Old 06-16-2016, 05:38 PM   #1
DGM-BRZ
DGM-BRZ's Avatar
Drives: 2017 CWP STi
18x8.75 For daily.
http://www.kijiji.ca/v-tires-rims/ci...res/1172473561
Im thinking about buying these.
First off, would these fit on my Stock height Subaru BRZ without issues?
Im going to use these for daily driving. Would it help/make worse my mileage/acceleration? Im mostly looking for a aestetically pleasing wheel but will help improve mileage/speed.
Are these too big? Should I go smaller for daily driving? I don't track.
DGM-BRZ is offline   Reply With Quote
Old 06-16-2016, 05:43 PM   #2
Maarten
Drives: Silver GT86 2013
The wider the worse the gas mileage. But you'll have more grip in corners and during acceleration.
I drive with 9,5rear and 8,5 front. My gas mileage went from 8-8,5l/100km to about 9-9,5 (sorry for the unit) it's not a terrible increase. But it's there non the less.
Normally 8,75 shouldn't give any fitment problems if I'm correct. Maybe you could also check the wheel directory on this forum for more info.
Verstuurd vanaf mijn A0001 met Tapatalk
Maarten is offline   Reply With Quote
Old 06-16-2016, 05:47 PM   #3
DGM-BRZ
DGM-BRZ's Avatar
Im Canadian so I use the same units.
That's odd, Im getting 9.9L/100km right now. AT transmission.
I must be doing something wrong...
Would the wheels I linked even be able to fit on my car? Size/bolts wise. Im not too educated on wheels.
Also anybody know if the wheels are any good?
Oh and, these should help with my acceleration?
Old 06-16-2016, 05:52 PM   #4
Maarten
Yea twins are also 5x100 and Et 35 will fit perfect flush in the front. But the rear will be slightly to much inwards. But only about 5-10mm so it won't show that much.
BTW I drive an mt and do quite allot of highway driving. I'm also not accelerating like crazy on every light.
If I go for a fun ride I average about 11l/100km
Old 06-16-2016, 05:57 PM   #5
DGM-BRZ
DGM-BRZ's Avatar
What do you mean by rear being slightly too inwards? Sorry, I'm new to this. I never expected to mod my car past cosmetic mods.
Oh that makes sense. Im usually driving locally and not highway.
Old 06-16-2016, 05:59 PM   #6
Maarten
The Et value is how much the wheel moves outwards. The higher the Et the more it moves out.
Like I said. Check the wheel directory. You'll learn allot. It's pinned up at the top in the wheels and tires group/folder or whatever you call it.
Old 06-16-2016, 06:28 PM   #7
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Fit? It will fit fine.
Too big? It's not in terms of spec. It will look like shit with stock suspension without camber adjustment. Even with camber it will look weird.
Acceleration and mileage will be worse. If you want better mileage, get some Prius wheels.
-alex
chaoskaze (06-16-2016)
Old 06-16-2016, 06:50 PM   #8
DGM-BRZ
DGM-BRZ's Avatar
Thanks for the replies fam.
Im looking for other options now, something that will hopefully look better on stock height.
Old 06-16-2016, 06:51 PM   #9
Maarten
Not much will look real good on stock height.
Old 06-16-2016, 08:09 PM   #10
DGM-BRZ
DGM-BRZ's Avatar
Old 06-16-2016, 08:25 PM   #11
driggity
Drives: Silver Coupe with a Boxer
Check the wheel directory for what different wheels will look like.
This thread has multiple pictures of the wheels you're interested in on a car with stock suspension: http://www.ft86club.com/forums/showthread.php?t=15163
driggity is offline   Reply With Quote
Old 06-20-2016, 09:35 AM   #12
Ashikabi
Ashikabi's Avatar
I have 18x8.75 +36 for my dailies. They look and drive fine. I'm lowered so that helps the fender gap. 18s will look better than the stock 17s but not as good as lowered 18s. No different wheel will change this. Fender gap is ugly and only lowering can fix it. Doesn't mean your wheels have to be ugly too
Old 06-22-2016, 07:28 PM   #13
illmatic_frs
illmatic_frs's Avatar
Drives: n/a
Rule: Don't go 18" unless you also lower.
Sent from my HTC One M9 using Tapatalk
illmatic_frs is offline   Reply With Quote
FS: Enkie Raijins Black 18x8.5/18x8 +45 5x100 (sold) FRSPhil Wheels and Tires 64 10-12-2016 03:37 PM
Gauging interest Enkei RS05RR 18x9+40/18x8.5+50/18x8.5+42 THMotorsports.com Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 09-19-2013 05:33 PM
Wheel Directory: WedsSport Maverick 210S 18x8.0 +?? / 18x8.5 +?? quik1987 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 09-04-2012 01:07 PM
Wheel Directory: Blitz BRW Profile 08 18x8.0 +45 / 18x8.0 +38 quik1987 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 08-27-2012 04:34 PM
