Old 06-03-2016, 03:48 PM   #15
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
Originally Posted by FRS Justin View Post
I would assume it would push a freeze plug out before it would go thru the JB Weld.
agreed. unless you have way more than normal coolant pressure, that'll probably hold forever. if you have high coolant pressures, you have much larger problems lol
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
The Following 2 Users Say Thank You to spitfire481 For This Useful Post:
themadscientist (06-03-2016), Ultramaroon (06-04-2016)
Old 06-03-2016, 07:21 PM   #16
themadscientist
Hotlink Terrorist
themadscientist's Avatar
Drives: 2015 WRB BRZ Spec S
That's what I'm thinking. Since my new turbo is not water cooled I have a free threaded hole into the water jacket where I could stick a pressure sensor. I have plenty of extra gauges so I could use an oil or fuel pressure meter and relabel it OH SHIT!
Old 06-04-2016, 02:58 AM   #17
86kahl
86kahl's Avatar
Drives: whiteout, dark tint
I mean, you have a replacement block coming. I'd cross my fingers, keep it on stock psi and keep the AAA card handy
86kahl is offline   Reply With Quote
Old 06-04-2016, 06:30 AM   #18
themadscientist
Hotlink Terrorist
That could be a problem since I'm going to be bolting one of these on it.
The Following User Says Thank You to themadscientist For This Useful Post:
86kahl (06-04-2016)
Old 06-04-2016, 10:29 AM   #19
Now we are talking things up my alley! Through the years I have had no less than 4 engines that had cracks or holes in them from various different causes and "repairs" that were just as varied (including JB Weld). Like you have said you have no clue how long it will last. My results went from a month or so to 15 years and counting (as of last year when I last saw the guy with my old car).
From my experience your "Oh shit" gauge may as well be labeled "too late anyway" since if the repair fails bad enough to register on a gauge there will be no going back.
You said a new block right now is not an option anyway so throw it in, drive it and wait for the cloud of steam and oil that may or may not show up.
Old 06-04-2016, 07:57 PM   #20
themadscientist
Hotlink Terrorist
I don't care about the block. I just want to catch it before the rotating assembly gets hurt. I can always reuse it in the new block.
Old 06-04-2016, 09:12 PM   #21
Irace86
Drives: BRZ + Ducati M796
Is that an area under lots of pressure? I can't tell.
Don't underestimate JB weld. In the welding industry, epoxies are supplying labor-cheap welds over conventional mig/arc/tig welds, and are actually stronger, last longer and have less of an error/fail rate.
Irace86 is offline   Reply With Quote
Old 06-04-2016, 11:36 PM   #22
themadscientist
Hotlink Terrorist
It's part of a larger, um "scheme" if you will. There is epoxy smeared inside the water jacket and there are cracks running across the deck. It's really bad.
Old 06-05-2016, 12:02 AM   #23
JB Weld is some amazing shit. Surface prep is key. If done right, I wouldn't be surprised if something else let go before that repair.
Tcoat (06-05-2016)
Hlep. I failed. Shaisters Northwest 14 06-02-2016 10:56 PM
Nameless overpipe/downpipe welds failed and perrin endlink failed stockysnail Northwest 4 01-14-2016 06:27 PM
Failed login notification griffinnn Site Announcements / Questions / Issues 6 02-18-2015 08:21 PM
WTB: FA20 Long Block/Short Block blown/running The Racers Line Engine, Exhaust, Bolt-Ons 7 07-29-2014 01:26 AM
WTB: FA20 Short Block or Blown Long Block The Racers Line Want-To-Buy Requests 1 06-29-2014 05:21 PM
