Old 08-23-2016, 10:52 PM   #673
toyoyoyoyo86
Drives: 86
Originally Posted by 86socal View Post
My oft is not connecting to the open flash manager, what should i do?
I had some trouble too.
What system and what error message?
toyoyoyoyo86 is offline   Reply With Quote
Old 08-24-2016, 01:04 PM   #674
commandar
Also running into the same. OFM 1.25.1, across two different systems.
No error message, it just sits at the "Connecting to device..." screen. I'm wondering if maybe something with the W10 Anniversary update broke something. I've had it hooked up on both these computers before, the tablet itself still works in the car just fine.
commandar is offline   Reply With Quote
Old 08-24-2016, 02:06 PM   #675
steve99
Drives: FT86
make sure you are not using usb 3 ports, from memory oft hardware doesn't work well with usb 3, they usually have blue colour inside, try usb 2 port they are usually white.
Old 08-24-2016, 04:39 PM   #676
Shady195
Drives: '13 10 Series FRS #1203
Originally Posted by mulekr1 View Post
Nah the guy is my friend (local mom and pop) but in NY you can't scam the system because its OBD2 and if it says not ready you can't pass. He doesn't personally care, I would just use someone elses car for a sticker but NY checks inspection to renew the registration.
NYS allows 1 failed ready monitor. 2 failed monitors if its over 10 years old if I recall.
I've passed 3 NYS inspections now with a custom tune and header.
Shady195 is offline   Reply With Quote
Old 08-24-2016, 05:29 PM   #677
STV3
Señor Member
STV3's Avatar
Update with my inspection problem.
Got the car to pass yesterday first try. All I did was order a OB2 extender cable from Amazon for $10. Made sure it connector had nice thick pins on it via the picture on Amazon. Plugged it into my car, plugged the other end into their inspection machine and it worked flawlessly.
STV3 is offline   Reply With Quote
Old 08-24-2016, 07:58 PM   #678
commandar
I've actually tried both a USB 2.0 port directly and through a hub.
What's particularly odd is that the OFT does show up in Device Manager, but OFM doesn't seem to pick it up. It's what has me wondering if it could be a software issue, especially since W10 just got a service-pack level update.
Old 08-24-2016, 11:40 PM   #679
toyoyoyoyo86
Drives: 86
I am on Mac running Windows 7 VM so not sure if my solution will help.
Basically let it display "Connecting to device" for a while and OFM will freeze. Then disconnect the USB cable and wait for "Unconfigured device, it cannot be used." message and click OK. Then reconnect the USB cable and start OFM again and it will connect.
Old 08-24-2016, 11:46 PM   #680
steve99
Drives: FT86
If you on windows try a different computer
if you on mac/apple its probably some issue with emulator or virtual machine software setup.
the oft guys run mac so they may be able to help
Old 08-24-2016, 11:58 PM   #681
commandar
I'll give this a try when I get home, thanks.
I've tried on both my laptop and desktop, actually, but they're both running W10 with the Anniversary update. I don't have easy access to a W7 PC, unfortunately.
Old 08-25-2016, 07:20 AM   #682
mulekr1
mulekr1's Avatar
Drives: 15' Limited BRZ
I've never heard that, maybe I take a trip to Albany or Rockland.
I would only have 1 failed ready anyways right?
Thanks so much btw.
mulekr1 is offline   Reply With Quote
Old 08-25-2016, 10:15 AM   #683
Shady195
Thanks so much btw.
Its quite possible NYC has a different stance on it. However I do know for sure NYS inspection as a whole allows for 1 failed rediness monitor (providing there is no CEL)
If there is a CEL it will fail.
Old 08-25-2016, 12:57 PM   #684
bababooey
Drives: BRZ SWP Limited -6MT
try this.
http://www.ft86club.com/forums/showt...37#post2660037
bababooey is offline   Reply With Quote
Old 08-26-2016, 12:31 PM   #685
Teseo
Drives: frs
Which afr is "normal" (safe?) with the stage 2 uel tune?
Mine are on 14.xx range. I will try data loggin when found an open road
Old 08-26-2016, 05:13 PM   #686
steve99
Drives: FT86
Should follow the values in the Open Loop Fueling Table under load
Rough guide to expected AFR (Naturally aspirated on petrol)
Cruise and idle around 14
Overrun –throttle closed will often read 20
Under load low to mid RPM , AFR around 12-13
Under load high RPM , AFR Mid 12 than tapering to maybe high 11 over 7000 on OFT tunes.
Have a read of the Ecu Logging link below (green one)
Teseo (08-26-2016)
WTB: Open Flash Tablet TOZER Canada Classifieds 3 07-05-2015 08:13 PM
Open Flash Header & Open Flash Tablet Calavera Engine, Exhaust, Bolt-Ons 9 05-11-2015 09:27 PM
FS: open flash headers / open flash tablet - SOLD alanhung85 Canada Classifieds 12 02-10-2015 03:08 PM
FS: Open Flash Tablet (OFT) mex2309 Engine, Exhaust, Bolt-Ons 1 10-29-2014 03:49 PM
Open flash tablet. cooldandani Scion FR-S / Toyota 86 GT86 General Forum 1 02-22-2014 08:14 PM
