Old 08-03-2016, 07:24 AM   #1
select20
Drives: FRS Pearl White
Slight engine stutter when AC is running?
This only happens when it's like 90+ outside and it's very noticeable. If I'm running the AC at night or when it's not as hot, it never stutters. Also, it's a consistent stutter, like every 3 seconds.
Really curious if anyone else has had this.
select20 is offline   Reply With Quote
Old 08-03-2016, 07:37 AM   #2
Everybody has this. The compressor kicks in and out a lot. Small displacement engines have to struggle a bit. Not a problem so don't worry.
Old 08-03-2016, 10:44 AM   #3
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Well known issue, even higher displacement motors I know do this, I've seen coyote powered 2012-2016 mustangs do this as well. It's just the sudden load on the motor. Also our compressors cycle on an off, on what I believe is a pressure based switch, so it may be a consistent on and off engagement of the compressor which is normal.
Old 08-03-2016, 03:59 PM   #4
Sigh-on-Rice
Waited 5 years for this
Sigh-on-Rice's Avatar
Drives: '18 MX-5 Club
Mine does this too sometimes. When it does it, it does it for the whole trip. When it doesn't, it doesn't for the whole trip. BUT, mine does it when the compressor kicks in, which is about 10 to 15 seconds. Not 3 seconds.
Old 08-04-2016, 02:28 AM   #5
I just returned from the warm side of our state (98 degrees F) and noticed the engine would "pull down" a bit (especially at idle) when the A/C compressor would kick in, also the idle would be a bit rougher.
If you would call that a "stutter" then yes.
Back-in-the-day ....... a "stutter" would be like a spark plug was fouled...
Old 08-04-2016, 02:42 AM   #6
If you listen carefully, engine RPM actually drops momentarily when the compressor clutch releases. At least mine does.
Also, every 3 seconds doesn't sound right. Did you mean to type "30?"
Old 08-14-2016, 08:44 AM   #7
select20
This is exactly what it makes me think of, except it only does it when the AC is on.
No I did mean 3 seconds. Maybe more like 3-5, but I'm not exagerating. Only when the AC is running on a hot day. If the AC is going at night, or just when it isn't hot, it never "stutters" or what ever you want to call it.
Also, sorry to take so long to get back, had some "technical" problems. With phone/pc/internet. I think it was the storms.
Old 08-14-2016, 08:46 AM   #8
select20
Ok well, that makes me feel better. Some times it will "stutter" multiple times and the AC doesn't come back on. If it takes a few minutes to kick back on and I start getting hot, I'll just hold in the clutch and rev the engine to 5k+ and it pops back on immediately.
Old 08-14-2016, 02:59 PM   #9
What you're describing sounds to me like what's called "idle hunt" which happens when something throws off the air-fuel mixture in a manner which the ECU is unable to control. The most common is a vacuum leak.
Old 08-14-2016, 03:03 PM   #10
You might consider taking your car into a shop that has a A/C checking/repair capability and have the refrigerant level checked.
Sometimes when a compressor is low on gas, it can give weird signals that might affect the engine.
Back-in-the-day ..... I'd guess that your cooler was low on ice ......
Old 08-14-2016, 04:05 PM   #11
Muaddib
Mentat
Muaddib's Avatar
Drives: 2013 Scion FRS 6MT
Idle at 2k rpm and you will be fine.
Muaddib is offline   Reply With Quote
Old 08-16-2016, 08:50 AM   #12
select20
Thanks for all the replies everyone. Much appreciated. Will take it to shop and get it checked just for peace of mind.
Old 08-16-2016, 11:20 AM   #13
FX86
my A/C always turns off because I can't stop redlining it with the pedal to the floor...then you start feeling really hot...that's how those race car drivers must feel with no A/C i guess
Old 08-16-2016, 01:33 PM   #14
Dang hot rod ........
Car running poorly after check engine light cleared AlexK Engine, Exhaust, Transmission 4 07-07-2015 04:16 AM
Slight buzz at 1,500 RPM ericmpena Engine, Exhaust, Transmission 5 05-02-2014 09:35 AM
Why does it stutter when I accelerate? dro Scion FR-S / Toyota 86 GT86 General Forum 9 10-14-2013 02:29 PM
Owner's manual slight confusion about engine break in period... davey90 AUSTRALIA 48 09-05-2012 10:51 PM
Toyota FTS report engine issues with FR-S running 91 octane DYOLF26 Issues | Warranty | Recalls / TSB 24 08-06-2012 02:22 PM
