Old 06-02-2016, 11:33 PM   #1
themadscientist
Hotlink Terrorist
themadscientist's Avatar
Drives: 2015 WRB BRZ Spec S
failed block warning signs
Not on my BRZ, I'm not boosting the little guy. No, I have another engine that has cracks and has been sleeved. The engine builder is confident it will hold, I know it won't and I'm fully stupid for trying to use it because I know it's going to fail, but here we are.
I am trying to figure out how the failure will present so I can catch it if it does. Obviously, there's the no doubt failure with oil and water all over the road, that's easy, but it's that slow, subtle failure I'm trying to watch out for. Regular checks of the radiator and the sump for the wrong fluid showing up will likely be a daily thing, but I'm thinking about plumbing a pressure sensor into the block to monitor the pressure of the coolant in the water jacket.
I probably won't have my new engine blocks in until next year at this rate so I just need this one to last that long while I wait for the new parts and work through the drivetrain so it can handle the next engine built on a solid foundation.
Old 06-02-2016, 11:41 PM   #2
navanodd
Drives: 2013 BRZ Sport-tech WRB
Monitoring crank case pressure might be the better way to go if you're thinking that route. I would expect if something is leaking that you'd see the most obvious pressure change there.
Though I would honestly think that the vibration signature and engine sound would be the first alert. If any cracks form, the resonant frequencies of the block will change as it becomes less stiff in certain areas. I would expect this to happen before any fluids start moving around.
navanodd is offline   Reply With Quote
The Following User Says Thank You to navanodd For This Useful Post:
mixtape (06-03-2016)
Old 06-02-2016, 11:57 PM   #3
themadscientist
Hotlink Terrorist
Oh it's cracked up real nice already, even has a blob of JB weld on the outside, BONUS!This whole thing is so Ill-advised. It's like "hey, how hard can I pull on a grenade pin before it comes out and how will I know when it just released?"
The Following User Says Thank You to themadscientist For This Useful Post:
86kahl (06-04-2016)
Old 06-03-2016, 07:51 AM   #4
FirestormFRS
I'm not seeing the point in the question. The block has already failed if you have a hole in the side of it.....Troll maybe?
FirestormFRS is offline   Reply With Quote
Old 06-03-2016, 08:24 AM   #5
AJPG
Drives: 22RE, FA20, 4G63
WTF?
AJPG is offline   Reply With Quote
Old 06-03-2016, 08:42 AM   #6
themadscientist
Hotlink Terrorist
Old 06-03-2016, 09:24 AM   #7
AJPG
I won't dare to ask how that happen... but that doesn't look like a fa20.
As you or your mechanic use epoxy to fix it I assume I not a major structural damage; that been said it could last... for some indeterminate time.
The Following User Says Thank You to AJPG For This Useful Post:
Old 06-03-2016, 09:31 AM   #8
mixtape
Posts in the nude
mixtape's Avatar
Drives: 2016 WRB BRZ
What was your biggest clue? The "NISSAN" stamps on the side?
2016 Subaru BRZ - World Rally Blue [Build Thread]
Instagram: @mixtography | My Automotive Photography
"Lesbian trees have no wood." - Scoobs McGee
mixtape is offline   Reply With Quote
The Following 5 Users Say Thank You to mixtape For This Useful Post:
86kahl (06-04-2016), nickmerronesucks (06-03-2016), Tectoniic (06-03-2016), themadscientist (06-03-2016), Toyarzee (06-03-2016)
Old 06-03-2016, 09:39 AM   #9
nickmerronesucks
Ned flanders
nickmerronesucks's Avatar
Drives: 13 BRZ, 16 Hellcat, 22 Ram 2500
RB or KA? lol I had a KA24DE once that had a Penny JB welded over a crack in the block. not sure how that happened but never had an issue until i blew it up on purpose before pulling it out
797Performance.com
nickmerronesucks is offline   Reply With Quote
The Following User Says Thank You to nickmerronesucks For This Useful Post:
Old 06-03-2016, 09:45 AM   #10
AJPG
The iron and the Nissan did help lol
Old 06-03-2016, 09:46 AM   #11
themadscientist
Hotlink Terrorist
It's an RB26 from a GT-R. The blocks are poorly cast in many cases and crack most of the time between the water jacket and bolt holes. I have all kinds of that and the cylinders were sleeved. The external patch is on a crack caused by the force of the front diff which is integrated into the oil pan shifting up under load and literally trying to break the block's back; again, a common failure. Unfortunately, the new blocks I ordered are on indefinite delay so I had to use what I had. What I had was absolute crap.
The engine builder swears it will hold. I know he's wrong. How long it will hold is something nobody can know. What I am trying to do is formulate the best warning system to alert me when it splits in case it doesn't immediately present with fluid all over the place. I was thinking a new leak would cause a shift in not just temperature, but also pressure in the cooling system. I can watch for that. I'm just not sure if the pressure will drop or rise, but if every day it's sitting at one point then suddenly swings I can shut it down and save the internals.
A friggin penny? That's so fail it's win!
Old 06-03-2016, 09:52 AM   #12
nickmerronesucks
Ned flanders
I say try it out, if there is a huge issue make the engine builder take fault and do all the work to repair it since hes saying its safe..lol.
My girlfriends dad accidently installed a stud to far into the head of his engine and it pierced through a water jacket or something(when bolt is removed coolant pours out), so his fix was to send the bolt in with some type of gasket maker or something..small block chevy little s10 makes a buttload of power and is holding up.. lol
797Performance.com
Old 06-03-2016, 09:56 AM   #13
themadscientist
Hotlink Terrorist
That's GM, though; that actually works. My buddy made head gaskets out of red RTV for his old low comp anemic Monte Carlo 350.
It's a long story, but we have different levels of acceptable. Part of my haste and thus my acceptance of a block that is a ticking time bomb is to get an engine running in it so they can get it put back together so I can get it away from them so I can have a more trustworthy builder build the replacement engine properly when the new blocks arrive.
Old 06-03-2016, 03:28 PM   #14
FRS Justin
Drives: 2013 Asphalt FRS
I would assume it would push a freeze plug out before it would go thru the JB Weld.
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
The Following User Says Thank You to FRS Justin For This Useful Post:
Ultramaroon (06-05-2016)
Hlep. I failed. Shaisters Northwest 14 06-02-2016 11:56 PM
Nameless overpipe/downpipe welds failed and perrin endlink failed stockysnail Northwest 4 01-14-2016 07:27 PM
Failed login notification griffinnn Site Announcements / Questions / Issues 6 02-18-2015 09:21 PM
WTB: FA20 Long Block/Short Block blown/running The Racers Line Engine, Exhaust, Bolt-Ons 7 07-29-2014 02:26 AM
WTB: FA20 Short Block or Blown Long Block The Racers Line Want-To-Buy Requests 1 06-29-2014 06:21 PM
