Old 06-21-2016, 03:49 PM   #1
Simply_the_best
Tom's Racing ADDICT
Simply_the_best's Avatar
Drives: 2013 Toyota 86, 1999 Toyota Corolla
My Nameless header dyno results (results to follow)
Hi FT86Club I'm going next week to get dyno tuned and will be posting up my dyno numbers for anyone that is curious to know what magic this header is capable of. I have all other supporting N/A mods minus the BPB. I'm planning on well over 200 whp which will be easily attained as I did speak to John from Nameless over this passed weekend at Englishtown after the FD event. I will update with results next week. Here are some shots of my setup.
My Engine mods are:
Engine:
ECUTek stage 2 flex fuel tune by Motoeast
Motoeast flex fuel kit w/ zeitronix ethanol content analyzer
Buddy Club P1 racing pulley set
Perrin cold air intake (gold wrapped)
Perrin 3" inlet pipe
68mm throttle body
Crawford Performance AOS
Nameless Performance long tube header (ceramic coated)
Motiv Concepts 2.5" overpipe
Motiv Concepts 2.5" catless front pipe
MXP catback exhaust
Forester turbo oil cooler setup
Eneos 0w-20 sustina engine oil
**Update**(6/28/16)
This is the dyno results 198whp & 162wtq. The Dyno reads on the low side so for a fact I know im over 200 whp. A previous car was tuned on the same dyno as me put down 195whp and went to another shop and that same car made 207whp with no tune change. As well as when I was tuned it was 91 degrees ambient temps. I'm thinking somewhere around 210whp with cooler temps. The car pulls harder than before. BIG thanks to Mike @ Motoeast.
Check out my car journal!
"Straights are for fast cars. Corners are for fast drivers."
Instagram: @simply_the_best
Simply_the_best is offline   Reply With Quote
Old 06-21-2016, 04:18 PM   #2
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
OFT or Ecutek?
The Following 2 Users Say Thank You to NyC Zn6 For This Useful Post:
G-awesome (06-21-2016), MrFisty (06-21-2016)
Old 06-21-2016, 04:26 PM   #3
CSG Mike
CSG Mike's Avatar
Thats a nice wrap job!
The Following 4 Users Say Thank You to CSG Mike For This Useful Post:
86kahl (06-22-2016), Irace86.2.0 (02-22-2018), Simply_the_best (06-21-2016), ThatAsianBradah (02-22-2018)
Old 06-21-2016, 05:13 PM   #4
Simply_the_best
Tom's Racing ADDICT
Originally Posted by NyC Zn6 View Post
OFT or Ecutek?
EcuTek. I plan on breaking over 200 whp.
Thanks!! I have been wrapping headers and turbo manifolds for quite some time now. I have some experience. I have wrapped some crazier headers than these too!
The Following User Says Thank You to Simply_the_best For This Useful Post:
NyC Zn6 (06-21-2016)
Old 06-21-2016, 05:21 PM   #5
G-awesome
Drives: 2015 Firestorm Scion FRS
interesting...never knew the nameless header was a long tube design!
G-awesome is offline   Reply With Quote
Old 06-21-2016, 06:01 PM   #6
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
I love the nameless headers. Too bad they are hardly visible because they are a beautiful design.
MS, CSCS, TSAC-F, CPT
Old 06-21-2016, 06:52 PM   #7
Infinity
Drives: 2016 Scion FR-S
Can't wait to see the results for this.
Infinity is offline   Reply With Quote
The Following User Says Thank You to Infinity For This Useful Post:
Simply_the_best (06-22-2016)
Old 06-21-2016, 06:54 PM   #8
JDM Haze
JDM Haze's Avatar
Drives: Whiteout FRS
Subbed!
JDM Haze is offline   Reply With Quote
The Following User Says Thank You to JDM Haze For This Useful Post:
Old 06-22-2016, 11:14 AM   #9
Simply_the_best
Tom's Racing ADDICT
They're actually quite visible for the most part. They come up to about the center of the crank pulley. Especially if you have a Perrin CAI like mine. It opens up the front of the bay alot.
Old 06-22-2016, 12:02 PM   #10
shu5892001
Ontario's FT86
Drives: 2016 Lexus GS-F
well over 200whp, I am assuming this will be on E85 then?
2016 Lexus GS-F PPE EL Headers, Joe Z X Pipe, Tom’s Racing Drop in, RR Racing Tune, RR Racing Motor Mount, RR Racing USRS. 430WHP.
2024 Volvo XC60 T8 Recharge
shu5892001 is offline   Reply With Quote
Old 06-22-2016, 12:09 PM   #11
nisti
nisti's Avatar
Drives: BRZ & XV
From his journal:
Another member on here has a similar setup in terms of supporting mods.
He is getting 205 hp at the wheels.
nisti is offline   Reply With Quote
The Following 2 Users Say Thank You to nisti For This Useful Post:
shu5892001 (06-22-2016), Simply_the_best (06-22-2016)
Old 06-22-2016, 02:29 PM   #12
weederr33
weederr33's Avatar
I can't really see mine since I have the air box resonator and then the long supercharger intake pipe.
Old 06-22-2016, 02:41 PM   #13
Simply_the_best
Tom's Racing ADDICT
You are running the Nameless long tube header? Also Which charger are you running? Vortech? I am planning on going supercharged but know that only certain ones will work with this header. John from Nameless said that he was speaking with someone that had a vortech with this header but had to rotate the housing a little.
Old 06-22-2016, 02:44 PM   #14
Simply_the_best
Tom's Racing ADDICT
Originally Posted by Norville Rogers View Post
That gold wrap I take it it's heat resistant as well as reflective.
Does it have a particular name so I can search for some or any recomendations?
Yes it is very very heat resistant. There are tests that prove this stuff works flawlessly. Hope this helps.
https://www.designengineering.com/ca...r/reflect-gold
[ame="https://www.youtube.com/watch?v=XjFzTJOuDQE"]Tested - DEI Reflect A Gold Heat Thermal Racing Engine Tape - YouTube[/ame]
The Following 2 Users Say Thank You to Simply_the_best For This Useful Post:
Reamer (06-22-2016), Teseo (06-28-2016)
Dyno Results - OFT Stage 2 UEL + Openflash Header + Full Exhaust pinski Software Tuning 8 11-21-2016 12:07 PM
Ace Header 4-2-1 CS400 Custom BRZEdit Tune Dyno Results JDM-dono Engine, Exhaust, Transmission 24 05-05-2016 05:54 PM
Dyno results, ONLY mod Nameless Downpipe. (Yes, I know, no baseline....) Sportsguy83 Engine, Exhaust, Transmission 53 03-19-2013 01:39 PM
Dyno Compilation - dyno testing results and recommendations Illusive Engine, Exhaust, Transmission 82 02-08-2013 08:00 PM
Dyno results for the Nameless Performance street package! John@Nameless Announcements, Contests, Giveaways 31 06-26-2012 05:37 AM
