#3655 |
Drives: FRS
That works turbo kit put down some great numbers....
#3656 |
Drives: '13 FRS
Sad times, got a p0018 coming to work today. Reading around about it doesn't sound good. I can't help but think it is related to this tune (jackson racing CARB) or kit somehow. I have had the car for 3 years and ~60k miles without issue.
I am out of warranty now so I will try to find a solution. |
#3657 | |
#3658 | |
Drives: '13 FRS
So I am unsure if this was ever done. The car was manufactured 12/12 and I bought it in 2/13 and had the dealer do oil changes for the first year so would they usually apply something like this or would I have to have requested it? If it is the one mentioned here: http://www.ft86club.com/forums/showthread.php?t=52979 then I don't have the underhood sticker it mentions one page 4 but that isn't conclusive. Either way if I am no longer running the stock ECU firmware and am instead running the JR CARB ecutek tune, then does this tsb even apply? If I go back to stock, get the dealer to flash, then flash back to JR tune is the end result any different than what I have now? |
#3659 | |
Drives: JR FR-S,
"Please refer to the Genuine Toyota or Subaru Service Manual for all mechanical and safety procedures. Make sure all vehicle updates and Technical Service Bulletins (TSBs) have been completed before installation." As discussed via email, this is not related to the supercharger system or CARB calibration. The OBD2 system is not altered by our supercharger or CARB calibration. The functions and warning that pop up are all still legitimate OEM warnings. Example: If the ECU said you had a P0463 Fuel Level Sensor Circuit High code, it would still mean there is an issue with the fuel sensor. That would not be the fault of the supercharger system or the CARB calibration. -Oscar Jr. |
| The Following 3 Users Say Thank You to Jackson Racing For This Useful Post: |
#3660 | |
PhoneFlash by EcuTeK
This code is caused by a very well documented mechanical issue that plagued a very good chunk of 2013, and even 2014 model year vehicles for this platform. It is recognized worldwide by both Toyota and Subaru, and occurs on vehicles from bone stock to wildly modified. It would be wise to heed Jackson's advice and pursue having a qualified technician address this fairly common issue. I have personally seen this issue both arise and subsequently be resolved at the OEM level more times than I care to remember, and I'm sure Jackson Racing is in the same boat there. Sincerely, Zach Delicious Tuning |
| The Following 2 Users Say Thank You to DeliciousTuning For This Useful Post: | CSG Mike (08-24-2016), Icecreamtruk (08-25-2016) |
#3661 |
Drives: 2015 AOZORA EDITION
any videos of pulls or anything? cant seem to find much on youtube
#3662 |
Drives: '13 FRS
Thanks for the responses guys (and jackson racing). I think the part I was missing and it took me a little while to get is that you are saying that the ecutek tune does not overwrite the entire ecu program memory, only part of it. So the OBDII sections of the ecu will be whatever they were at the last version that toyota wrote to it.
#3663 | |
#3664 |
Drives: Toyota 86
Question for fitting this kit to a RHD model: where will the rotrex oil reservoir tank reside since the car battery is in place of the brake booster?
#3665 | |
Zach or others, I have a 2013 BRZ and was curious if the p0018 code eventually plagues all early build cars or is it still a small percentage? And if it does happen, can it only be resolved at the dealership or any competent garage? I did a search and it seems like a common code but the fix is all over the place, from ECU replacement, to cam sensor replacement to some other mechanical fixes. And it seems like even after these fixes, the code still pops up. If there's a p0018 definitive fix thread, please point me to it. Just want to learn more! |
#3666 | |
Drives: 2014 BRZ
#3667 |
Has anyone experienced any 'rev hang' around 2,000rpms when driving through parking lots and such?
I usually notice it when I disengage the clutch and it only lasts for like 2 seconds then idles. Last edited by Aaronimoe; 08-29-2016 at 11:24 PM. |
#3668 | |
Drives: sc00ter
| Jackson Racing Rotrex Supercharger System Info and Discussion | Jackson Racing | Forced Induction | 827 | 04-06-2020 05:56 PM |
| Jackson Racing Supercharger Press Release and Info | CounterSpace Garage | Forced Induction | 110 | 01-03-2017 10:04 PM |
| jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! | CSG Mike | Forced Induction | 24 | 04-27-2016 01:59 PM |
| Jackson Racing supercharger | NoppyNop | Forced Induction | 241 | 06-26-2014 04:05 PM |
| Jackson Racing Supercharger Pre-Order Sale, $200 off! | Xero-Limit | Forced Induction | 2 | 03-05-2014 05:14 PM |
