go_a_way1
Old 07-06-2016, 03:27 PM   #4047
ka-t_240
Try the Motul Gear 300. But, if there is damage that is already done, then the Motul can't magically undo the damage.
Any better options you have seen for rebuilds?
I have rarely had issues with 4th, but my last track day I had 2 instances where i felt "locked out" of 4th.
Going to do a fluid swap, was already on Motul 300. Was planning to change fluid this spring but it was out of stock at our distributor. Fluid has 15k, and about 15 track days and 30 autox on it.
ka-t_240 is offline   Reply With Quote
Old 07-06-2016, 06:14 PM   #4048
CSG Mike
CSG Mike's Avatar
That is way, way too much time on that fluid. You have to shorten your maintenance intervals if you're driving the car hard.
Old 07-06-2016, 08:04 PM   #4049
FTA_Dave
Drives: 2013 Frs, E46 Bmw
I have just picked up a used FRS to do some stock-c auto-x and HPDE days, The car will also be driven on weekends <10k/yr .Both myself and wife are novices. What would your recommendation be for a good all around tire and size for the stock 17x7 wheels? The RE-71R and Z2-SS seem to be the popular choices and 215/45, 225,45, 235/40 the most used sizing. In regards to brake pads, will a dual purpose compound suffice? Could you recommend a specific pad to meet my needs? Thanks
FTA_Dave is offline   Reply With Quote
Old 07-06-2016, 09:28 PM   #4050
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Do the 225s and buy street pads and track pads or just deal with the dust/noise of the track pads on the street. I like Carbotech pads, but that's up to you.
DocWalt is online now   Reply With Quote
Old 07-10-2016, 09:48 PM   #4051
DarkSunrise
DarkSunrise's Avatar
Has anyone seen wear like this (or rubber buildup possibly) on the inside shoulder of their rear tires? This was my LR tire. RR tire looked similar, but not as pronounced.
This was after an open track day (about 3 hrs total run time) on new RCE T2's and fresh alignment. Tires were BFG Rivals. Alignment was as follows:
Front Left:
- caster 5.8 degrees
- camber -2.4 degrees
- toe 0/0"
Front Right:
- caster 5.9 degrees
- toe 0/0"
Rear Left
- camber -1.6 degrees
- toe 1/16" in
Rear Right
- camber -1.7 degrees
- toe 1/16" in
2022 BRZ Build
2013 FR-S Build
Old 07-10-2016, 09:57 PM   #4052
Panamaniac
I had similar or worst wear. I had Toyos R888s and they would wear really bad on the inside.
We had the same toe in as well. We went for 0 toe and the wear became alot better.
Sent from my SM-G928G using Tapatalk
Panamaniac is offline   Reply With Quote
The Following User Says Thank You to Panamaniac For This Useful Post:
DarkSunrise (07-10-2016)
Old 07-10-2016, 10:07 PM   #4053
DarkSunrise
Thanks. My old alignment had 0 toe in the rear, so that would make sense why I've never seen this before. Hmm... sounds like I may need to go back to 0 toe.
2022 BRZ Build
2013 FR-S Build
Old 07-10-2016, 10:10 PM   #4054
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Yep, my rears have that after a track day at Putnam Park and the 650+ miles home. Similar alignment. In my case it was just rubber pickup, it peeled right off. Looks the same on yours, to be fair.
The Following 2 Users Say Thank You to DocWalt For This Useful Post:
DarkSunrise (07-10-2016), Pat (07-10-2016)
Old 07-10-2016, 11:24 PM   #4055
DarkSunrise
Ok thanks I'm going to try peeling it off tomorrow. Hopefully that's all it is.
2022 BRZ Build
2013 FR-S Build
Old 07-11-2016, 04:36 AM   #4056
CSG Mike
CSG Mike's Avatar
Do you happen to have pyrometer readings?
Old 07-11-2016, 02:24 PM   #4057
DarkSunrise
No tire temp readings unfortunately.
I tried picking at it today. It's stuck on there pretty well and comes off in small bits and pieces. I noticed the inside part of the tread is smooth compared to the rest of the tire surface which is rough/grainy (and elevated a bit in comparison).
Here are a couple more pictures after picking at it.
The more I inspect it, I'm concluding that I'm not using that inside part of the tire and what I'm feeling is either the boundary of OPR or rubber migration towards the inside. To sum it up I think I need more rear camber... which is where I think @CSG Mike was going with the pyrometer comment.
2022 BRZ Build
2013 FR-S Build
Old 07-11-2016, 02:30 PM   #4058
Pat
Pat's Avatar
Drives: 2023 BRZ
I totally agree.
The Following User Says Thank You to Pat For This Useful Post:
DarkSunrise (07-11-2016)
Old 07-11-2016, 02:37 PM   #4059
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
+1 on the agree. I'm at -2.6 and -1.9 and I need more rear camber... you definitely need more. I've done enough autocross and track days that my street driving isn't evening out the wear, so if I keep the BRZ I'll be running more camber next year.
The Following User Says Thank You to DocWalt For This Useful Post:
Old 07-11-2016, 02:37 PM   #4060
Panamaniac
Yeah might agree with that comment of more neg camber. I use 2.5 on the rears with 0 toe
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 07:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 01:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 08:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) — General Topics 11 05-31-2012 08:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) — General Topics 20 01-10-2012 10:54 AM
