Old 07-03-2016, 12:51 PM   #1
euthqt
Drives: 2013 Scion FRS 10 Series AT
Strange Wire on floor?
Hey guys. So today I got in my car to see a wire and connector under my steering wheel on the floor. I'm not sure what it is or what it goes to but I crawled under and looked at the wiring under the dash and nothing looks to be missing or out of place, so I'm not sure. Thanks in advance.
euthqt is offline   Reply With Quote
Old 07-03-2016, 01:09 PM   #2
JD001
JD001's Avatar
Drives: Subaru BRZ
I haven't the foggiest idea about the wire but how come you are taking photos of dubious electronic contraptions in your bathroom??
Old 07-03-2016, 01:31 PM   #3
Peaty
Scooby***s Guy
Peaty's Avatar
Drives: 2019 Impreza Sport - MT
It almost looks like the harness plug that is hidden up in the headliner for an autodim rear view mirror
Peaty is offline   Reply With Quote
Old 07-03-2016, 01:44 PM   #4
JD001
JD001's Avatar
Drives: Subaru BRZ
You guys get autodim rear view mirrors?? I was counting myself lucky getting autolights....
Old 07-03-2016, 01:49 PM   #5
euthqt
Haha I needed some light! The 10 series doesn't come with auto dim mirrors, so not sure what else it is
Old 07-03-2016, 04:08 PM   #6
It's the plug for your electric toothbrush .......
JD001 (07-03-2016)
Old 07-03-2016, 04:38 PM   #7
JD001
JD001's Avatar
Drives: Subaru BRZ
Are you sure your car has not been wired up with an eavesdropping device - secret video and listening devices..
Old 07-03-2016, 05:49 PM   #8
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Out of curiosity can you start the car and put it in neutral or park and try removing the key with the car running?
Old 07-03-2016, 06:40 PM   #9
stevesnj
stevesnj's Avatar
The ends of the wires don't look frayed like it was pulled apart, looks like they were cut. Anything not work in the car?
My 2016 Build thread
Old 07-04-2016, 12:48 AM   #10
Mr Nerd
Mr Nerd's Avatar
Looks like one of the plugs tucked behind the head unit. Have you fooled with your stereo recently?
Mr Nerd is offline   Reply With Quote
Old 07-04-2016, 12:51 AM   #11
ryoma
ryoma's Avatar
it also looks like a connection for the footwell lighting. does your car come with that option?
Old 07-04-2016, 01:18 AM   #12
loose parts sometime make their way into cars during manufacturing or repair so as long as everything works I wouldn't worry.
I am seeing a pattern of unidetified electronics turning up lately though so maybe sombody is tracking us. http://www.ft86club.com/forums/showt...91#post2696291
Old 07-06-2016, 05:08 PM   #13
XtremeMaC
Drives: Asphalt Grey FR-S
that does in fact look like the stereo plugs I saw when I fiddled around with the HUD. if you can get a clearer picture of the inside of the connector.
well come to think of it, none of those connectors I saw had foam on them, it was usually the harness that had the foam wrapped around...
the fact that the terminal ends are not even exposed is interesting. did dealer do work on it?
2013 Asphalt Grey FR-S MT VIN: 7086XX
XtremeMaC is offline   Reply With Quote
Old 07-06-2016, 07:00 PM   #14
Maybe something from under the seat. Does your seat detect the presence of your butt? It's not an airbag connector. Those are yellow.
Strange noise Tiliziano Issues | Warranty | Recalls / TSB 1 06-05-2015 05:20 PM
Help me identify this wire! Extra wire around battery after clutch job YouShallKnow Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 12-09-2014 03:04 PM
New strange noise? kALMIGHTY Issues | Warranty | Recalls / TSB 45 05-02-2014 02:52 AM
NOW THIS IS JUST STRANGE White64Goat BRZ First-Gen (2012+) — General Topics 37 03-11-2013 10:26 PM
Reverse Wire Tap wire Location? Norkoastal Electronics | Audio | NAV | Infotainment 2 10-19-2012 11:22 AM
