Old 09-07-2016, 11:07 PM   #29
mulekr1
mulekr1's Avatar
Drives: 15' Limited BRZ
Even the worse shops i've seen in NY do better, take it back or if through insurance get them involved to switch shops. Thats not even close, like someone above said they can try blending it (paint matching one panel is hard) but that color doesn't even look close.
mulekr1 is offline   Reply With Quote
Old 09-07-2016, 11:44 PM   #30
PatSciFRS
Drives: Scion FRS 10 Series
Usually, I'd say ...... just get over it.
However, from your picture, I'd suggest you take it back and let them make another attempt.
Yeah, actually I am not usually a nitpicker and I was seriously thinking of letting it go but when I look at the bumper I just know that it's wrong. On the day I bought the car, I knew that this Silver Ignition paint on the 10 Series was going to be a tricky paint to match, it has all kinds of hues depending on the lighting conditions. But from all the replies and honest opinions the overwhelming consensus is to give it another shot. So this is what I have decided to do. I will let you know how the second try turns out.
Thanks to all
Pat
PatSciFRS is offline   Reply With Quote
The Following User Says Thank You to PatSciFRS For This Useful Post:
humfrz (09-07-2016)
Old 09-08-2016, 02:52 AM   #31
RJasonKlein
RJasonKlein's Avatar
Drives: 2013 Scion FR-S 10 Series
I feel your pain, because I, too, have a 10 Series and know just how unique the paint is on our cars. The work done on your car shouldn't be accepted, and there's a very obvious difference in color between the bumper and quarter panel that anyone can spot. If the quarter panels were undamaged in the collision, contrary to what two people have suggested you do not want to blend or feather the new bumper paint into that of the surrounding quarter panels. A skilled painter will be able to get near-perfect match when reprinting the bumper on its own.
Good luck - like I said, I feel your Pain!
Last edited by RJasonKlein; 09-08-2016 at 03:51 AM. Reason: Corrected a typographical error.
RJasonKlein is offline   Reply With Quote
Old 09-08-2016, 03:03 AM   #32
Hotrodheart
Hotrodheart's Avatar
Originally Posted by PatSciFRS View Post
Hi folks,
Just wanted to gauge your opinion concerning paint match-up. My Series 10 FRS was rear-ended a few weeks ago and it was fixed last week basically with a new bumper. However, when I took delivery of the car, I noticed that the paint on the bumper did not match the paint on the rest of the car body. At first I was given a lecture on how the paint appearance will always be different because of the different materials (plastic vs metal) being covered. When I was still not satisfied with that explanation, I was provided with a write-up that stated that I can bring the car in after a couple of weeks to allow the fresh paint to cure and the bumper will be repainted at no cost to me.
The question that I have is the following: Is it worth it to go through this again and probably the paint will still not match or should I just accept it as it looks right now?
Your comments are welcome.
Thanks
Pat
Horseshit. They do bad work. They are just hoping you go away. I'd go to your insurance company, lodge your complaint. Let the insurance company recommend another shop to get it painted right. And of you're lucky, that body shop will go on the insurance company's shitlist. Maybe THAT will get their attention. But I wouldn't bring it back to the same body shop on a bet. You alreadu gave them a chance to put it right. They gave you the "they all do that" line.
Hotrodheart is offline   Reply With Quote
The Following User Says Thank You to Hotrodheart For This Useful Post:
strat61caster (09-08-2016)
Old 09-08-2016, 03:17 AM   #33
TheAsianRacer
TheAsianRacer's Avatar
Drives: Asphalt FRS
While I agree you should take it back as it is way off but it will be hard to match paint regardless. Heck, even if damage is on the metal surfaces as well, 8-9x of 10, the paint won't match due to it being different materials. However, any self respecting true painter doesn't want to have to do things more than once so they will spray anywhere from 3-5 different test panels just to get the closest one.
Anyone that says it will match perfectly, go to any Toyota/ford/Lexus/Mercedes/etc, look carefully at any and most colors on the lot, you will find that even from the factory, the paint won't match 100% from any metal surface vs the bumper/plastic pieces. That is why when vehicles age and the moldings start to discolor before most metal parts.
Also, regardless of ANY shop you take it to, for any repairs, they will use bondo, it's just a matter of how thick they lay it on and sand it back down. Even brand new cars and their panels may have "bondo" to remove any imperfections in the stamping/production process.
TheAsianRacer is offline   Reply With Quote
Old 09-08-2016, 09:39 AM   #34
Shinigami301
Slow driver, fast biker.
Shinigami301's Avatar
Drives: '16 86, '00 Celica GTS, Sportbikes
Originally Posted by Norville Rogers View Post
Why are you tippy tapping to us on the keyboard. Take it back if you aren't happy or live with it and shut up and stop bothering people that have nothing to do with it.
Man up.
Why so acerbic?
Shinigami301 is offline   Reply With Quote
Old 09-08-2016, 11:04 AM   #35
fizzymike
fizzymike's Avatar
Drives: 2014 Silver BRZ
Like everyone says, take it back. I know it must be a pain but its better than staying like that. I can imagine it looks worse in person. Paint wont always match 100% but they can definitely do better than that.
fizzymike is offline   Reply With Quote
Old 09-08-2016, 01:35 PM   #36
RichardsFRS
RichardsFRS's Avatar
Drives: 2013 Pearl White 6MT
It looks like ass, they did horrible job. Get your money back and take it to competent people
Back from bancation in Banopolis where I laid on the beach with a beer between my legs. I at night and ate at sun rise
RichardsFRS is offline   Reply With Quote
Old 09-08-2016, 04:07 PM   #37
Kensu
Drives: 13 brz premium
Im getting my rear bumper replaced soon due to some scratches and warping from a small bumper to bumper accident over the weekend. this has me a little worried if the shop will actually match my paint correctly.
Kensu is offline   Reply With Quote
Our Back to Back Savings Continue with our 2015 Memorial Day Sale! FRSport.com Announcements, Contests, Giveaways 0 05-22-2015 09:10 PM
Axle back exhaust feed back requested Gruppe-s Engine, Exhaust, Transmission 10 12-10-2014 08:56 PM
Possible trade? Nameless axle-back for Perrin Resonated Cat-back GTB/ZR-1 Engine, Exhaust, Bolt-Ons 0 03-26-2013 02:51 PM
Drove the 86GT and NC miata back to back on GT5 Hanzo FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 39 01-07-2012 01:56 PM
