#15 |
Drives: 2015 FR-S
Is it possible to just remove the ECU, put a used one in and flash that one and then if the situation arrives there, put the original unflashed one back in?
#16 | |
Drives: FT86
They might be talking BS about the flash counter, i cannot find it in techstream software toyota uses. ecu replacement see here Replacing a Bricked ECU with new or used ECU (engine control Module) http://www.ft86club.com/forums/showthread.php?t=102810 . |
#17 | |
Drives: 2015 FRS Asphalt
The Servco Hawaii service center I go to the service rep told me about the Mossman warranty thingy. He said they would have to prove the aftermarket part caused issues/failures with the car. When I was interested in TRD exhaust he said, "$1300.00 for TRD exhaust is a waste because you can buy a better after market one!" He told me I wouldn't violate my new car warranty and extended warranty with a aftermarket exhaust. As long as the stock header is not switched out the warranties would be fine.
#18 | |
hey you, yeah you <3
Drives: 2014 37J FR-S
| The Following User Says Thank You to Packofcrows For This Useful Post: | nikitopo (07-13-2016) |
#19 | |
Huge E85 fan!
Drives: 2016 Scion FRS
I asked specifically about the header and the service mgr said it's not a problem. Of course, he also said if there's a warranty issue that the stock header can be switched out pretty easily.... |
#20 | ||
Drives: Full race 4cyl boxer
Them asking you to reinstall all OEM parts is not fraud (especially considering it is a Toyota EMPLOYEE telling you to do it) they need to have the car in OEM condition for their diagnostics to work. Even if they know that you had aftermarket parts on the car they need it back in original condition to diagnose it properly. Quote:
Yes the sensors that control the engine ARE covered under the powertrain warranty. If it makes it go, it is powertrain. The ECU is covered, therefore the sensors that feed the ECU are covered. I believe there is an exception for O2 sensors in the extended warranty, but not sure (they are certain to wear out before 100,000 and depends on the quality of your gasoline) |
#21 |
Off Topic
Yes it is. The Toyota dealer and Toyota USA are two separate entities. Warranty repairs are paid for by Toyota USA on the dealer's recommendation. So the dealer is saying they'll conceal the potentially warranty-voiding mods and misrepresent the issue in order to get money out of Toyota USA. Which is the textbook legal definition of fraud.
#22 |
Drives: 13 frs red
My first motor expired at 20k. Rocker arm. Dealer saw perrin crank pulley and told me to bring stock pulley in. For some reason Toyota instructed mechanic to inspect main bearings. New shortblock was the result. That lasted 500 miles. Cam gear issues. Finally got a complete motor, ecu, all new plumbing etc.No problems since. Im rather grateful. It could've been worse.
#23 | |
Its the same as a Police officer telling you to make a U-turn when no U-turn is allowed. Did you break the law or not? |
#24 | |
Off Topic
#25 | |
If the authority (the Dealer tech representative) tells you: "Put your stock parts back on and bring it in" If you follow his instruction you are NOT committing fraud. You are following instructions. You have NO IDEA what he intends to do with corporate. Using your logic, if I make a bank deposit, and the teller steals that money and buys illegal drugs, I assisted with the law breaking? NOT |
#26 | |
Off Topic
#27 | |
If the dealer says: "Put your OEM parts back on and bring the car in so I can run standard Toyota diagnostics on your problem" (Which I have personally SEEN a tech tell a customer) You are NOT committing fraud. Period. If the dealer says: "Put your OEM parts back on and bring the car in and I wont tell corporate, wink wink, nudge nudge" You are assisting in the dealer committing fraud. "Your example makes no sense and doesn't relate at all." And the example definitely DID relate. If I give someone cash for one thing and they use it for another (illegal) thing, did I help commit the crime or not? NO Because they did not use the cash for what it was intended for. SAME with the car example. If I put the parts back on to assist with the diagnostics (what I was told) and the DEALER uses it for something else (say to pass an inspection from corporate) then my actions are NOT assisting in fraud. Last edited by justatroll; 07-13-2016 at 02:47 PM. |
#28 |
Drives: ̶1̶0̶ ̶S̶
Seriously guys? Fraud? Toyota manufactures the car, and the dealer sells and maintains it thereafter. If a dealer is telling you to put oem parts on/reflash and bring it in so they can work on it, why are you complaining? If you feel guilty about "lying" to a corporation, you've got bigger problems.
| Why does the Toyota service manager email me offers, and then never responds | pasternak | Scion FR-S / Toyota 86 GT86 General Forum | 21 | 06-20-2016 12:33 PM |
| Quick question openflash manager and flash tablet manager | Nisien | Software Tuning | 3 | 02-28-2016 04:08 PM |
| Navigation Fix...Interesting Conversation | BRZJonny | BRZ First-Gen (2012+) — General Topics | 11 | 06-13-2013 05:15 PM |
| asked dealer service manager about aftermarket/warranty | NuckinFutsFR-S | Issues | Warranty | Recalls / TSB | 23 | 10-31-2012 09:24 AM |
| Video: Toyota FT-86 II Concept Design Explained by "Dezi" Nagaya (Design Manager) | Hachiroku | Scion FR-S / Toyota 86 GT86 General Forum | 58 | 04-11-2011 10:03 PM |
