Old 07-30-2016, 12:12 AM   #1
Nightflo
Nightflo's Avatar
What motor oil to use on a jacksonracing supercharged brz?
Hey guys,
Im pretty much new to this forum but I've been on it for quite a while before I made an account. Needless to say, this is my first post.
I currently running the Jackson Racing c38 supercharger on my brz, bigger injectors, pump, flexfuel etc.
I was wondering what type of motor oil I should use for oil changes.
Some people say, stick to 0w20 while others are telling me to get motul 5w30.
I need a tiebreaker xD btw, i live in central california wheres its normally 100+ degrees.
please help =(
Nightflo is offline   Reply With Quote
Old 07-30-2016, 01:16 AM   #2
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Well, your hear a bunch of options.
I would hit up Jackson Racing customer service, and ask them what they would recommend.
I'm pretty sure that's the best way to go. Other wise everyone and their mother will tell you to put X brand and X weight.
I would stick to the factory oil spec till you hear from them.
Also FYI Motul isn't all that. Just a different oil brand. Nike vs. Reebok. Which fanboy base do you want to be in?
I'm a Mobil 1 fanboy, reason: Walmart cheap, find it anywhere 24/7 7 days a week. Even in the middle of bumfuck vile.
Other brands like Motul. Special order, wait a few days a bit pricey. For same exact performance.
The Following User Says Thank You to Mr.ac For This Useful Post:
BRZHarley (07-30-2016)
Old 07-30-2016, 02:12 AM   #3
I'd recommend 0w20 Mobile 1.
Old 07-30-2016, 02:15 AM   #4
byun
byun's Avatar
Drives: 2015 BRZ CWP
I've been running amsoil 5w30 for 6k miles.
byun is offline   Reply With Quote
Old 07-30-2016, 02:40 AM   #5
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Your oil will have high temperatures with a supercharger. You will need at least a 5w30 oil. It will be slightly thicker in cold temperatures and provide the necessary protection in high temperatures. Using a 0w20 oil even with an oil cooler is like submitting suicide.
Motul is also a good choice . It is used by STi for many years.
Old 07-30-2016, 03:14 AM   #6
TMW
Drives: 2013 Subaru BRZ
Originally Posted by Nightflo View Post
Hey guys,
please help =(
I have the c30, 700cc injectors, pump, flex fuel, pretty much your same setup. Also live in central california. I run 0w20. but that's because i'm not tracking/autocrossing. The most I do is spirited driving, occasional redline pulls, but that's about it. Usually just out-and-about driving. you don't need a heavier oil if this is all you do. if you plan autocrossing or tracking, run a thicker oil.
edit: central coast for me... i totally glazed over "100+ degrees". I don't have temps that high where I live haha.
TMW is offline   Reply With Quote
Old 07-30-2016, 03:28 AM   #7
swarb
http://www.ft86club.com/forums/showthread.php?t=91820
The Following User Says Thank You to swarb For This Useful Post:
LXXXV1 (04-04-2017)
Old 08-08-2016, 10:58 AM   #8
VABeachBRZ
Is amsoil 5-30w the best bet with c38, 700cc dw injector, 300cc dw and flex fuel
VABeachBRZ is offline   Reply With Quote
Old 08-16-2016, 07:43 PM   #9
Spinning Sushi
Legend
Spinning Sushi's Avatar
Drives: BRZ Limited
I've been boosted for over 30k miles and I've done nothing but Eneos 0w20
Spinning Sushi is offline   Reply With Quote
Old 08-18-2016, 12:12 PM   #10
xsnapshot
Fast enough
Drives: 2013 Subaru BRZ AT
Nothing about your motor has changed other than the power output. Oil galleys/clearances/bearings/etc was all designed for 0-20. Use a quality synthetic 0-20.
If your oil temps are staying within range there is absolutely no reason to switch to a heavier oil.
xsnapshot is offline   Reply With Quote
Old 08-18-2016, 01:23 PM   #11
bluesubie
Drives: 2004 Subaru Forester 2.5XT
Increasing the power output alone is a good reason to switch to a heavier oil, IMO. Oil temps alone do not tell you anything about your film strength and whether or not the HTHS and kinematic viscosity are sufficient for bearing protection in a particular application.
I hear a lot of talk about this engine being "designed for 0W-20" although Subaru Japan allows thick Euro 0W-30 and 5W-40 in a stock BRZ.
http://www.subaru.jp/accessory/engin...miumoil01.html
http://www.subaru.jp/accessory/engin...miumoil02.html
bluesubie is offline   Reply With Quote
The Following User Says Thank You to bluesubie For This Useful Post:
B T (08-24-2016)
brz frs supercharged oil
RGM Supercharged 86 GeeTee86 AFRICA 63 08-16-2015 10:07 AM
charged86 supercharged to build motor turbo charged86 Member's Car Journals 9 07-25-2015 12:48 AM
Seized motor!! What STX mods should I do while I have the motor out?? BlaineWasHere Tracking / Autocross / HPDE / Drifting 27 12-11-2014 03:39 PM
my supercharged brz zenny Member's Car Journals 17 04-29-2014 09:46 AM
My Supercharged GTS Aussie Willy Member's Car Journals 23 07-12-2013 07:06 PM
