Old 07-12-2016, 11:30 AM   #1
1Cor10:23
1Cor10:23's Avatar
Drives: '13 Whiteout FR-S (M/T)
AP Sprint clicking noise when turning
Hi there,
Wondering if anyone else with the AP kit has had "clicking noises" when turning? Most noticeable at relatively low speeds at sharper turning angles - could it be combination of floating rotors, j-hooks, and piston angles when turning?
Sounds like a metal-on-metal click, perhaps 2-4 times per revolution.
Thanks!
1Cor10:23 is offline   Reply With Quote
Old 07-12-2016, 11:45 AM   #2
Chico
Drives: '14 BRZ WRB
Originally Posted by 1Cor10:23 View Post
Hi there,
Thanks!
Yes! I installed the AP kit in the spring and the last two times at the track I've noticed a loud clicking noise when turning left or right. Haven't heard it street driving. I just assumed it was the brakes.
Chico is offline   Reply With Quote
The Following User Says Thank You to Chico For This Useful Post:
1Cor10:23 (07-12-2016)
Old 07-12-2016, 07:50 PM   #3
byun
byun's Avatar
Drives: 2015 BRZ CWP
I don't have the AP kit buy I had a clicking noise with my Stoptech kit and found the noise coming from where the lines mount to the hard line on the fender wall. The clip from goodridge lines that I have that holds the line in there worked itself loose and when turning almost full lock left or right caused a click/tapping noise when turning.
Put new clips in that i had from an old stoptech kit and got rid of the noises. not sure if it helps, but could be a place to look.
byun is offline   Reply With Quote
The Following User Says Thank You to byun For This Useful Post:
CSG Mike (07-12-2016)
Old 07-13-2016, 01:07 PM   #4
1Cor10:23
1Cor10:23's Avatar
@byun thanks for the suggestion - will take a look!
Old 08-12-2016, 09:43 PM   #5
1Cor10:23
1Cor10:23's Avatar
@JRitt any thoughts?
Sent from my ONEPLUS A3000 using Tapatalk
Old 08-12-2016, 10:23 PM   #6
BRZtoni
Turbo E85
BRZtoni's Avatar
Drives: 13 wrb brz
Check for anything making contact.
My sprint kit doesnt click andni tracked it 3 times with it so far since installation
Flex Fuel Turbo BRZ
BRZtoni is offline   Reply With Quote
Old 08-12-2016, 10:36 PM   #7
1Cor10:23
1Cor10:23's Avatar
@BRZtoni I'm wondering if it's related to wear on the rotor. It's just funny that I get noise on both sides now. Probably 8 track days on the set now.
Old 08-13-2016, 12:01 AM   #8
cjd
cjd's Avatar
Drives: 2017 BRZ
I'm pretty sure the Sprint does not have a floating setup... from their site:
  • Aluminum hats on Endurance discs are floating, while hats on Sprint discs are bolted
If yours is floating, perhaps it needs to be tightened up?
That said, no noises from mine, but I probably abuse them far less. If it's a new noise, I'd suspect wear related or heat-cycle related. Inspect all fittings and fasteners.
Old 08-13-2016, 10:43 PM   #9
BRZtoni
Turbo E85
BRZtoni's Avatar
Drives: 13 wrb brz
im going to say i doubt its the rotors considering the main point for me to buy these BBK was that the rotors can last a lot of track times
like the other poster said, check the rotor top hat maybe it got loose?
Flex Fuel Turbo BRZ
Old 08-14-2016, 02:29 AM   #10
1Cor10:23
1Cor10:23's Avatar
Retorqued a couple of weeks ago but I realize now I only did 10ftlbs and not the 18 for the fixed style of the sprint rotors... woops. But no movement at 10ftlbs, likely none at 18 as well but will check.
The Following User Says Thank You to 1Cor10:23 For This Useful Post:
BRZtoni (08-18-2016)
Old 08-23-2016, 08:12 AM   #11
CrispyCheddar
CrispyCheddar's Avatar
Drives: the white one
Did you solve this?
How do you have your brake lines routed? It could be rubbing on your wheel. A line rubbing on the wheel weight would make that clicking noise.
If it is rubbing on your wheel, it is more than likely wearing out that one spot on your brake line, which could end up bad if it rubs all the way through
If you can't win a race, beat the person in front of you
CrispyCheddar is offline   Reply With Quote
Old 08-25-2016, 09:16 AM   #12
puma
crew chief
puma's Avatar
Drives: Race car FR-S
we have that problem with the Racer-X lower control arm and AP sprint kit, when completety turned the lower ball joint makes contact with the disk, must not be a problem with the stock LCA but worth a check.
puma is offline   Reply With Quote
Old 08-26-2016, 01:44 PM   #13
Tenino
Drives: 13' BRZ
For those that are in pinch and do not have extra clips laying around, your local O'reilly's has them for $2 (Box of 4).
According to O'reilly's it also fits Subaru Forester, Impreza, and Outback. If you want "OEM" your local dealership should carry it as well. Just look up the year model and cross reference etc.
BrakeBest Hardware & Hydraulics - Brake Hose Lock (Part #H1457-2)
http://www.oreillyauto.com/site/c/de...0265&ppt=C0064
Tenino is offline   Reply With Quote
Old 08-26-2016, 09:26 PM   #14
Sleepless
Sleepless's Avatar
Drives: 2014 BRZ
My guess is slightly uneven pad deposits on the rotors which make contact with pads when turning. I believe the AP calipers don't have pad tensioners so they can click.
Sleepless is offline   Reply With Quote
Clicking/cloncking from left front when turning wheels cawith Issues | Warranty | Recalls / TSB 14 02-08-2019 06:14 AM
Wilwood BBK Clicking Noise AlexK Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 03-24-2016 08:38 PM
Clicking noise from exhaust? azynneo Issues | Warranty | Recalls / TSB 6 06-16-2015 03:05 PM
Clicking noise in engine bay teddydoggy Issues | Warranty | Recalls / TSB 4 08-12-2013 05:15 AM
Clicking noise? Not crickets... Laika Issues | Warranty | Recalls / TSB 4 10-18-2012 07:39 PM
