Old 06-15-2016, 02:57 PM   #211
Torry@HKSUSA
Torry@HKSUSA's Avatar
Drives: HKS
Originally Posted by HuntingtonFRS View Post
Has anyone done a BOV on this kit?
It comes with a recirculated BOV. If you mean a *different* BOV, then I haven't heard of anyone trying to do it. Not that it couldn't be done, but there's not much reason to do it.
Torry@HKSUSA is offline   Reply With Quote
Old 06-15-2016, 03:46 PM   #212
HuntingtonFRS
Drives: 2013 Scion FR-S in White
It's a Bypass Valve on it now. A little different.
HuntingtonFRS is offline   Reply With Quote
Old 06-15-2016, 03:51 PM   #213
Torry@HKSUSA
Drives: HKS
Not really. A recirculating BOV is the same thing as a bypass valve. HKS even refers to it as a BOV in the manual.
Old 06-15-2016, 05:02 PM   #214
Andew727
Drives: Scion FR-S
its different. and i added a tial recirculating BOV to mine directly after the compressor. check out my build on instagram @AndyB727. i also added a much larger intercooler with a vertical core
Andew727 is offline   Reply With Quote
The Following 3 Users Say Thank You to Andew727 For This Useful Post:
CxG (06-16-2016), HuntingtonFRS (06-15-2016), Kris86 (06-21-2016)
Old 06-15-2016, 05:37 PM   #215
HuntingtonFRS
http://www.motoiq.com/MagazineArticl...cion-FR-S.aspx
Old 06-15-2016, 05:53 PM   #216
HuntingtonFRS
Do you have a video you can share or post on Instagram of the BOV?
Old 06-15-2016, 09:01 PM   #217
Shinra Inc
Shinra Inc's Avatar
Drives: Tiny Bronco
Originally Posted by Torry@HKSUSA View Post
That's because we just added your ECU ID to the website yesterday
We are making the announcement later today for confirmed fitment through 2016 with the Flash Editor.
However, the Flash Editor is *not* able to overwrite the Ecutek flash. You must be running a stock ROM to use the HKS FE.
Oooooooo sneaky!
So the only required parts for the included tune would be the exhaust and spark plugs?
Shinra Inc is offline   Reply With Quote
Old 06-16-2016, 09:19 AM   #218
Torry@HKSUSA
Drives: HKS
Originally Posted by Shinra Inc View Post
Oooooooo sneaky!
So the only required parts for the included tube would be the exhaust and spark plugs?
I'm assuming you meant to say tune, not tube. But yes.
Old 06-16-2016, 03:16 PM   #219
Andew727
Drives: Scion FR-S
car isnt finished yet but i will post everything to instagram and youtube as soon as its finished. ill list all my mods below.
-stg1
ecutek (james martin) tuned
HKS gt supercharger 100mm pulley
HKS s-type oil cooler
moto-east e85 kit
perrin lw crank pulley
fic injectors
dw65c fuel pump
ft86speedfactory headers
greddy cs gts ver2 cat back
**engine failure: valve spring cracked, valve guide chipped, and cam damage. i was lucky it happened at a redlight**
-stg2
90mm pulley & removing restictor plate
treadstone 26x10x3 vertical core intercooler
BC I beam connecting rods w/ arp extreme hardware
King rod bearings
stock cr pistons (rods required machine work for install)
Arp head studs & cosworth head gaskets
GSC Ti valve springs retainers
valve job
omni 3 bar map sensor
Tial 50mm BOV
TRD baffled oil catch can
custom intercooler piping
act 6 puck clutch kit with heavy duty pressure plate and LW flywheel
mtec shift springs w/ trd shifter kit
perrin shifter bushing w/ tranny support
all fluids replaced with redline
Old 06-16-2016, 03:45 PM   #220
Andew727
Drives: Scion FR-S
Question, hoping someone may have an answer for this.
so these kits use a draw through MAF not a blow through MAF. i have noticed most guys mount their BOV's closest to the intake manifold/furthest from the MAF sensor. i am waiting to hear back from evasive to see if you have to do this or not because my original BOV location thought was going to be directly after the compressor for a great sound and i would be shortening the lengthy recirculating tube to about 3 inches instead of it being 6 feet long.
please help if you have any knowledge on this pre or post intercooler mounting of BOV's on a centrifugal set up.
Old 06-16-2016, 06:59 PM   #221
Shinra Inc
Shinra Inc's Avatar
Drives: Tiny Bronco
Yep. Oops. Thanks.
Old 06-22-2016, 01:22 PM   #222
Timmy_Jones
Spun
Drives: 23' Supra
Anyone install the kit at home, with the HKS tuner and email the, for the 93 octane tune? I run 93 only and was hoping they could ship the tuner, with the 93 tune already loaded on it.
Timmy_Jones is offline   Reply With Quote
The Following User Says Thank You to Timmy_Jones For This Useful Post:
zeal86 (06-22-2016)
Old 06-22-2016, 01:42 PM   #223
zeal86
zeal86's Avatar
Drives:
That would be nice for those in areas where 93 is readily available but I believe you would have to get with an HKS pro dealer for a 93 tune.
__________________________________________
projekt zeal86 build
zeal.eightsix Facebook
Instagram | zeal.eightsix
zeal86 is offline   Reply With Quote
The Following User Says Thank You to zeal86 For This Useful Post:
Timmy_Jones (06-22-2016)
Old 06-22-2016, 02:21 PM   #224
Timmy_Jones
Spun
Drives: 23' Supra
Pro-Dealer for me is almost two hours away...agreed, wish I could just get the 93 octane loaded up on the tuner.
supercharger help... sosick Forced Induction 25 08-16-2013 12:02 AM
HKS GT Supercharger Evasive Motorsports Forced Induction 48 02-08-2013 07:21 PM
ETA on TRD Supercharger? frsinpa Forced Induction 18 01-11-2013 11:09 AM
supercharger? but by who? carbonBLUE Forced Induction 14 11-02-2012 11:10 PM
HKS GT Supercharger Kit BPAuto Forced Induction 18 10-27-2012 04:11 PM
