Old 06-28-2016, 04:30 PM   #127
MJones_RB
MJones_RB's Avatar
Drives: Scion FR-S Series 10 #2462
"The BRZ has evolved again, with revised valves, camshafts and cylinder blocks."
So I Google FA20:
"The FA20D features both direct and port injection (Toyota's D-4S injection system) and Subaru AVCS variable valve timing system. It is used in the Subaru BRZ, and is identified by a Toyota engine family code known as the 4U-GSE, which is installed in the Toyota 86 and the Scion FR-S.[7] According to Subaru, 0W-20 oil is recommended."
and under that:
"FA20F: A version with Subaru's own direct fuel injection and twin-scroll turbocharger was introduced in 2012.
Displacement: 1,998 cc
Bore: 86 mm
Stroke: 86 mm
Compression Ratio: 10.6:1"
So the 86 uses Toyota's DFI system, even in the BRZ, but the F model uses Subaru's DFI system, and it's supercharged? Is it basically the same engine? Curious how this affected the new 86 version.
MJones_RB is offline   Reply With Quote
Old 06-28-2016, 04:31 PM   #128
Originally Posted by Deadrik View Post
That's my problem, i tend to over think everything. I go from looking at used to save money, to convincing myself that New is preferable due to warranty or any other crazy reason.
Also, if i'm not going BRZ, that Hot Lava FR-S here i come!
I long ago gave up on used but there certainly are beneifits. Team Lave is looking for some replacements!
I was thinking that it might be best to wait until the 2nd gen is released, however who knows when that might be.
If ever. (Ignore all speculation and prophesies on a "next gen" or you may wait for no reason.
Old 06-28-2016, 04:32 PM   #129
Freude am Fahren
Drives: '13 DGM BRZ Limited/'14 Yamaha R6
Originally Posted by Jeff Lange View Post
One of the interesting things is that there seem to be multiple things in the document stating that the SACHS suspension and Brembo brakes will be Japan-only.
Hopefully not.
Jeff
I think that's just how they are offered. I think in Japan, there will be an actual trim level that comes with them, while else where, it will be considered a separate package. Just a guess.
-XXR 527 18x8.75 +35
-Nameless 2.5" OP/FP Combo (Coming soon) & Axleback
-SBD 500X (Waiting on coating to install)
-Southbend SBD500X Clutch
Freude am Fahren is offline   Reply With Quote
The Following User Says Thank You to Freude am Fahren For This Useful Post:
krayzie (06-28-2016)
Old 06-28-2016, 04:37 PM   #130
funwheeldrive
Do you plan on heavily modding your car, or are you mostly going to keep it stock for a while?
Old 06-28-2016, 04:38 PM   #131
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
If it's a larger pump though, that still remains to be seen.
The new pump is physically identical in size to the old one. There are images of them in the PDF.
Stang70Fastback is offline   Reply With Quote
The Following 2 Users Say Thank You to Stang70Fastback For This Useful Post:
Guff (06-28-2016), Tcoat (06-28-2016)
Old 06-28-2016, 04:44 PM   #132
Guff
Now w/ over 400 womprats!
Guff's Avatar
Drives: BRZ LZR
- The Ancient BRZ Sacrament
by Zaku
Old 06-28-2016, 04:45 PM   #133
Deadrik
Drives: 02 Mustang, Hopeful BRZ soon
Performance wise, i would keep it mostly stock. It would become my DD + toy, and would need a damn good reason to convince myself to mod.
Deadrik is offline   Reply With Quote
Old 06-28-2016, 04:48 PM   #134
Deadrik
I got a large amount of people thats close to me telling me not to bother with new.
The first scratch, the first dink. I live in Brooklyn, my current mustang got sideswiped on two separate occasions (only cosmetic damage) and coincidently on each side
Also, i have been dying to get the Hot Lava, i wish it was on the BRZ.
The Following User Says Thank You to Deadrik For This Useful Post:
Tcoat (06-28-2016)
Old 06-28-2016, 04:51 PM   #135
raven1231
As mentioned above if you plan to mod it then there is no reason to buy new, at least in regard to warranty. If you plan to keep it stock I would likely buy new just for the changes but that's just personal preference. These cars have shown that they are pretty damn reliable even used.
Old 06-28-2016, 04:51 PM   #136
Stang70Fastback
A.K.A. Starlord
I don't consider that alone as an excuse to not buy a new car. I live in Chicago. I bought a brand new Series.Blue. I'm as OCD as it gets. What has happened so far?
Well, a car hit a piece of debris on the highway that shot into my door and put a 4" gash in the paint. Was I upset? Yes. Went through insurance, and got it fixed at a reputable shop, and now you can't even tell. A few months later an idiot lady opened her door into my car putting a huge vertical dent in the door. I waited until she came back out and got her info, and got that fixed (PDR) and now you can't even tell. I'm approaching 2 years of ownership now, and other than some rock chips, the only cosmetic damage to the car is a scuff on the left corner of the rear bumper, presumably from some incompetent fool who couldn't park. I thought it would annoy me, but it doesn't, really. Would I like to get it fixed? Sure. But the car still looks great.
Having said that, all of the other benefits that come with owning a new car still apply. Just because your first dent will suck (that first incident was painful) doesn't mean it might still not be worth it to you. Having said that, my car is also garaged when I'm not using it, so...
The Following User Says Thank You to Stang70Fastback For This Useful Post:
funwheeldrive (06-28-2016)
Old 06-28-2016, 04:58 PM   #137
Deadrik
Well your point of view is mine when respond to that. Same when it comes to RWD in winter, i hear the same thing every time.
Still have a lot to think about, and have some time before the '17 orders can go in. Thanks!
(Once i hit my 10 posts, i can start my thanking!)
Tcoat (06-28-2016)
Old 06-28-2016, 05:01 PM   #138
Deadrik
Thanks everyone for the input, however i think i might be derailing the thread just a bit!
Old 06-28-2016, 05:01 PM   #139
raven1231
So I Google FA20:
and under that:
Bore: 86 mm
Stroke: 86 mm
They are taking about the WRX engine above? I'm confused where you're getting the supercharged part.
MJones_RB (06-28-2016)
Old 06-28-2016, 05:17 PM   #140
After you have been here a while you will know you can never truly derail a thread here. They branch off but almost always end up straight again!
Official OpenFlash Tablet FA20 Tuning Tech Discussion Thread Rombinhood@OpenFlash Software Tuning 2594 08-01-2017 02:03 AM
Official: 2017 Acura MDX Teased, Will Debut In New York! Bye Bye Bird Beak? vh_supra26 Other Vehicles & General Automotive Discussions 4 03-23-2016 06:30 PM
2017 FRS Official Facelift Pics Zhangy Scion FR-S / Toyota 86 GT86 General Forum 2 03-17-2016 06:06 PM
Official New England random discussion thread! PRORICAN New England 503 07-24-2014 05:08 PM
Official FA20CLUB Turbo Kit FAQ Discussion FA20Club.com Forced Induction 67 01-09-2014 01:06 AM
