Old 07-07-2016, 07:02 PM   #1331
steve99
Drives: FT86
All you aussie guys will be better running @Waynos maps
Old 07-07-2016, 07:12 PM   #1332
steve99
Drives: FT86
Originally Posted by GenRuleAThumb View Post
Just did a quick data log to have you guys take a look and make sure everything looks good.
JDL UEL no cat
Top Speed Axelback
CAN 91 pisswater
Stage2 UEL Map
Car was warmed up for 5 min, then a short drive with 2 small pulls at the end. Just want you guys to take a look and make sure it all looks normal. Car runs great for the most part although last night had a weird hickup under <15% throttle a couple times, did not happen during the log or at all this morning.
http://datazap.me/u/genruleathumb/sc...t?log=0&data=1
Iam is 1
no fbkc
you did not log flkc but looking at the KC Learned looks fine
the only issue is its running quite rich 11.2 and while thats safe it will cost you some power , you will need to do some maf scaling to correct it, the bogging at low rpm is likely due to load limits
Old 07-07-2016, 07:29 PM   #1333
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
All the openflash tunes are safe in the short term due to the factory ecu logic, they just may not live up to their potential is all.
With mine all you need to max them out is select between 2 maf scales.
If you're on E85, flash the US.Rich scale, drive 150km after flashing or filling up, then log WOT 3rd gear from 2500-7500. If it's richer than about 11.8 AFR @ 6800 then switch to the US.Lean scale.
Just don't base decisions on data logged straight after flashing on E75 or so, because fuel trims won't have settled correctly.
The process is the same on 98 except that you can log after filling up, provided you haven't switched from E85 recently.
Originally Posted by fibble View Post
Thx Wayno.
Just to check 100% - I think you are saying that aside from checking MAF scaling on Stg2, you feel that your Stg1 and Stg2 (Petrol and E85) maps are safe enough for us to run (on Aust 98 and E85) even without visibility of FLKC, KC, IAM, etc?
Are these the v107.2 files at the bottom of your helpful post here:
http://www.ft86club.com/forums/showthread.php?t=83945 ?
I imagine we use the v106 definition files you have listed?
I assume we use A01G as the base?
Unfortunately, not all tables are the same scale/values across ROMS so a little bit of extra work to convert for D00G (e.g. fuelling).
Agreed - same on my logs. This supports my assumption that Openflash pushed an update to OFT over the last few days via OFM.
Cheers
Old 07-07-2016, 09:08 PM   #1334
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Originally Posted by Rezi View Post
@Wayno Multiplying the MAF Cells did the trick. It follows the Commanded 1:1 at 3.44v and above. THANKS!
FLKC was also reduced.
Also, it seems that my FBKC is going crazy with AC activated, everytime the AC kicks in and i am on the throttle it seems to detect "false knock". Is that normal?
IAM dropped down to 0.98, but i think it is because of the AC. I will give it a another week of learning time for the knock-sensor.
AFR / IAM drop: http://datazap.me/u/rezi/16063?log=0...rk=3357-819-93
FBKC with AC on: http://datazap.me/u/rezi/16061?log=2...zoom=3140-4880
FYI, Intake Temperature was around 87F-90F
Out of curiosity I took a couple of logs with my AC on. No WOT to redline pulls just regular driving loads. Aside from some tick tack flkc here and there (-.34*) there's no knock correction worth noting. My fuel trims actually look slightly better than with AC off. That was rather unexpected. Fuel trims will tend to go a few percent positive at and near idle speeds with AC on. My high temp fueling compensation was slightly off toward - fuel trim. With AC on, it evened it right out to 0% LTFT. lol
http://datazap.me/u/solidone/z6-kc1h...&data=1-8-9-11
As knock free as this log looks I'm pretty sure if I punched the throttle with the AC on I would see some knock correction where I typically wouldn't or more knock correction where it is minor with AC turned off.
Intent > Content
Old 07-07-2016, 09:33 PM   #1335
Rezi
Drives: GT86
The Knock Correction on mine happened when i stepped on the throttle with AC on. When the AC kicks in i can feel it, so can the knock sensor?
On WOT the AC automatically shuts off.
Anyways, i'm gonna stick with wayno's v107 98 stg1. I think i ruined my tune with pulling timing over the couple of months. It doenst feel peppy anymore between 4000 and 6000 when WOT :/
A friend of mine has OTS stg1 91 from vishnu. He has absolute no knock, never, even if it is hot. Overall i am running about 2,5degree less advance. And this is driving me nuts.. And he is driving with 98 octane i never heard of.
