Old 07-27-2016, 04:21 PM   #1
SlammedSilly
Drives: 2015 Ultramarine FR-S
Humidity Issue?
whats going on guys, so i have a quick question for ya guys... anyone in the northeast area of the country of the great country of the USA (philadelphia) have any issues the past week or so with their clutch pedal feeling really spongy? i think its just the humidity, but idk...
ALSO....
im OFT stage 2 UEL on 93oct, anyone having a horrible lag issue with throttle response? i think its JUST humidity, but was curious to see if anyone else has had the issue?
SlammedSilly is offline   Reply With Quote
Old 07-27-2016, 05:49 PM   #2
I'd guess your observations are due more to the heat than humidity...........
Ultramaroon (07-28-2016), zc06_kisstherain (07-27-2016)
Old 07-27-2016, 06:47 PM   #3
SlammedSilly
see the heat is at like 90-98 degrees with humidity... but the heat can make it lag that bad??? its got like a 2/3sec hesitation before the throttle feels like it actually does something
Old 07-27-2016, 07:11 PM   #4
Well, the heat may be affecting the hydraulic clutch feel if there is some air in the lines. If that's the case, bleeding the system would eliminate that possibility.
As far as the increased lag with higher temperatures, other than noting that warmer air carries less oxygen, I'm really not sure.
Captain obvious is asking if you're running the A/C more ..... ??
SlammedSilly (07-28-2016), Ultramaroon (07-28-2016)
Old 07-28-2016, 09:10 AM   #5
SlammedSilly
captain obvious should know A/C is for noobs who cant stand the heat, haha. but yea im def going to bleed the system to make sure theres no air, idk how that would of happened, im just gonna blame toyota for this
The Following User Says Thank You to SlammedSilly For This Useful Post:
humfrz (07-28-2016)
Old 07-28-2016, 09:53 AM   #6
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
Heat and humidity is pretty much a full time thing here in Florida. I don't have either of the probs the OP has. I think you have something else going on.
guybo is offline   Reply With Quote
The Following User Says Thank You to guybo For This Useful Post:
Tcoat (07-28-2016)
Old 07-28-2016, 10:03 AM   #7
SlammedSilly
see i plugged my oft in, and had my friend watch the real time data, and he said everything looked absolutely fine, so idk, on top of all this my friend who works at a toyota dealer said that the clutch feels terrible in my car, hes like granted you have 30k on it, but something is not ride, im gonna bleed the slave and go from there and see what happens
Old 07-28-2016, 12:19 PM   #8
shellslinger
Drives: Whiteout FRS
Super easy to bleed the system too. Takes like 5 minutes with the vacuum.
shellslinger is offline   Reply With Quote
Old 07-28-2016, 01:49 PM   #9
stevesnj
stevesnj's Avatar
Change your brake and clutch fluid and then get a steak extra cheese wit!! or 2
My 2016 Build thread
The Following User Says Thank You to stevesnj For This Useful Post:
Old 07-28-2016, 03:23 PM   #10
SlammedSilly
HAHAHAH, YAAAAS! well you know your not from philly when you have a pic of pats/geno's hahah, gotta explore ya cheesesteak taste buds
stevesnj (07-28-2016)
Old 07-28-2016, 03:45 PM   #11
scmil95eg
Drives: '95 delSol, '13 EvoX, '14 Leaf
Geno's > Pat's
*drops mic*
scmil95eg is offline   Reply With Quote
The Following User Says Thank You to scmil95eg For This Useful Post:
Old 07-28-2016, 04:04 PM   #12
SlammedSilly
OREGON STEAKS OVER ALL
Old 07-28-2016, 09:56 PM   #13
stevesnj
stevesnj's Avatar
I've been eating Pat's forever, I heard Oregon has good steaks, gotta try it. But I tried Geno's 3 times and to me they were just awful, better roll but crap on the inside.
SlammedSilly (07-29-2016)
Old 07-29-2016, 11:07 AM   #14
SlammedSilly
i 100% agree with you, im a pats over geno's kinda guy! but you def need to try this place.... http://dalessandros.com/
you will be in heaven, not the greatest are after 10pm, but if you go with a group of people, you'll be fine! but day time is completely fine
stevesnj (07-29-2016)
AT frs rpm issue ricebox Issues | Warranty | Recalls / TSB 18 01-04-2016 02:01 AM
OFT IAM issue Tectoniic Software Tuning 23 10-28-2015 06:52 PM
Need help with FI issue!! Jhood Forced Induction 16 09-07-2015 11:04 PM
a little issue here Asian Delight Electronics | Audio | NAV | Infotainment 8 02-10-2014 04:32 PM
LED DRL issue CaptainSlow Cosmetic Modification (Interior/Exterior/Lighting) 4 08-12-2013 06:15 PM
