Old 09-07-2016, 12:01 PM   #1
timmydatooth
Drives: Scion Frs
Question about coolant
Just looking at my engine today I noticed that the coolant level was barely above the line that says low. Does that mean that I should add more now or do I wait? Also is there a certain type of coolant that our cars use or do I have to go to toyota to get it? Please help Thanks!
timmydatooth is offline   Reply With Quote
Old 09-07-2016, 12:18 PM   #2
theadmiral976
Drives: WRB Subaru BRZ Limited 6MT
If the engine was stone cold, then you are fine re coolant levels. If it was warm, you will likely find that the level drops below the low line when then engine cools.
I strongly encourage you to use the Toyota/Subaru coolant specified in the manual. The cooling system on this car, like most new vehicles, is designed to last basically the life of the vehicle. The various additives found in non-OEM coolant can cause issues with these relatively finicky systems. The OEM coolant is quite expensive, but you shouldn't really ever have to buy more than one jug. I think the coolant is rated for almost 200K miles in these cars.
If you choose to fill the reservoir, I strongly suggest you fill no more than halfway between low and high. Otherwise, you'll just be wasting coolant (it'll spill out) as this engine is quite dynamic in coolant levels during heat cycling.
theadmiral976 is offline   Reply With Quote
The Following User Says Thank You to theadmiral976 For This Useful Post:
timmydatooth (09-07-2016)
Old 09-07-2016, 12:18 PM   #3
gramicci101
Off Topic
If it's between the full and low lines when the engine is cold then you're fine. But if you want to put a little more for peace of mind, you need either Subaru super blue coolant or Toyota super long life coolant. Not prestone or whatever else.
The Following User Says Thank You to gramicci101 For This Useful Post:
Old 09-07-2016, 01:21 PM   #4
86geek
86geek's Avatar
Drives: 2015 FRS Asphalt
I had same issue a few days ago but my reservoir was bone dry. Drove to dealership and they topped it off for me. This is the second time it's happened since I've owned the car. Service writer suggested at my next service in Oct. to get a closer inspection to make sure I have no leak. My car still has the new car warranty. Amazon seems to be the cheapest for me to get the Toyota coolant.
Opti-Coat & Cquartz Finest, Apexi Drop in Filter, 2.5 Perrin Res. Catback Exhaust
86geek is offline   Reply With Quote
Old 09-07-2016, 01:31 PM   #5
SlammedSilly
Drives: 2015 Ultramarine FR-S
HEY FELLA's! ok, so i last year, i noticed my coolant was low, stopped in had it topped off, made sure it was topped off at every oil change also. As of a few months ago, i stopped in to get it topped off and they put toyota red coolant in, thats a no no!! So they ended up doing a full coolant flush on them! Well my coolant level is low again and im stuck on what i should do. Bc they said keep an eye on it and its been like 3k miles since the flush they wanted to look into it...
so from what ive noticed/read, its a common issue for our cars to eat coolant. and most of ours havent had any head gasket issues, yet!!
SlammedSilly is offline   Reply With Quote
The Following User Says Thank You to SlammedSilly For This Useful Post:
F R YESS (09-08-2016)
Old 09-07-2016, 04:08 PM   #6
In addition to what said above, since you live in a warm climate, and your car just needs a cup or two to bring up the level, I would suggest you just add some distilled or demineralized water.
It will be OK......
timmydatooth (09-07-2016), Ultramaroon (09-07-2016)
Old 09-07-2016, 04:12 PM   #7
Well, now, my 2013 hasn't "used" any significant amount of coolant in the last 3 years.
Your car may have a slow coolant leak ......
lupindub (09-07-2016), SlammedSilly (09-08-2016)
Old 09-07-2016, 11:32 PM   #8
lupindub
Drives: Scion FR-S
Ditto this. For some reason *knock on wood* it seems my car hasn't lost a drop of coolant nor oil in the time I have owned the vehicle.
lupindub is offline   Reply With Quote
The Following User Says Thank You to lupindub For This Useful Post:
humfrz (09-07-2016)
Old 09-08-2016, 12:13 AM   #9
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
If it's not leaking then it's evaporating. Since it's a large percentage is water. And you know.... Heat and what nots, typical middle school sicence class.
The amount of coolant to fill the coolant reservoir is like 2 cups. Kind of makes you question why you bought that $30 coolant, where all you needed was a cheap $1 gallon of distilled water. But meh, at lest you'll have that coolant for years or when ever you need it.
Old 09-08-2016, 12:16 AM   #10
jarnojvv
jarnojvv's Avatar
Drives: 86|Fortuner|FJ|Mustang|SwiftSport
I have to ask, evaporating to where? Is it not a closed system?
-JvV-
jarnojvv is offline   Reply With Quote
Old 09-08-2016, 12:29 AM   #11
Mr.ac
Mr.ac's Avatar
Drives: BRZ Premium
Really?
Old 09-08-2016, 01:10 AM   #12
jarnojvv
jarnojvv's Avatar
Really?
Real question bud, I have never needed to refill coolent ever on any of my vehicles newer than 20 years.
-JvV-
Old 09-08-2016, 01:37 AM   #13
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
Theory is that overflow tank/reservoir isnt air tight, water vapor will escape through there.
The Following User Says Thank You to PandaSPUR For This Useful Post:
zc06_kisstherain (09-08-2016)
Old 09-08-2016, 01:38 AM   #14
jarnojvv
jarnojvv's Avatar
Tnx, but in practice this is shown to be negligibly little in a healthy system?
-JvV-
Coolant loss - Void Warranty/ Edit: coolant flush question BRZach Engine, Exhaust, Transmission 15 01-02-2016 09:21 PM
Coolant Question fantah Hawaii 0 08-01-2014 06:06 PM
Turbo coolant lines GTX2867. Can I use the throttle body coolant lines? mike the snake Forced Induction 8 04-01-2014 06:56 PM
Simple frs coolant question Young_makaveli Engine, Exhaust, Transmission 24 12-25-2013 05:42 PM
Coolant Question boredom.is.me Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 04-15-2013 08:50 PM
