| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
Drives: Subaru BRZ
Oil filter punctured wrap, does it matter?
Purchased an OEM Subaru filter for the BRZ online...came in a sealed carton but the plastic wrap of the actual filter itself has a puncture. Not sure how this is possible as it's been sitting in a sealed box. Will the puncture affect the performance of the filter? I've read something about moisture making filters go bad and the point of a (sealed) wrap is to keep moisture out. Am I over thinking it?
'16 SWP BRZ
#2 |
Thanks
Its fine
#3 |
I wouldn't worry about it and just use it..........
![]() humfrz |
#4 |
Yes. Screw that puppy in there and forget about it.
#5 | |
Drives: 2005 Toyota Camry
Thanks. (the wrap is there because there's a tiny bit of lube on the rubber gasket. it's there so that the lube stays and doesn't stain the packaging) -alex |
#6 |
Drives: 2016 BRZ
#7 |
Panda Trueno
Drives: No twin now.
You're fine.
#8 |
Drives: 2015 WRB BRZ Premium
Be careful. I hear that if you combine an oil filter with punctured packaging and a clock that has the colon blinking catastrophic failure will occur immediately.
2015 WRB BRZ - Nameless - Raceseng - Eibach - Whiteline - Cusco - Perrin
| The Following 5 Users Say Thank You to Nickosport For This Useful Post: | Boomerang (08-04-2016), gramicci101 (08-04-2016), soulreapersteve (08-04-2016), Tcoat (08-04-2016), Tectoniic (08-05-2016) |
#9 |
Sarcastic SOB
The filter is a preventative device if particulate in the oil exceeds tolerances.
Similarly, a condom is a preventative device, also wrapped to ensure it's effectiveness. That said, I would NEVER use a condom that was in a opened packet. TOSS IT! ...joking!
#10 |
Power Ranger Elite
Drives: '13 WRB Sport-tech
Most off the shelf oil filters don't come plastic wrapped in the carton. if you don't believe me go to any walmart and start opening up oil filters.
tl;dr you're fine.
#11 | |
From Keep a Word:
| The Following 4 Users Say Thank You to Tcoat For This Useful Post: | Boomerang (08-04-2016), soulreapersteve (08-04-2016), Ultramaroon (08-04-2016), wbradley (08-04-2016) |
#12 |
Someplace in here there is a thread where a guy changed his own oil for the first time ever and left the plastic on the filter. He may have been thinking the same way.
#13 |
86
oh no....
| The Following User Says Thank You to Boomerang For This Useful Post: | Ultramaroon (08-04-2016) |
#14 | |
Sarcastic SOB
Magnum?
| Impressive Wrap Vinyl wrap Thread Discounts For Forum Members | ImpressiveWrap | Southern California | 4 | 05-26-2017 02:59 AM |
| Good carbon fiber vinyl wrap for ABS spoiler to wrap it? | dssence | Cosmetic Modification (Interior/Exterior/Lighting) | 15 | 02-07-2014 05:31 PM |
| Car Wrap / Foil Wrap : Pros and Cons? | LeBryan | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 06-25-2013 10:13 PM |
| Does CAI brand matter or just the filter? | ngabdala | Engine, Exhaust, Transmission | 16 | 08-26-2012 02:36 AM |
| ARE YOU GONNA BUY IT NO MATTER WHAT | serchmarc | Scion FR-S / Toyota 86 GT86 General Forum | 97 | 03-19-2011 06:27 PM |
