Old 09-01-2016, 05:43 PM   #701
Lefty-FRS
Lefty-FRS's Avatar
Drives: '15 FRS 1.0
I appreciate this thread very informative to a noob.
" It's not the hand you're dealt, but how you play it."
Lefty-FRS is offline   Reply With Quote
Old 09-06-2016, 01:48 PM   #702
itsjustdavep
itsjustdavep's Avatar
Drives: Asphalt Scion FR-S
Originally Posted by itsjustdavep View Post
has anyone heard anything on this yet? i just updated my OFT after like a year and realized that this is now a selectable menu
Anyone? Shiv?
2013 Asphalt HRI Tuned-K&N DropIn-Tomei UEL-Tomei OP-Invidia FP-Nameless Muffled Trackpipe...and corn
itsjustdavep is offline   Reply With Quote
Old 09-12-2016, 02:02 AM   #703
geoffrey1236
Drives: 2013 FRS MT
Hello,
just got the OFT from Shiv and very enjoy the stage1 93 tune. I have TRD exhaust system on the 2013 frs, and im considering about change my intake to TRD or K&N or if you have any recommendations? if I changed the intake, do I need to modify some tunes by using RomRaider? or i dont need to? please advice, because if this will gain more hp then i'll be move onto the next stage with OFH.
thanks,
Jeff
geoffrey1236 is offline   Reply With Quote
Old 09-12-2016, 02:52 AM   #704
steve99
Drives: FT86
Originally Posted by geoffrey1236 View Post
Hello,
thanks,
Jeff
Have a read of the Basic bolt on Mods Guide link below
There is very little hp in intakes and you will likely need to alter maf scaling in tune to suit intake
Much easier and cheaper option is to buy a performance drop in filter like apexi or similar dry filter.
Save you money and put it towards a set of catless header you will get a much better bang for buck than an intake.
Teseo (09-12-2016)
Old 09-13-2016, 02:59 AM   #705
geoffrey1236
Drives: 2013 FRS MT
thanks for the info!
Old 09-13-2016, 08:25 PM   #706
WolfsFang
Scrape Master
WolfsFang's Avatar
Drives: Goal: Oldest FRS State Side
So i have kinda a dumb question, just got a OFT in the mail today, yay very excited! plugged it into my car and read the stock rom, now I have plugged into my pc and im ready to upload a tune, now this is where the question comes in.
In Open flash manager it shows my calibration as ZA1JA00C but if I look at the other tunes that it has created they go as.
Stg 1 A01C.bin
Stg 2 EL A01C.bin
Stg 2 UEL AO1C.bin
etc...
If my calibration is ZA1JA00C than why are the tunes that it created A01C? Which do I upload, A00C.bin or A01C.bin?
For any reference my mods are borla UEL headers, Injen intake, and power blocks.
You do realize comparing the BRZ to the FR-S is like comparing which hand you love masterbating too right?
WolfsFang is offline   Reply With Quote
Old 09-13-2016, 08:29 PM   #707
alxtheoreo
alxtheoreo's Avatar
Stg 1 A01C.bin
Stg 2 EL A01C.bin
Stg 2 UEL AO1C.bin
etc...
Congrats on your purchase!
Those are the default maps. You want to download the updated maps from their webpage. Once you download them, you can upload the correct file to your tablet by removing the default maps.
Sent from my SM-G930V using Tapatalk
Invidia catless FP & Q300. Enkei TS-10s. Conti ExtremeContact Sport tires. Hawk HPS pads. Centric Rotors.
alxtheoreo is offline   Reply With Quote
The Following User Says Thank You to alxtheoreo For This Useful Post:
WolfsFang (09-13-2016)
Old 09-13-2016, 08:30 PM   #708
WolfsFang
Scrape Master
WolfsFang's Avatar
Awesome thanks
The Following User Says Thank You to WolfsFang For This Useful Post:
alxtheoreo (09-13-2016)
Old 09-13-2016, 09:19 PM   #709
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
Maybe I missed it, but do we know if the 2017 cars are supported by OFT? Their website says 2012+, just curious if anyone has a 2017 that has successfully flashed with OFT.
justinco is offline   Reply With Quote
Old 09-14-2016, 01:10 AM   #710
steve99
Drives: FT86
They have support for F00C and F40C manual 2016 cars, not sure on the auto, but find the calibration ID of the eCU and ask the OFT guys they will be able to help. If they dont have tunes for them they will be able to make some up once they get hold of a rom from the later model cars
Nah (09-20-2016)
Old 09-14-2016, 01:30 AM   #711
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
Ok, that's positive at least. I might be a guinea pig and pickup a '17 BRZ and see how OFT works with it. I would be getting it dyno tuned anyways, so long as I could read/re-flash I should be ok I would think.
Old 09-20-2016, 09:11 AM   #712
Nah
Drives: 2013 Scion Frs 6mt
@steve99 could you explain the benefits of dialing in both PI and DI independently and could you explain the process as to how if I use the VGI MAF scaling tool.
I understand maxing out both DI and PI than logging.... but what's after that? Would I just scale my MAF to each than scale it one last time when I intorduce both?
I know increasing or decreasing injection latency helps with LTFT at idle but again what about those crossover points?
Any tips while on e85?
One last question Steve99 are there any other maps that will have a direct effect on LTFT?
I'd like to know different ways to address LTFT than scaling my MAF so any help is appreciated
If you've answered this before I apologize
Thank you!
Nah is offline   Reply With Quote
Old 09-20-2016, 09:57 AM   #713
Kodename47
Kodename47's Avatar
Drives: UK GT86
There is probably very little to gain if you haven't swapped an injector set. In theory it would be beneficial for ensuring that fuel trims don't change when changing between PI/DI/Dual.
How you would do it is up to you. However scaling the MAF on one and then the other is going to show you the difference, how you then manipulate it is done by PI flow scalar and/or the many DI tables.
LTFT will obviously be affected by any fueling calibration changes like those just mentioned, however by playing with the open loop and closed loop fuel maps you can deactivate the LTFT if you desire. This has it's advantages and disadvantages.
.: Stealth 86 :.
Kodename 47 DJ:
Old 09-20-2016, 10:39 AM   #714
Nah
Thank you. Okay so lets says with full DI is show me 8% 5% 3% (LTFT idle,cruise,WOT) and full PI shows 3% 5% 8%. What's the difference there? If that's even a good example?
How would I manipulate the PI flow scaler and DI tables? Increase or decrease?
WTB: Open Flash Tablet TOZER Canada Classifieds 3 07-05-2015 08:13 PM
Open Flash Header & Open Flash Tablet Calavera Engine, Exhaust, Bolt-Ons 9 05-11-2015 09:27 PM
FS: open flash headers / open flash tablet - SOLD alanhung85 Canada Classifieds 12 02-10-2015 03:08 PM
FS: Open Flash Tablet (OFT) mex2309 Engine, Exhaust, Bolt-Ons 1 10-29-2014 03:49 PM
Open flash tablet. cooldandani Scion FR-S / Toyota 86 GT86 General Forum 1 02-22-2014 08:14 PM
