| DIY (Do-It-Yourself) Guides For all DIYs. |
2013-2017 Service Manual, 2016 Wiring Diagram & Extras
Rip of the service manuals (and other info) from Toyota's TIS Portal for 2013-2017 vehicles
This was ripped from TIS in 2016. There's no PDF versions of the service manuals in here, (but PDF's of the wiring diagrams though), due to how Toyota presents the information in TIS; additionally, keeping these as a website (or packaged website in the case of the offline version) allows following links between pages for extra steps and related work, and easily tracing wires in the wiring diagrams. Converting to PDF and linking between the pages would be a considerable amount of work, anyone is welcome to try though (I tried some automated methods but kept running into issues). I also didn't think to grab wiring diagrams for other years while I had access (it was more complex and I forgot to take notes as well), sorry. Please note: search at the top of the pages doesn't work (relied on parts of TIS that couldn't be ripped and would have required a bunch of work to make functional again) Online mirrors: https://gt86stuff.onrender.com/t3Portal/ https://t3p.vercel.app/t3Portal/ Offline version: (works on PC & Mac, it's just the website source packaged as an NW.js application) t3Portal-GT86.app.zip (1336 MB) (direct download link) (MD5: BF94055D6236F87FAC916D547BA503CB) t3Portal-Corolla.app.zip (883 MB) (direct download link) (MD5: 5E731419E018676F53D96BFEDDFC73C4) Uncompressed sizes are: TIS Website Files: 1359 MB (total, although each manual is only about 120-260 MB) Extra PDFs: 209 MB Windows Interface: 223 MB MacOS Interface: 250 MB It's possible to strip it down to decrease size, but it's all lumped together to prevent under-shared parts being lost. I won't be maintaining the mirrors or adding extras, so they may disappear over time, but feel free to make your own mirror if you wish (offline version contains the server contents and notes). Using the MD5 above can be used to make sure downloads of the zip files haven't been altered. (Edit: moving all info to this first post and updating links.) Last edited by fireblaze; 05-03-2024 at 06:58 PM. |
| The Following 34 Users Say Thank You to fireblaze For This Useful Post: | Alfs (06-01-2021), azian_advanced (02-10-2017), Boomerang (06-10-2016), cbryant514 (09-14-2017), Chaetagnath (06-10-2016), Clutch Dog (05-05-2019), Compelica (04-15-2021), EndlessAzure (01-17-2023), FirstWinter (10-10-2017), FRSBRZGT86FAN (06-12-2016), FunnyGopher (05-25-2021), fx1mark (10-11-2017), gkubed (02-05-2019), H1C (02-23-2024), halfwaytobedlam (10-29-2024), hifiguy99 (07-31-2020), johnowow (02-26-2023), mabviper (06-22-2016), Midtenn (08-01-2025), mitsurugi_78 (03-27-2017), MrDinkleman (06-20-2016), MugsBRZ (04-06-2019), Overdrive (11-22-2024), Pedro13 (02-05-2020), RedReplicant (03-21-2022), Resolute (06-03-2017), ScoobsMcGee (05-29-2021), sly (01-08-2020), stevesnj (06-10-2016), Trueweltall (09-26-2019), trxn (02-03-2024), Ultramaroon (09-14-2017), vintagemxer (05-17-2021), XK4 (02-09-2017) |
#2 |
86
Thanks!
#3 |
I guess no single file PDF?
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
#4 |
The thought had crossed my mind, but ultimately I decided to try n clone the site instead, since I liked some of the added functionality it gave. I did a quick search and found a script that might be able to convert the service manual files to pdf, although all intra-article links will probably break. The wiring diagrams are easy since TIS already had copies of them in pdf form (the print buttons brings them up). The only issue will be some sort of table of contents / index since the pdf would be quite large...
I'll try to convert it when I get a chance... |
#5 |
Thanks, I was going to do page by page but I saw the amount of pages then decided against..lol
#6 |
| The Following User Says Thank You to Tcoat For This Useful Post: | stevesnj (06-13-2016) |
#7 | |
Reading through that thread (which I had previously seen before I grabbed my own copy from TIS), it looks like for that vehicle ,Suburu released a copy in pdf as well as the web version, when I was in TIS I didn't see any easy pdf downloads for the 2016 FR-S, else I would have saved a few hours work... ![]() I just tried running the conversions program I found (wkhtmltopdf) against the service manual files; It worked on my small test bunch of files, but when I ran it against the whole directory it started kicking out not found errors on stuff that does exists. It will probably take some tinkering... I can zip the relevant directory and send it if you (or anyone else) wants to try... |
#8 |
LOL I am the last person that could try that!!!!
#9 |
Drives: 2016 Raven FR-S
THank you very much for this manual! This is absolutely amazing information.
I just have a quick question. I am going to be adding a subwoofer with amp to the existing sound system and headunit in the next two weeks. My plan is to use a line out converter on the rear speaker wires (as the rear speakers are crap anyway) and use that to connect the RCA's from the amp. In the wiring diagram, do the colours of all the wires match the colour scheme of the wires at the back of the physical head unit? Or did they decide to be inconsistent and are gonna force me to figure it out the hard way? I will be making a custom harness for this using Metra parts and will defs post my results when it is done. |
#10 | |
According to the EWD the rear speakers are wired as follows: HTML Code:
Headunit Pin 2 > Violet > Connector HD1* Pin 8 > Violet > RL + Headunit Pin 6 > Pink > Connector HD1* Pin 9 > Lt Blue > RL - Headunit Pin 1 > Yellow > Connector HD1* Pin 1 > Yellow > RR + Headunit Pin 3 > Black > Connector HD1* Pin 2 > Pink > RR - *Connector HD1 - Driver Side Foot-well Left |
#11 | |
Drives: 2015 Scion FR-S Base MT
| The Following User Says Thank You to Captain Curt For This Useful Post: | stevesnj (06-22-2016) |
#12 |
Yeh I'll try
#13 |
Rip updated to include all FR-S & Toyota 86 model years, Subaru to come at some point in the future...
Since I have the basic site structure, I am able to rip new data sets in about an hours time (I wrote down how this time :P), the EWDs take significantly more time.... I wish I had taken notes the first time... If anybody want to share their Toyota/Subaru TIS access with me, I'd rip some stuff for them... (getting tired of paying to get more stuff) FYI, I don't check the email associated with this account often... |
#14 | |
I was going to remake the entire thing into a .pdf with clickable links. |
| Tags |
| repair manual, service manual, wiring diagram |
| BRZ Headlight pin/wiring diagram | 2SeeKU | Electronics | Audio | NAV | Infotainment | 12 | 06-28-2020 03:17 AM |
| O2 sensor wiring diagram | g0odspeed | Electronics | Audio | NAV | Infotainment | 1 | 12-18-2015 06:01 PM |
| Wiring diagram for BCU | 1GiantTurtle | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 12-07-2014 11:10 PM |
| 2 SVC+ 2 DVC WIRING DIAGRAM | PineappleFriedRice | Electronics | Audio | NAV | Infotainment | 8 | 03-03-2014 01:12 PM |
| Wiring Diagram for base radio? | -max- | Electronics | Audio | NAV | Infotainment | 2 | 12-19-2012 05:39 PM |
