Old 06-11-2016, 11:58 PM   #1
adtsoft
Drives: 2016 Scion FR-S
Backup Camera and Amp
I have a brand new Scion FR-S (manufactured 4/16) and I am swapping out the stock stereo with backup camera with one that also has navigation and Sirius. I have searched high and low and cannot find the proper wiring for the backup camera and power to the amp to turn it on. I have found descriptions of a 16 pin connector that I don't have and descriptions of a 28 pin connector that I have but the wires for the camera aren't in it, only the reverse wire.
Has anyone figured this out? Otherwise I plan to ohm out the harness the hard way and will post pic of what I find. Also from what I have read the camera needs 6VDC, so I will be making a voltage regulator to power it and will post the details.
adtsoft is offline   Reply With Quote
Old 06-12-2016, 11:15 PM   #2
adtsoft
Solved
I solved my problems. The amp is powered by the standard connector via the blue wire in most adapters and connects to the brown factory wire.
I found the camera on a 24 pin connector that only has four wires.
Orange Camera Video -
Black Camera Video +
Yellow Camera Battery +
Brown Camera Ground
*These do have some gray checks but you can easily identify them given these colors.
Keep in mind that the camera uses 6VDC so you need to use a voltage regulator, not 12VDC!
The Following 3 Users Say Thank You to adtsoft For This Useful Post:
Chimera (06-13-2016), Kushkaki (07-24-2021), SVXdc (06-19-2016)
Old 06-19-2016, 07:17 PM   #3
SVXdc
Radio wiring harness guru
SVXdc's Avatar
Drives: 1996 SVX L AWD
Code:
Orange Camera Video (-)
Black  Camera Video (+)
Yellow Camera Battery (+)
Brown  Camera Ground
Thanks for posting that.
Here's a rotated/cropped version of your picture, with pin numbers added:
The colors appear to be black, white, orange, red. Is your picture from the harness in your FR-S, or a pic you found elsewhere?
Would you please confirm the colors you saw, and match them to the pin numbers?
SVXdc is offline   Reply With Quote
The Following User Says Thank You to SVXdc For This Useful Post:
Old 06-20-2016, 09:57 PM   #4
adtsoft
Good catch SVXdc, I mixed up the colors between the dash and trunk harnesses.
Trunk Harness at Camera (four pin):
Colors are for the harness plugging into the camera pigtail wiring.
2 - Light Blue Camera Video -
1 - Orange Camera Video +
4 - Brown Camera Ground
3 - Yellow Camera Battery +
Dash Factory Harness (24 pin):
24 - Orange Camera Video -
12 - Black Camera Video +
23 - Red Camera Video Ground
11 - White Camera Battery +
Let me know if you have any other questions. It would be easy for me to take a picture of the trunk wiring.
The Following 2 Users Say Thank You to adtsoft For This Useful Post:
Kushkaki (07-24-2021), SVXdc (06-25-2016)
Old 06-25-2016, 09:54 PM   #5
SVXdc
SVXdc's Avatar
I'm sure I'm not the only one who will be interested to see pictures of the camera harnesses in the trunk -- both the 'from car' side and the 'into camera' pigtail.
What are the model numbers on the OEM HU that was originally in your FR-S?
If you ever pull your new HU again, it would be nice to see clearer pictures of that 24-pin plug, as well as the other factory harnesses that were connected to the OEM HU. Looking to see if there are any new (possibly undocumented) signals on any of those harnesses.
Old 06-25-2016, 09:55 PM   #6
SVXdc
SVXdc's Avatar
To retain the OEM camera, people might find that using half of Metra's AX-TOYCAM3 is helpful:
Some GT86 models outside North America use the smaller 4-pin "Eclipse" style connector for the rear camera. This other harness looks like it will work for that: AX-MAZCAM
In both cases, you'll still also need a 6V voltage converter.
You can offer the unused half of either of those harnesses to someone who wants to connect an aftermarket camera into the same OEM HU (and they will probably work for a few other Toyota/Scion OEM HU models, too).
Old 09-07-2016, 12:35 AM   #7
Magoo
Magoo's Avatar
Drives: 2013 Scion FRS
First, thanks for posting this info. I have a 2013 FRS and found a 2016 Head Unit on ebay for cheap. Everything plugged right in and worked fine. I don't have a backup camera and after some research, found that almost everything out there is for the 2015 head unit.
I found this and am hoping that it might do the trick. Thoughts?
https://camera-source.com/2016-scion...amera-kit.html
Magoo is offline   Reply With Quote
SOLD - Rydeen Duo ZH07-150B Backup Camera and Rear Camera SVXdc Harness NanDAssi Audio/Visual, Electronics, Infotainment, NAV 5 11-24-2015 06:06 PM
Backup camera G8mou Northern California 28 01-08-2015 02:25 AM
Q&D backup camera VR46 Electronics | Audio | NAV | Infotainment 8 09-05-2014 11:13 PM
Backup Camera Raven23 Electronics | Audio | NAV | Infotainment 6 07-16-2014 03:50 PM
PnP Backup camera - BRZ? Skurj CANADA 1 04-10-2014 02:33 PM
