Old 12-14-2015, 03:31 PM   #85
No1der
No1der
No1der's Avatar
Drives: BRZ Limited Satin White
+1 for the BRZ
No1der is offline   Reply With Quote
Old 06-02-2016, 09:18 PM   #86
treminaor
"DGM BRZ"
treminaor's Avatar
Drives: 2016 BRZ Limited
Just did this successfully to my BRZ on my own since I found most of the wiring posts here conflicting and/or confusing. Mine now have normal turn signal capabilities, no switchbacks or LEDs or anything fancy. And they don't come on with the foglights but I could probably tap the running lights or the boomerangs if I cared enough, but I don't. I'll post a video soon.
treminaor is offline   Reply With Quote
The Following User Says Thank You to treminaor For This Useful Post:
iLaw (06-02-2016)
Old 06-02-2016, 10:46 PM   #87
iLaw
iLaw's Avatar
Drives: 2015 BRZ, Aozora Edition
I'd love to know which wires you tapped specifically since the BRZ is single filament vs. The FRS that is dual filament. Looking forward to your video!
iLaw
2020 Subaru Crosstrek Sport
2015 Subaru BRZ Aozora Edition (Sold)
iLaw is offline   Reply With Quote
Old 06-03-2016, 12:16 AM   #88
treminaor
"DGM BRZ"
treminaor's Avatar
I tapped the white turn signal harness wire on the passenger side and the red turn signal harness wire on the driver's side. I also un-crossed the wires within the driver's side turn signal so that power went to power and ground went to ground.
[ame="https://www.youtube.com/watch?v=o6WbbxmusL8"]BRZ Sidemarkers to Turn Signals Conversation Notes - YouTube[/ame]
The Following 4 Users Say Thank You to treminaor For This Useful Post:
aegisdrgn (06-03-2016), BaatLuk (09-18-2017), norcalpb (03-16-2017), tato.valverde (06-06-2016)
Old 06-03-2016, 12:25 AM   #89
aegisdrgn
aegisdrgn's Avatar
Drives: Scion FR-S 10 Series #2263
Nice!
Do the sidemarkers still light up when your headlights/parking lights are on?
aegisdrgn is offline   Reply With Quote
Old 06-03-2016, 12:42 AM   #90
treminaor
"DGM BRZ"
treminaor's Avatar
Originally Posted by aegisdrgn View Post
Nice!
As I mentioned in the other comment, they don't come on as fog/parking lights anymore because they are wired directly to the turn signals. If you wired the boomerang wire (which is the original white and white/red wires respectively on both sides of the car in the sidemarker plugs) into the series you could probably make it work but you would have to have some sort of circuit added (relay??) in there so the sidemarkers still flash correctly regardless of the on/off state of the parking lights. I'm not an electrician lol.
Old 06-05-2016, 01:39 PM   #91
iLaw
iLaw's Avatar
Firstly, thanks for making that video, it was extremely helpful.
Hmmm, I wonder what the solution is if I want my side markers to work when the headlights are on. I don't really care if they are in sync or not (in the original FRS video the side marker was synced when headlights were off and alternated when headlights were on).
You mentioned in your video that on the driver's side, the wires were crossed. and the boomerang was in that series somewhere... I wonder if you sent the ground wire from the side marker to the live wire of the signal bulb, would that work? As when the signal is off, it would be a complete circuit, but when the signal flashed the system would have no ground and the side marker would turn off...
I'm not an electrician either, so I'm just using my high school electronics knowledge for this... I have no idea if that would work lmao
iLaw
Old 06-05-2016, 03:22 PM   #92
treminaor
"DGM BRZ"
treminaor's Avatar
Before I noticed the wires were crossed on the drivers side sidemarker I ended up wiring the turn signal hot wire to the boomerang ground, which caused the boomerangs not only to flash alternately with the turn signals but it overloaded the circuit and made the sidemarker very dim.
Honestly since my tail lights have the DOT sidelights and my car is lit like a christmas tree when the lights are on I wasn't too worried about losing my sidemarkers - I gained more safety from having them as turn signals than fog lights lol. If you figure out how to have the best of both worlds let me know.
Old 07-06-2016, 07:51 PM   #93
iLaw
iLaw's Avatar
I have successfully accomplished this on the BRZ. It's complicated, if you want to do it right. It took myself, electrician, 4 relays some wires and a soldering iron to do it. Will post update soon. Taking pictures of the work and will write up a full thing soon.
iLaw
The Following 4 Users Say Thank You to iLaw For This Useful Post:
aegisdrgn (07-07-2016), Ben_G (01-04-2017), codesplice (07-07-2016), n0thing (01-07-2017)
Old 07-06-2016, 09:49 PM   #94
treminaor
"DGM BRZ"
treminaor's Avatar
Why is alternating sequence considered the "right" way? Do they still work as fog lights?
Old 07-06-2016, 10:24 PM   #95
iLaw
iLaw's Avatar
The alternating sequence is only happens when the side markers are on (boomerangs or headlights on) and you signal. I'll explain more on why it happens in my detailed post.
Fog lights have nothing to do with the wiring for making singling side markers. Fog lights are on a completely different circuit and its unnecessary to touch them to accomplish this.
iLaw
Old 07-07-2016, 02:06 AM   #96
aegisdrgn
aegisdrgn's Avatar
I eagerly await your write up! I love reading about how people make small but meaningful mods to their cars.
Old 01-03-2017, 02:20 PM   #97
n0thing
Drives: Subaru BRZ
Did you manage to finish the write up? Looking to do this to my BRZ (single filament turn signal). I bought LEDs for side markers, but may have to revert back to filament 194s. I wonder if the following works? Basically remove the side maker ground and tap it into signal wire.
edit: nvm, i believe the above would only work with frs due to double filament signal bulbs
n0thing is offline   Reply With Quote
Old 01-04-2017, 11:01 AM   #98
Ben_G
Drives: Blue BRZ
Huh...4 relays, eh? Sounds like those boomerangs made things pretty complicated. Looking forward to the write up...
Ben_G is offline   Reply With Quote
clear side marker part number NOBROWS Cosmetic Modification (Interior/Exterior/Lighting) 34 09-11-2017 10:12 PM
**Toyota 86 Fog Light Bezels $34.9, 86 Arm Rest, GT86 Badge, Fog Light Set for $112.9 nigel-jdmparts Exterior Parts - The Rest 524 02-28-2016 11:24 AM
Converting side marker to turn signals ayau Cosmetic Modification (Interior/Exterior/Lighting) 30 12-13-2015 04:41 PM
does your car come with side door marker light? excited86 CANADA 12 08-02-2012 07:07 PM
Raven blacked out side marker before and after Roadstercycle FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 17 06-24-2012 11:52 PM
