Old 09-12-2016, 12:01 AM   #1
MelvinKennyG
Drives: Blue
Unhappy Clutch problems please help
I just installed a new clutch and flywheel in my frs but I've had several problems first of all the car won't start and my clutch pedal feels loose when before it felt stiffer. I don't know what to do please help
MelvinKennyG is offline   Reply With Quote
Old 09-12-2016, 12:38 AM   #2
Did you mess with the crankshaft position rotor? If it's installed backward, the engine won't start.
Sportsguy83 (09-15-2016)
Old 09-12-2016, 01:23 AM   #3
Well, HELLO MelvinKennyG and welcome to our forum......
WOW - big project, good for you taking it on ......
If you haven't already done so, you might review this DIY to see if you can glean any hint as to what is wrong.
http://www.ft86club.com/forums/showt...ghlight=clutch
I see one of our best mechanical guys is on the case ....
@Ultramaroon ...... what on earth is a crankshaft position rotor, what does it do and where is it ...... ?? .....
kthxbai (09-13-2016)
Old 09-12-2016, 01:30 AM   #4
It's a disc that fits between the engine and the flywheel. It has tabs cut into it that can be seen by a proximity sensor. It works exactly the same way that the wheel speed and camshaft position sensors work.
humfrz (09-12-2016), kthxbai (09-13-2016), Sportsguy83 (09-15-2016)
Old 09-12-2016, 01:35 AM   #5
@MelvinKennyG .... when you say the engine won't start, do you mean it won't turn over or it won't fire .... ??
Ultramaroon (09-12-2016)
Old 09-12-2016, 01:42 AM   #6
MelvinKennyG
Drives: Blue
What I mean is that when I press the clutch in and turn the key the end r won't fire up it'll try to but it just won't crank
Old 09-12-2016, 01:44 AM   #7
MelvinKennyG
Drives: Blue
I didn't mess with the crankshaft position rotor at all
Old 09-12-2016, 01:45 AM   #8
@MelvinKennyG in that DIY you may wish to pay particular attention to:
- On the top of the transmission you're gonna see a tangle mess of wires and hoses but we really only need to worry about a few of them. There are 2 connectors (one red and one gray) that need to be disconnected. There's also a ground wire that need to be unbolted from the top of the tranny. You can also see the clutch actuator, its held on with two 14mm bolts. DO NOT REMOVE THE BOLT TO THE CLUTCH LINE UNLESS YOU WANT TO DEAL WITH BLEEDING IT LATER!
- One thing I forgot to take a picture of is the wiring that needs to be removed from the starter. On the back of the starter you will see a small connector that needs to be removed. Also there is a rubber boot covering a 12mm nut on a wire terminal, remove this and move the wires out of the way."
Now, tell me that you DID hook the starter back up ......
Old 09-12-2016, 01:54 AM   #9
MelvinKennyG
Drives: Blue
I believe I did connect the starter correctly
The Following User Says Thank You to MelvinKennyG For This Useful Post:
humfrz (09-12-2016)
Old 09-12-2016, 01:54 AM   #10
I'm sorry, I have to ask ....... you did hook the battery back up ..... ??
When you hit the key (start switch) does it go "click-click-click" .. ??
Have you checked the voltage on the battery ...... maybe it died during the operation ....
Old 09-12-2016, 01:58 AM   #11
I think there's some confusion over terminology. OP,
Crank = turn over = starter motor actually rotates the engine.
Fire = anything more than that. Could be a single pop, a sputter, or actually runs on its own for a few seconds.
humfrz (09-12-2016)
Old 09-12-2016, 01:59 AM   #12
MelvinKennyG
Drives: Blue
Yea I hooked it up correctly at first I thought my battery had died but after doing a battery test it showed it was fine. Like I said before what i find weird is that my clutch feels a lot softer than before maybe it's not making good contact. My car will not turn on at all it'll seem like it's about to start but then just doesn't
Old 09-12-2016, 02:04 AM   #13
Does the starter rotate the engine? Does it rotate the engine with the same vigor as it did when it was working properly or, if it rotates, does it labor?
humfrz (09-12-2016)
Old 09-12-2016, 02:08 AM   #14
As far as the soft clutch ...... be aware of this part of the DIY.
"You can also see the clutch actuator, its held on with two 14mm bolts. DO NOT REMOVE THE BOLT TO THE CLUTCH LINE UNLESS YOU WANT TO DEAL WITH BLEEDING IT LATER!"
So, does your clutch system need bleeding .. ??
How about the clutch return spring ..... is it still in place .. ??
clutch, flywheel, won't go into gear, won't start
Buddy Club Race Spec Coilover Problems on Problems on Problems mpross Suspension | Chassis | Brakes -- Sponsored by 949 Racing 48 09-05-2016 12:18 AM
New Clutch Job, New Problems... RUEN_86 Engine, Exhaust, Transmission 4 12-28-2015 06:13 PM
Transmission problems, oil leaks and detonation problems.. turboviper Issues | Warranty | Recalls / TSB 4 06-18-2014 05:01 PM
Problems with FX400 full-disk clutch after shady install... ***Help?*** Argento_FR-S Engine, Exhaust, Transmission 4 05-29-2013 03:29 AM