Rezi is offline   Reply With Quote
Old 07-07-2016, 11:28 PM   #1336
solidONE
solidONE's Avatar
I rarely take logs with AC on, though I always have my OFT hooked up. So the change in fuel trim and knock correction is just something I observed. I don't really bother with AC since I always turn it off when I'm driving the car hard. Maybe it's more of a concern for others, but I dont worry too much about performance with AC on unless I catch something really off, which I haven't so far.
Why not try the fuel your friend is using? Maybe it's just better fuel he is using?
Intent > Content
Old 07-08-2016, 12:09 PM   #1337
Rezi
Drives: GT86
Wow..
Wayno's v107.2 Stg1 solved all my problems.
Zero knock on WOT, unbelievable...
http://datazap.me/u/rezi/0807wot?log=0&data=1-12
The Following User Says Thank You to Rezi For This Useful Post:
solidONE (07-08-2016)
Old 07-08-2016, 07:49 PM   #1338
CZ6T
Drives: 2022 crystal white BRZ
Hey guys, ended up picking up an OFT and flashed the stg2 EL E85 map onto the car.
I'm not getting anything at all for my IAM, and the FLKC is consistently -5. From the other logs I've seen that means its pulling loads of timing, right? It seems really odd that it never budges from 0 at anytime, so maybe the ECU didn't take the flash, although it seems to run very well.
The CalID for my car is ZA1JF00C, iirc.
http://datazap.me/u/cz6t/log-1468013...a=1-7-12-13-14
CZ6T is offline   Reply With Quote
Old 07-08-2016, 09:22 PM   #1339
steve99
Drives: FT86
it looks like the logging does not work for soke parameters on your rom, contact the oft guys.
from what i can see it looks ok using kc leanred.
logging for flkc iam is not working correctly
Old 07-08-2016, 10:20 PM   #1340
CZ6T
I've sent them an email, so I'll just have to wait and see what's going on. It's a releif to know it doesn't look realy terrible, though. I'll take it easy for a few days and see if it starts developing knock or not, and hopefully the ltft will be nice.
Old 07-08-2016, 10:26 PM   #1341
steve99
Drives: FT86
you can see knock with the KC Learned parameter, you need to open your tune in romraider and go to the Knock Correction max A table then compare the values in that table at some load and rpm points to the kc learned values you see in log if they are close then you have no knock and iam is 1, i had a quick look and it seems fine
afr looks ok and ltft is ok for e85
Old 07-09-2016, 03:43 AM   #1342
fibble
Drives: 2015 86 GTS
Hi guys,
Stock D00G car running Wayno's Stg 1 98 v107.2 tune.
Fuel - Caltex Vortex 98
2 Logs attached:
http://datazap.me/u/fibble/oft-stage...o?log=0&data=1
Note: ignore FLKC due to problems with OFT.
Still seems to be some knock and trims look a little out with AFR a little rich.
Thoughts on whether there's still work to be done (timing and fuelling) or acceptable for Stg 1 tune on my car?
Wayno - this is with AVCS in v107 (not experimental).
Thx
KCA Max A attached below:
fibble is offline   Reply With Quote
Old 07-09-2016, 04:14 AM   #1343
Wayno
Wayno's Avatar
Looks fine to me. It may get leaner. Do at least 150km before you judge fuel trims.
Hi guys,
2 Logs attached:
Thx
The Following User Says Thank You to Wayno For This Useful Post:
fibble (07-09-2016)
Old 07-09-2016, 04:19 AM   #1344
fibble
Drives: 2015 86 GTS
No probs - will do the extra ks.
Also noted experimental Stg 1 AVCS is significantly more conservative on both Intake and Exhaust.
Something you found or suspect?
RGM Supercharged 86 performance data TheGooseman AFRICA 14 12-13-2014 02:15 AM
Interpreting Ecutek Data Logs? cuddefred Software Tuning 3 09-02-2013 01:55 PM
VIR - Impressions/Pics/Logs/Video (Track Daze) swift996 Tracking / Autocross / HPDE / Drifting 39 08-30-2013 10:21 AM
Noise tube delete air/fuel logs? jm1681 Engine, Exhaust, Transmission 13 10-17-2012 05:57 PM
ECU Data Logger Motordyne Engine, Exhaust, Transmission 5 07-18-2012 10:27 AM
