| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
#43 |
Drives: whiteout, dark tint
Air bubble. You gotta jack up the drivers side and run it with the heater on
#44 | |||||
Drives: 2015 Series.Blue
You're just changing things without knowing the issue. You also keep driving it when the more you overheat, the more likely you are to blow a headgasket or something... |
#46 |
Drives: Full race 4cyl boxer
#47 |
BRZ overheating
When bleeding coolant put the thermostat as high up as possible
| The Following User Says Thank You to 86kahl For This Useful Post: | Notso (06-10-2016) |
#48 | |
Of course that is unless you go with a waterless coolant that doesn't expand with temperature, but that's beside the point. |
#49 |
Drives: FT86
There is a bleed valve in the top heater hose at rear of engine its in the 90 degree connector. Use that to bleed system , have heater on full hot setting
When you driving turn the heater in car on full with fan running for heater on full. Does it blow rearly hot air when car is hot, if not the coolant is not circulating, check for blocked radiator or hoses or the thermostat is in backwards. you have already replaced pump. |
#50 | |
Drives: Subaru BRZ
So, it seems to be getting better each time I bleed it, but it still doesn't like to be idle at a stop light, or going over 50, even in 6th low rpms. Casual town driving 35mph it seems to be doing fine though, about half temp on the gauge. The hottest it gets now is just under 3/4 on the gauge, still not comfortable with that. I'm hoping it's just a really pesky airbubble. I've jacked up the car, both sides at different times, squeezed the radiator hoses. Used the air bleed valve, revved the engine while bleeding, heater on etc...
#51 | |
Drives: 2005 Toyota Camry
-alex |
| The Following 4 Users Say Thank You to mav1178 For This Useful Post: |
#52 | |
Drives: '12 C63 P31, '23 GRC
Past: (2) 2000 MR2 Spyder, 2017 GTI Sport, 2006 Porsche Cayman S, Supercharged 2013 BRZ-L, 2007 Honda S2000, 1992 Integra GS-R |
#53 | |
Drives: Subaru BRZ
#54 | |||
You stated the following: Quote:
The system may (or may NOT be) under an increased absolute pressure with respect to atmospheric pressure. The system is (by definition) "Closed" as it is allowed to have an absolute pressure that is different than the atmosphere. It is also "closed" due to the fact that the system's water pump does not have to pump against any "head" (there is no uphill vs downhill). Another condition of a "closed loop" system is that it's working fluid volume remains constant during operation (if you let any coolant escape, it doesnt get replenished). The system most definitely MUST have a differential pressure which is completely different than absolute pressure. For the system to provide cooling it requires differential pressure (provided by the water pump) to circulate the water through the cooling passages and through the heat exchanger (radiator). No differential pressure, no flow, no cooling. The fact that the system pressurizes due to the water reaching boiling temperature has absolutely nothing to do with the operation of the system EXCEPT: If the system did not maintain a CLOSED LOOP SYSTEM during steady state operation, the coolant would boil away and leave you with no working fluid. So does the system need to be "pressurized" wrt to atmospheric pressure to operate? NO. Now what are we talking about wrt burping and why can the system stop "pumping" and overheat badly? What can stop the cooling system from operating? 1 - The heat cannot move from the heat source (engine) to the working fluid 2 - The heat cannot move from the working fluid to the heat exchanger (radiator) 3 - The heat exchanger cannot transfer heat to the heat sink (atmosphere). 4 - The working fluid cannot move from the heat source to the heat exchanger (pump not pumping) So now that we have that cleared up, we can refer to the 4 conditions above when trying to figure out why the system stopped working. And lets not forget that there are three possibilities occurring in the OPs case: A - The Engine is fine except the cooling system is malfunctioning B - The Cooling system is fine but the engine is producing too much heat and the cooling system cannot handle the heat load. C - The engine is not really overheating but the temperature indicators are malfunctioning. OR.... Has anyone suggested checking for: Oil in the water? Water in the Oil? Inability of the cooling system to maintain pressure under a pressure test? Because any of those things could indicate a blown head gasket. Or you could just stick your HEAD IN THERE and LOOK for a blown head gasket..... Quote:
some leaks (such as a blown head gasket) will only present themselves when the system is under pressure it is infinitely easier to stick your head in an engine bay and look for coolant leaks when the engine is not running and cold as opposed to running and HOT. |
| The Following 2 Users Say Thank You to justatroll For This Useful Post: | gravitylover (06-13-2016), Tcoat (06-13-2016) |
#55 |
Drives: 2014 BRZ Limited
Nah. Never mind. This guy obviously didn't pass middle school earth sciences class, so arguing with him is pointless.
#56 | |
.. earth science class..... Riiiiight...... Got it. You clearly WERE going to say something but thought better of it. Because you are out of YOUR class maybe? Oh and what can cause #4 above (pump not pumping)? How about 'cavitation'? You might want to look that up. Last edited by justatroll; 06-14-2016 at 03:15 PM. |
| Overheating of central part of cabin between seats | jorgelucho | Issues | Warranty | Recalls / TSB | 2 | 10-06-2014 04:48 PM |
| Massive Overheating Incident | mitosis | Issues | Warranty | Recalls / TSB | 26 | 11-18-2013 08:12 AM |
