Old 08-26-2016, 11:15 PM   #687
Sam.Vera
Detective John Kimble
Sam.Vera's Avatar
Drives: 2016 FR-S
I have a question. I did some searching around this forum and google and couldn't find the answer. My apologies if it has been discussed before.
When I press the throttle right to the floor, the OFT doesn't read 100. In fact, when I am flooring it down the highway, going through the gears, for example; it fluctuates anywhere from 96 to 89. Is this normal? I decided to reflash my car and use the instructions on the first page here for laggy throttle, by letting the car sit with the ignition on (but the car not running) for an extra while so it can learn cam positions and whatnot. Even after that, with the ignition on (and the car not running) I pressed the throttle to the floor and released several times over and it only ever reaches 97. This is all with the Stage 2 EL 91 octane tune.
My car is a 2016 FRS. Mods are an even-length, catless header; Full exhaust, HKS drop in air filter, intake sound delete, and finally the OpenFlash Tablet.
Sam.Vera is offline   Reply With Quote
Old 08-26-2016, 11:34 PM   #688
phrosty
It's normal.
phrosty is offline   Reply With Quote
Old 08-27-2016, 03:20 AM   #689
Sam.Vera
Sam.Vera's Avatar
Drives: 2016 FR-S
Ah, really? That really bothers me. Silly thing.
Old 08-27-2016, 07:36 PM   #690
Teseo
Drives: frs
Can i leave the obd cable plugged the oft connected?
Asking because i dont wanna plug unplug, obd connector looks weak
Old 08-27-2016, 07:51 PM   #691
phrosty
I use an extension cable for this reason.
The Following User Says Thank You to phrosty For This Useful Post:
Teseo (08-27-2016)
Old 08-27-2016, 08:46 PM   #692
OrangeGuitar
OrangeGuitar's Avatar
Drives: '17 BRZ Dark Grey Sport-tech 6MT
An extension with a switch helps. The battery dies in a few days otherwise
OrangeGuitar is offline   Reply With Quote
Old 08-30-2016, 09:36 PM   #693
itsjustdavep
itsjustdavep's Avatar
Drives: Asphalt Scion FR-S
Originally Posted by Yoshoobaroo View Post
Back on the old Vishnu Procede piggyback tuner there was an 'auto tune' feature that would gradually increase the aggressiveness of the tune until incipient knocking appeared, and then backed off slightly. Maybe Tunebot is a new version of that?
-Josh
has anyone heard anything on this yet? i just updated my OFT after like a year and realized that this is now a selectable menu
2013 Asphalt HRI Tuned-K&N DropIn-Tomei UEL-Tomei OP-Invidia FP-Nameless Muffled Trackpipe...and corn
itsjustdavep is offline   Reply With Quote
Old 08-30-2016, 10:07 PM   #694
JW843
JW843's Avatar
Drives: 2013 BRZ Limited
What is the latest version right now? I've got hardware version 100 and firmware version 138, but i still get "Update Template File" popups when going going to read data values in the car.
JW843 is offline   Reply With Quote
Old 08-31-2016, 04:02 PM   #695
Halo_86
Drives: Whiteout Fr-s
Maybe someone in here and has an OFT with a custom tune done with Shiv can answer this.
I was wondering how long does the process of getting a custom tune from Shiv take. I purchased and have been in contact with Shiv but all he has asked were some basic condition/model of my FR-S. I'm just curious as to how long it took to receive a baseline tune as my FR-S pretty much been sitting for a week.
Thanks.
Halo_86 is offline   Reply With Quote
Old 08-31-2016, 04:17 PM   #696
everythingsablur
everythingsablur's Avatar
Drives: 2016 Scion FR-S RS 2.0
I have not done the custom tune, but my rough understanding from reading up on it is the process does take time. If you want a tune done immediately, you possibly chose the wrong product and should go to a local tuner with a dyno, but they will almost invariably tune with Ecutek or similar (and lock the tune).
Shiv/team will send you a base tune, get you to install it, then you'll need to drive and data log for a period of time, and send them the logs. They'll analyze it, send you an updated tune, and you repeat the process for several iterations (max 7?) until they/you feel that the tune is as optimal as it will realistically get. This whole thing can take days if not a couple weeks to get through from start to finish.
As for delays in even getting that process started... <shrug> Busy guy?
2016 Scion FR-S Release Series 2.0 #170/1000
everythingsablur is offline   Reply With Quote
Old 08-31-2016, 04:49 PM   #697
Halo_86
Thank you sablur.
I have been in contact with Shiv; getting to know the car/mods/driving, and I understand it takes time to achieve the optimal tune. Just looking for comfort in regards to when a baseline tune would come around since its going on three weeks since the last time I have been able to move the FR-S.
Old 08-31-2016, 04:51 PM   #698
itsjustdavep
Thank you sablur.
Since you've been able to move the car?...
Old 08-31-2016, 05:11 PM   #699
Halo_86
2.5 barmap sensors that comes with the Vortech V3 kits wouldn't allow me to start the car. I used the stock map sensor to start it and move it out the garage and that was it. I don't feel safe driving the car as multi CELs get thrown with the car is on with the stock map sensor.
Old 08-31-2016, 06:30 PM   #700
Kodename47
Kodename47's Avatar
Drives: UK GT86
I'm sure someone could sort you out, configuring the map sensor isn't that hard. If you're running the OEM MAP sensor, just copy across the settings from an OEM map. It won't be an issue running the standard one.
You just need the scalars and DTC limits. 3/4 tables in Romraider IIRC
.: Stealth 86 :.
Kodename 47 DJ:
WTB: Open Flash Tablet TOZER Canada Classifieds 3 07-05-2015 08:13 PM
Open Flash Header & Open Flash Tablet Calavera Engine, Exhaust, Bolt-Ons 9 05-11-2015 09:27 PM
FS: open flash headers / open flash tablet - SOLD alanhung85 Canada Classifieds 12 02-10-2015 03:08 PM
FS: Open Flash Tablet (OFT) mex2309 Engine, Exhaust, Bolt-Ons 1 10-29-2014 03:49 PM
Open flash tablet. cooldandani Scion FR-S / Toyota 86 GT86 General Forum 1 02-22-2014 08:14 PM
