Old 06-22-2016, 06:35 PM   #1
Crunk81us
Drives: Toyota 86
Diff and gear oil. Fill to overflow, or service manual capacity??
I am going to be changing my diff and gear oils again with lighter weight oil.
Last time i did them, i filled until the fill hole dribbled.
BUT
I fit a lot more in than the service manual recommends.
So what is the go here?
I dont want to have too much oil in there sapping power from my 86 series race car..
I have always filled to the fill hole before.
manual states 2.2 for GB and 1.1-1.2 for diff.
I fit appx 2.8-3l in GB and 1.5-1.6 in the diff
Crunk81us is offline   Reply With Quote
Old 06-22-2016, 07:03 PM   #2
Oh, I'd suggest you just fill them up till they won't take any more and call it good.
Old 06-22-2016, 07:12 PM   #3
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Both are fine. If you want every ounce of performance, fill it to capacity as specified
-alex
The Following 2 Users Say Thank You to mav1178 For This Useful Post:
86kahl (06-22-2016), Crunk81us (06-22-2016)
Old 06-22-2016, 07:20 PM   #4
Crunk81us
Drives: Toyota 86
-alex
every ounce! yes every single one
Old 06-22-2016, 11:56 PM   #5
Verify they are level along both pitch and roll axes, fill until overflow, wait a bit, top them off to make sure. Don't overfill.
Wally86 (08-19-2021)
Old 06-22-2016, 11:59 PM   #6
gramicci101
Off Topic
What about yaw though?
The Following 2 Users Say Thank You to gramicci101 For This Useful Post:
Ultramaroon (06-23-2016), Wally86 (08-19-2021)
Old 06-23-2016, 01:04 AM   #7
Crunk81us
Drives: Toyota 86
Only needed when also reading lift, drag and thrust..
The Following 2 Users Say Thank You to Crunk81us For This Useful Post:
Old 06-23-2016, 01:13 AM   #8
Fucking peanut gallery... As soon as I submitted I knew I was gonna regret it.
Crunk81us (06-26-2016), Wally86 (08-19-2021)
Old 06-23-2016, 02:15 AM   #9
........not a red letter day for ol Ultramaroon .........
Ultramaroon (06-24-2016)
Old 06-24-2016, 01:31 AM   #10
Old 06-24-2016, 10:47 AM   #11
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
Fill until it comes out, then have a beer, then put the plug back in with a fresh crush washer.
JazzleSAURUS is offline   Reply With Quote
Old 07-06-2016, 12:49 PM   #12
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
I just try to fill close to capacity indicated in shop manual.
Old 08-18-2021, 06:59 PM   #13
trinidadj
Drives: '16 FRS-MT Ablaze Red
I just finished a clutch install, and I filled the transmission gear box until the oil started to seep back out the fill hole. I measured the oil remaining in the last bottle. Based on what’s left, I filled to about 2.6 liters. Will I have any issues with the extra fluid being in there or should I drain it and refill to 2.2L? Thanks
trinidadj is offline   Reply With Quote
Manual Trans./Diff. Fluid Change.?. westmansweed Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 13 07-15-2015 09:02 AM
Limited Slip diff oil Motul GEAR 300 LS 75W-90 FRSToyota86 Canada Classifieds 12 08-22-2014 01:47 PM
Tri-State Locals Special on NEWLY RELEASED Greddy HIGH CAPACITY DIFF COVER !!! 468Power NY / NJ / CT / PA 5 10-24-2013 11:21 AM
Rear diff service JoeBoxer Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 22 11-06-2012 11:23 PM
