you have now, your tire will rub against fender. it's kind of late now since you already purchase rims unless you can trade back for am offset that fits your fender, than you won't have to cut anything good luck let's hope it's not to costly
Old 09-15-2016, 04:51 PM   #14
VeganGirl
Fitment is perfect besides it hitting the body of the car. It's an 18" wheel. There's people that have 19" with no problem so idk... and going back to the person is out of the question for reasons I will not disclose.
Other pics
The Following 2 Users Say Thank You to VeganGirl For This Useful Post:
Summerwolf (09-15-2016), turtlefeeder (09-15-2016)
A question for Rocket Bunny wide-body owners UkrOP Cosmetic Modification (Interior/Exterior/Lighting) 0 02-20-2016 02:07 PM
SOLD Rocket Bunny Wide-Body Aero Kit Ver. 2 tech31 Exterior Parts (Aero, Lighting, Etc.) 10 06-10-2015 10:12 AM
rocket bunny wing on stock body guybaldo Cosmetic Modification (Interior/Exterior/Lighting) 9 01-25-2014 02:15 AM
Question about Rocket Bunny Wide Body Kit.? CodyFRS Cosmetic Modification (Interior/Exterior/Lighting) 1 05-16-2013 07:53 PM
Rocket Bunny wide body kit legal? JasonCDC AUSTRALIA 26 02-21-2013 03:47 AM
