Old 05-20-2016, 09:28 PM   #1
theman233
Drives: 2013 subaru brz
P0500 after wheel stud install
Hello ft86,
Today I had a shadetree mechanic install new wheel studs on my passenger side rear wheel, everything went fine until he told me to get in and give it a test ride and I noticed the traction control, ABS, and check engine light were all on after a block. I told him this and he told me he forgot to hook up the speed sensor cable.... Anyways, he hooked up the cable back and after I turned the car back on, only the ABS and traction control light went off. Is the check engine light on only as a precautionary since it saw the cable was unplugged? It hasn't gone away after a couple of restarts and I'm just wondering what could have gone wrong...since from what I searched, all 3 lights would be on if the cable was broken? The mechanic told me it would probably go away after I got home, and that he would get a reader and help later, but I'd rather not go back.
Thanks
theman233 is offline   Reply With Quote
Old 05-20-2016, 09:40 PM   #2
steve99
Drives: FT86
Originally Posted by theman233 View Post
Hello ft86,
Thanks
yeah it was likely all due to wheel sensor not plugged in.
you can clear the CEL and codes by just removing battery terminal for a few minutes. If it does come back after that then you have other problems
Tcoat (05-22-2016)
Old 05-20-2016, 09:44 PM   #3
kev60625
Drives: 2013 WRB Subaru BRZ
you can clear the CEL and codes by just removing battery for a few minutes. If it does come back after that then you have other problems
This
kev60625 is offline   Reply With Quote
The Following 2 Users Say Thank You to kev60625 For This Useful Post:
86kahl (05-20-2016), Tcoat (05-22-2016)
Old 05-21-2016, 10:50 PM   #4
Hello ft86,
Today I had a shadetree mechanic install............
Thanks
Well, now, your first mistake, was having a "shade tree" mechanic do the work on a modern car ....... I'll betcha he was OLD ........ and still thinks the emergency brake drum on the FR-S is the main brake .......
And the "mechanic" must have been from Indiana and learned his shade tree mechanic skills from working on John Deere tractors .........
What kind of shade tree did he pull your car under ........ any tree other than maple is ....... WRONG!
However, he doesn't sound like a fool ......... "here, I just replaced all the studs on your wheel .... YOU go take it for a test drive" ........
IN case you haven't figured it out ........ ol humfrz is ah jest messen wich ya ......
Like ol @steve99 suggests, just disconnect the negative post of the battery till you can count to 100 (backwards) then hook it back up.
NO, contrary to what ol steve99 says, you DO NOT have to "remove the battery". He was just trying to upsell you into a new battery ...... he had already set you up with his "if your battery is old comment". Next would have been ....... "well, now since you have the battery out" .....
Anyway, welcome to the forum ....... and I hope the battery disconnect snaps the computer back upright ..........
steve99 (05-21-2016), Tcoat (05-22-2016)
HELP! Lug nut and wheel stud stripped! jaydee_do_work Scion FR-S / Toyota 86 GT86 General Forum 17 07-26-2015 02:50 PM
Broken Exhaust Stud During FP Install EvoPrecision8 Engine, Exhaust, Transmission 28 03-31-2015 04:21 PM
Wheel stud options chris86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 09-26-2014 03:40 PM
Replacement Lug Stud/Wheel Hub swift996 Issues | Warranty | Recalls / TSB 3 08-30-2013 02:58 PM
Wheel stud Guaruja Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 10-11-2012 03:42 AM
