Old 09-11-2016, 11:48 PM   #29
Originally Posted by ghostzfh View Post
@Stang70Fastback ... Damn that looked really rough on your transmission.
Absolutely not. Done properly, buttery smooth.
Stang70Fastback (09-11-2016)
Old 09-11-2016, 11:53 PM   #30
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
What ^he^ said.
Stang70Fastback is offline   Reply With Quote
The Following User Says Thank You to Stang70Fastback For This Useful Post:
Ultramaroon (09-11-2016)
Old 09-12-2016, 01:04 AM   #31
86wtywly
Drives: 2014 Scion Frs
Originally Posted by Stang70Fastback View Post
Haha, Ultramaroon and I had a discussion about this not too long ago! (The thread he linked above.) Here's a video I made (also in that thread) where I did NOT double clutch and was able to downshift to 1st at 15 and 20 MPH without issue.
When double clutch, u shift second to neutral. Now u let off the clutch and depress the gas pedal to the desired rpm range. And then shift into first. I know the procedure, however when I tried it, it's even worse than single clutch downshift. Juz wondering.
86wtywly is offline   Reply With Quote
Old 09-12-2016, 01:08 AM   #32
86wtywly
Originally Posted by Cal3000 View Post
I'd double clutch into 1st gear if I'm going 15mph or something. As low as 7 or 8mph, you can just shift it into 1st. Double clutching places less strain of you sychros or no strain at all of you match the engine speed with your transmission.
Juz wondering how u guys achieve double clutch downshift. When I am in neutral and depress the gas pedal to the desired rpm range, and then depress the clutch and shift to first. It felt harder to shift comparing to single clutch downshift. Dunno why.
Old 09-12-2016, 01:40 AM   #33
Stang70Fastback
A.K.A. Starlord
Not sure what you're asking. That is how you double clutch, but I did not do that in the video. I just clutched in and went from 2nd straight to 1st while blipping the throttle.
Old 09-12-2016, 02:22 AM   #34
It's all in the timing ......
If you can get the timing just right, one doesn't have to use the clutch (except for starting off). Ask any old trucker about "jake shifting" ......
The Following 4 Users Say Thank You to humfrz For This Useful Post:
MasonL1997 (09-12-2016), Stang70Fastback (09-12-2016), Tcoat (09-12-2016), Ultramaroon (09-12-2016)
Old 09-12-2016, 01:53 PM   #35
Stang70Fastback
A.K.A. Starlord
Yup. Used to do this for fun all the time when I drove an old, manual school bus. Just enough throttle to "unload" the drivetrain, then slip it out of gear, rev properly, and slot it into the next gear, all without touching the clutch...
...which was useful because the clutch pedal came up twice as far as the other pedals, and was stiff AF, so after an hour your knee would start to hurt.
The Following 2 Users Say Thank You to Stang70Fastback For This Useful Post:
humfrz (09-12-2016), Ultramaroon (09-12-2016)
AT downshift issue FRSBRZGT86FAN Issues | Warranty | Recalls / TSB 92 12-04-2015 02:11 AM
Messed up downshift - how bad did i fuk up ? WGMGR Scion FR-S / Toyota 86 GT86 General Forum 22 11-05-2015 02:55 PM
Rev match downshift possible with OFT Simon99 Software Tuning 24 08-17-2014 05:20 PM
downshift to first swpbrz Engine, Exhaust, Transmission 13 05-07-2014 09:33 PM
6th to 5th Downshift Crunch jcat5150 Issues | Warranty | Recalls / TSB 1 04-17-2014 04:41 PM
